Need help with ZFS Cache, it is crashing my TrueNAS
It doesn’t seem like I could disable the maintenance schedule. and I am not sure this is required to run plex. I tried jellyfin but for some reason i didn’t like it and I already had plex life pass from long time ago.
I had few other days where my system goes unresponsive, not necessarily during this maintenance task.
This honestly driving me crazy lol
another one, all of drop offs to flat lines were time it went froze.
BTW This isn’t CPU temp issue, as I undervolted and has been under 70 even if full load. This was my first troubleshoot.
IMO, you definitely shouldn’t disable it for good. Just like a temporary solution (if it is a solution at all) while you are seeking help from plex users/devs. Perhaps you have prioritised support with plex pass (just speculating).
Could also be the reason.
i understand undervolt could be an issue but during cpu stress test and memtest, it passed without any problem.
Well let’s start taking variables out of this equation. In hindsight all those ARC charts are telling me is that your server only survives a few hours at a time. Get it back to bone stock and try again.
I will do that command line that caps the arc size and see if my system survives plex maintenance. fingers crossedddd
I’d recommend a wattage cap instead of undervolting for a NAS specifically. I’m fairly certain it isn’t related to what you’re experiencing, but while we’re testing things, it likely can’t hurt.
Was going to be my next question. Fair enough, memory is assumed stable.
Don’t forget that you can change the hours the Plex maintenance runs, so you don’t have to wait until 2-5am :smiley:
Might be worth checking the Plex logs to see if it captures anything - though I think by default logs are tmpfs (exist in memory & don’t survive reboot) and it could be worth changing it to anything else for testing so you can go back & see wtf Plex was doing.
I’ll say it again, an oom event would leave a log trail.
If you find no log trail it’s possible your crashes are due to something else, like unstable hardware.
Verify that it’s an oom event before you spend more time investigating.
If capping the ARC size fixes the problem of the server crashing, I don’t consider that a solution. It means an underlying issue exists.
Don’t let anyone who is a big fan of Core over Scale know (I don’t want them to get even more smug), but I proactively cap ARC on Scale… just in case.
(You are right though - it is not a fix)
How do I get the logs that you are looking for?
You did see I already brought out the popcorn?
Unfortunately, it did not survive last night’s plex maintenance schedule.
You’re back to this.
For all we know, this might be a specific bug in Plex that somehow kills the server or triggers an OOM event.
ok How do I check the logs? I will provide the info once I know how to get the logs.
If not mistaken:
/var/log/syslog
The laziest way I’d try would be to see output of
grep -i memory /var/log/syslog
or grep -i oom /var/log/syslog
or grep -i "killed process" /var/log/syslog
…I’m lucky enough that I haven’t had a crash due to oom before, so I’m vague on what the output would be - but I’m like 75% sure that one of those should give you some kind of hit. Otherwise, enjoy reading the system log in its entirety I guess :frowning:
Jun  6 15:40:46 truenas kernel: DMI: Memory slots populated: 2/4
Jun  6 15:40:46 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  6 15:40:46 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  6 15:40:46 truenas kernel: Early memory node ranges
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c79000-0x80c79fff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  6 15:40:46 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  6 15:40:46 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  6 15:40:46 truenas kernel: Memory: 31560704K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756260K reserved, 262144K cma-reserved)
Jun  6 15:40:46 truenas kernel: x86/mm: Memory block size: 128MB
Jun  6 15:40:46 truenas kernel: Freeing initrd memory: 76420K
Jun  6 15:40:46 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  6 15:40:46 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  6 15:40:46 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  6 15:40:46 truenas kernel: nvme nvme1: allocated 64 MiB host memory buffer.
Jun  6 15:40:46 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun  6 15:40:46 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  6 15:40:47 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  6 15:40:47 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  6 15:40:47 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  6 15:41:20 truenas lxcfs[3597]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun  7 01:36:27 truenas kernel: DMI: Memory slots populated: 2/4
Jun  7 01:36:27 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  7 01:36:27 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  7 01:36:27 truenas kernel: Early memory node ranges
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c7a000-0x80c7afff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  7 01:36:27 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  7 01:36:27 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  7 01:36:27 truenas kernel: Memory: 31560652K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756260K reserved, 262144K cma-reserved)
Jun  7 01:36:27 truenas kernel: x86/mm: Memory block size: 128MB
Jun  7 01:36:27 truenas kernel: Freeing initrd memory: 76420K
Jun  7 01:36:27 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  7 01:36:27 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  7 01:36:27 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  7 01:36:27 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun  7 01:36:27 truenas kernel: nvme nvme2: allocated 64 MiB host memory buffer.
