How do i get the "su" password inside a container? (Nextcloud help)
The message is not an error just a warning. Not meaningful unless you are exposing to the internet. When you get to the point of setting up a reverse proxy, that will enable you to get rid of it easily. There’s a config file you can edit to fix it, but, then you have to make it persistent. That all depends on how it is setup, etc. Easier to just handle with reverse proxy if you plan of setting one up or ignore it. It’s more a docker container error than anything, they (nextcloud) should have done this already in my opinion.
Well, sweet! Then that should mean everything is set up and happy. You’ve been an incredible help!
