Zfs send | zfs receive overwriting mountpoints
I nearly had an aneurysm today when I did my normal backup, but for the first time choosing to send encrypted datasets as raw, with a command like:
zfs send -v -R -w tank@backup-2025-06-27 | zfs receive -v -F -o readonly=on backuptank/backup
The aneurysm formed as I went to mount my home directory and got an error that it didn’t exist…
zfs list -t fs -r backuptank showed:
NAME                                USED  AVAIL  REFER  MOUNTPOINT
backuptank                          2.55G  10.8T    96K  /mnt/backuptank
backuptank/backup                   2.55G  10.8T   112K  /mnt/tank
backuptank/backup/home              2.55G  10.8T   304K  /mnt/tank/home
backuptank/backup/home/evan         2.55G  10.8T   312K  /mnt/tank/home/evan
Note that backuptank/backup mounted itself onto /mnt/tank where tank is supposed to be…
I worked out that I can zfs receive -u to not mount the received dataset, and therefore can fix this after the backup completes, but is this supposed to happen and is there a better way to avoid?
Best wishes,
Evan
Things will workout a lot simpler, if you try the same with a tool like syncoid.
Thank you for the idea! Syncoid doesn’t seem to mention encrypted datasets or raw mode? I don’t want the data re-encrypted (so I can use the same keys to open it as the original) or re-compressed (one of the encrypted datasets is large and manages 1.57x with zstd-6 and 1.0x with lz4…, whereas the rest of the datasets are best with lz4).
Just to add: zfs receive -x mountpoint did not help – the mountpoint was still copied from the source.
syncoid does work with encrypted datasets, and replicate in raw mode
use "–sendoptions=w " with syncoid to achieve this
(note : it starts with two - but appears as a long dash here)
Perfect – thank you! It uses zfs send/receive underneath. What does it do differently to not munge the mountpoints?
I think syncoid author Jim Salter is the best person to explain this. checkout
The issue still occurs with syncoid but syncoid helped me find it, and syncoid behaves slightly different in a way that is less dangerous.
zfs send -R implicitly sets -p – Include the dataset’s properties in the stream. This includes mountpoint. syncoid does its own method of --recursive that does not automatically include --preserve-properties, but I need --preserve-properties, and enabling it also sends the mountpoint. However, syncoid sends the mountpoint as /mnt/mnt/tank which at least does not conflict with /mnt/tank! That will be fine. :slight_smile:
I wasn’t aware of syncoid previously – thank you!
For those interested in syncoid: it needs a perl module Capture::Tiny. I downloaded syncuid and Capture::Tiny .pm files from GitHub, and installed like this into /mnt/tank/local:
export PREFIX=/mnt/tank/local
export PERL5LIB=$PREFIX/lib/perl5
mkdir -p $PERL5LIB/Capture
cp Tiny.pm $PERL5LIB/Capture
cp syncoid $PREFIX/bin
and set PERL5LIB in .zshrc.
Also I found the order of command line options mattered. With —sendoptions=w somewhere in the middle it errored with source/destination dataset not found, but worked when put last.
I submitted a PR for syncoid syncoid: add capability to preserve inherited properties by evan314159 · Pull Request #1013 · jimsalterjrs/sanoid · GitHub
  • not set excluded properties when preserving properties (like mountpoint)
  • add new option --preserve-inherited-properties to copy properties that were inherited at the source but would not be inherited at the destination
