What is the full output of
sudo ethtool ens2f1
And how are the quality of the ethernet cables ??
You could try to swap the cables on the Win & Server , to see if the 1GB follows the cable/switch-port
sudo ethtool ens2f1
Settings for ens2f1:
Supported ports: [ TP ]
Supported link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
This is the device we are using from LSPCI
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller 10-Gigabit X5 40-AT2 (rev 01)
01:00.1 Ethernet controller: Intel Corporation Ethernet Controller 10-Gigabit X5 40-AT2 (rev 01)
Seems like the port advertise 10G
Strange that it isn’t selected.
Try
sudo ethtool -s ens2f1 autoneg off speed 10000 duplex full
And if it survives :
Post output of
sudo ethtool ens2f1
We want to make sure the switch isn’t going into half duplex , due to autoneg off.
1000baseT/Full
10000baseT/Full
1000baseT/Full
10000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
drv probe link
Did you run the
Is this a cable issue?
Are you using a Cat5 cable or maybe a damaged cable?
I see this question has been asked but I don’t see an answer.
It’s possible it’s a cable issue. I have some cheap cat six patch cables But honestly, I suspect aren’t even actually cat 6. But as it was less than 1 m I thought it would be OK.
I haven’g tried anything new yet. I have some cat6a Cable and ends I’m gonna make up my own patch cables and then try again. I just haven’t gotten around to it. I’ll report back once I know.
