Per the above, small files will fit into small blocks so the expectation is met.
What I didn’t anticipate is tails of large files that are smaller than the small block cutoff going into the sVDEV as well. I will have to re-write the sVDEV resource to be more careful in that phrasing.
I don’t think there is anything inherently wrong with tails going into the sVDEV, presumably fragmentation and lots of leftover file tails mixed in small files have a lower impact on system performance there than they would in the HDD pool.
Still, it’s curious just how little of my sVDEV is in use vs. pool capacity. Anyhow, many thanks to everyone re: enlightening me!
It wouldn’t just be the tails. Any middle block that compresses below the cutoff will also apply. This can theoretically happen with highly compressible files.
RAIDZ is not great for small blocks, but not as bad dRAID. For 9-wide dRAID your smallest physical allocation is 9 ashifts, no matter how little you write, while for any width of even RAIDZ3 it is “only” 4 ashifts. For more typical RAIDZ1 – just 2 ashifts. So RAIDZ in worst case will be close to mirror on efficiency, while dRAID has potential for much worse.
Ahh I see. Hmm… I would go even one step further. I have only roughly 350GB of files that are NOT 1M. So how do I ended up with 750GB svdev? Just tails?
Or maybe old snapshots?
Little bit off topic, but it depends on the size and pool geometry.
Imagine a RAIDZ2 that is 12 drives wide.
From a traditional RAID, you would expect 83.33% storage efficiency. (12-2) / 12 = 83.33%
But for RAIDZ2, if the files are 16k in size, you only get 66%.
See this see this RAIDZ efficiency table and explanation on why.
This might be a none issue for you, if for example you only store files that are +1M in size and have a record size of 1M. Because the bigger the record, the smaller the “RAIDZ problem” tends to get.
If you use zvol for VMs with a blocksize of 16k, all your writes will be 16k (or below thanks to compression). This could make the potential problem worse.
With dRAID the problem is, that the smallest write has to be the size of the number of data drives multiplied by sector size (probably 4k). So in a dRAID2:10d:0s:12c, which is two parity, 10 data, the smallest write possible is 40k.
Yes, I do. Since that is the default, I am a little bit skeptical turning it on.
Edit: I ran it manually. Usage is still ag 72% according to zpool. But maybe that is just a zpool update thing?
Had a look, my sVDEV is only 6% full while the 50x larger Z3 pool is 28% full. Given that I rebalanced the entire pool, I am somewhat flummoxed to have so little in terms of tails. I don’t expect any “guts” since most of my data is incompressible - archives, images, and videos.
Granted, I went on a metadata-destroying crusade by putting a lot of things into sparsebundle archives that only present themselves as larger files to the file system, but still I would have expected a larger “tail” impact than I see here, especially considering that most datasets have a small block cutoff of 512k, for example. That is one step below the 1M recordsize for everything else. Curious!
This makes sense, but means that the svdev was specifically designed for dRAID and is less suitable for raidz.
Home users hardly ever have a use case for dRAID; this then implies that they hardly have a case for svdev. Hard drive raidz[2,3], optionally with (metadata) L2ARC and/or separate SSD mirror pool for apps/VMs, and that’s it.
True. But I’ve already made several changes for upcoming ZFS 2.4 to start moving its focus. It will be able to play as SLOG. It will be allowed to be RAIDZ (actually any topologies without previous restrictions, so that you could use some 3-wide RAIDZ of SSDs special for some multiple 10-wide RAIDZ2 of HDDs pool). special_small_blocks will be allowed arbitrary values. zfs rewrite will allow to easier migrate data there and back. But yea, it is a good point that it needs some more thinking on the semantics of small blocks.
It can be vice versa:
There is a hardly case for SSD mirror pool for apps/VMs. Hard drive raidz[2,3] optionally with sVDEV and /or separate “SSD-only” dataset for apps/VMs, and that’s it.
One one hand, the restriction looks strange.
On the other hand, having a raidz2 (4+ drives) special vdev is not attractive if a 3-way mirror does the job with appropriate redundancy. And a raidz svdev would raise the same issue of low efficiency for small files (blocks) as the main raidz storage.
Until now, I only thought of special vdev as a matter of performance, hence SSD, with low capacity requirements.
But with huge dRAID vdevs a “residual” chunck of a big file that would be to small to store efficiently across the whole dRAID could still be sizeable (up to megabyte size maybe?), and there could be lots of these; so svdev could be a matter of capacity. Then a raidz2 svdev with HDDs may make sense next to a dRAID array.
Same. Especially “metadata” and “dedup” special vdevs.[1] Other than RAM and avoiding reboots, I can see the obvious performance boost of these types of special vdevs.
Can’t speak for enterprise, but my guess would be that if you polled random, non-enterprise end-users about why they added a special vdev to their pool, they are likely to say it’s because they want to increase performance, since their spinning HDDs are a bottleneck.
EDIT: Full disclaimer. My personal opinion: For home use, I think special vdevs can be more trouble than they are worth. They require additional storage drives (usually NVMe’s), complicate the pool’s structure, and can put your data at risk if you don’t properly treat them with the same degree of importance as your HDD vdevs.
Maybe not as much for a “small blocks” special vdev, but I wouldn’t be surprised if users got the wrong impression of what it’s really meant for. ↩︎
Excuse my nit-picky corrections please, just want to make sure I get this right.
Less suitable for RAIDZ with a perfect pool geometry for small files.
hardly have a case for svdev with anything else than the default 0 for small files. 0 results in a metadata only svdev, which home users have a use case for.
That is implying that you only need small read and writes to be fast.
Could be true, but I am not so sure about this.
Also it probably would only work for docker/LXC and not for VMs.
If you go with the default 16k for blocksize for VMs, separating the speed requirements by size is a lot harder. You can’t set it to 16k, otherwise ALL data is in svdev. And if you set it to 8k, it might not speed up everything you need.
SATA is IMHO perfectly fine, since it is about IOPS and not bandwidth. And the IOPS of SATA drives is still miles better than HDDs.
It’s not harder. It is, aiui, impossible. Unless you want to store the entire zvol on sVDEV (which is pretty common btw). I suspect that some compressed blocks could also end up there with 0 < special_small_blocks < volblocksize.
Yes. It’s exactly the substitute for a “separate SSD mirror pool for apps/VMs”. And you get a metadata performance boost for the entire pool as a bonus.