Jun  7 01:36:27 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  7 01:36:28 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  7 01:36:28 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  7 01:36:28 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  7 01:37:02 truenas lxcfs[3600]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun  7 03:20:11 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 10:09:25 truenas kernel: DMI: Memory slots populated: 2/4
Jun  7 10:09:25 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  7 10:09:25 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  7 10:09:25 truenas kernel: Early memory node ranges
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c7a000-0x80c7afff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  7 10:09:25 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  7 10:09:25 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  7 10:09:25 truenas kernel: Memory: 31560624K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756264K reserved, 262144K cma-reserved)
Jun  7 10:09:25 truenas kernel: x86/mm: Memory block size: 128MB
Jun  7 10:09:25 truenas kernel: Freeing initrd memory: 76420K
Jun  7 10:09:25 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  7 10:09:25 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  7 10:09:25 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  7 10:09:25 truenas kernel: nvme nvme1: allocated 64 MiB host memory buffer.
Jun  7 10:09:25 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun  7 10:09:25 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  7 10:09:26 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  7 10:09:26 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  7 10:09:26 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  7 10:10:01 truenas lxcfs[3590]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun  7 10:35:19 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 11:16:49 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 11:22:01 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 13:16:09 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 13:21:21 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 14:08:02 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 14:20:34 truenas kexec-load[441928]: Loading new kernel image into memory...
Jun  7 14:28:44 truenas kernel: DMI: Memory slots populated: 2/4
Jun  7 14:28:44 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  7 14:28:44 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  7 14:28:44 truenas kernel: Early memory node ranges
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c79000-0x80c79fff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  7 14:28:44 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  7 14:28:44 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  7 14:28:44 truenas kernel: Memory: 31561140K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756264K reserved, 262144K cma-reserved)
Jun  7 14:28:44 truenas kernel: x86/mm: Memory block size: 128MB
Jun  7 14:28:44 truenas kernel: Freeing initrd memory: 76420K
Jun  7 14:28:44 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  7 14:28:44 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  7 14:28:44 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  7 14:28:44 truenas kernel: nvme nvme2: allocated 64 MiB host memory buffer.
Jun  7 14:28:44 truenas kernel: nvme nvme1: allocated 64 MiB host memory buffer.
Jun  7 14:28:44 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  7 14:28:45 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  7 14:28:45 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  7 14:28:45 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  7 14:29:19 truenas lxcfs[3569]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun  7 15:18:30 truenas kernel: DMI: Memory slots populated: 2/4
Jun  7 15:18:30 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  7 15:18:30 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  7 15:18:30 truenas kernel: Early memory node ranges
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c79000-0x80c79fff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  7 15:18:30 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  7 15:18:30 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  7 15:18:30 truenas kernel: Memory: 31560816K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756260K reserved, 262144K cma-reserved)
Jun  7 15:18:30 truenas kernel: x86/mm: Memory block size: 128MB
Jun  7 15:18:30 truenas kernel: Freeing initrd memory: 76420K
Jun  7 15:18:30 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  7 15:18:30 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  7 15:18:30 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  7 15:18:30 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun  7 15:18:30 truenas kernel: nvme nvme2: allocated 64 MiB host memory buffer.
Jun  7 15:18:30 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  7 15:18:31 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  7 15:18:31 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  7 15:18:31 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  7 15:19:05 truenas lxcfs[3574]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun  7 20:03:49 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 20:09:00 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 20:19:23 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 21:21:38 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 21:42:23 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 21:47:35 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 21:52:46 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:10:36 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:15:47 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:20:58 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:26:09 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:31:21 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:36:32 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:41:43 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:46:55 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:52:06 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  7 23:57:17 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 00:02:28 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 02:07:00 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:14:26 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:19:38 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:30:00 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:35:12 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:40:23 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:45:34 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:50:46 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 03:55:57 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 04:01:08 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 04:06:19 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  8 07:07:54 truenas kernel: DMI: Memory slots populated: 2/4
Jun  8 07:07:54 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  8 07:07:54 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  8 07:07:54 truenas kernel: Early memory node ranges
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c79000-0x80c79fff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  8 07:07:54 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  8 07:07:54 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  8 07:07:54 truenas kernel: Memory: 31560792K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756264K reserved, 262144K cma-reserved)
Jun  8 07:07:54 truenas kernel: x86/mm: Memory block size: 128MB
Jun  8 07:07:54 truenas kernel: Freeing initrd memory: 76420K
Jun  8 07:07:54 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  8 07:07:54 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  8 07:07:54 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  8 07:07:54 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun  8 07:07:54 truenas kernel: nvme nvme2: allocated 64 MiB host memory buffer.
Jun  8 07:07:54 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  8 07:07:55 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  8 07:07:55 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  8 07:07:55 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  8 07:08:29 truenas lxcfs[3579]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun  9 03:11:32 truenas kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 0
Jun  9 08:32:57 truenas kernel: DMI: Memory slots populated: 2/4
Jun  9 08:32:57 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  9 08:32:57 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  9 08:32:57 truenas kernel: Early memory node ranges
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c79000-0x80c79fff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  9 08:32:57 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  9 08:32:57 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  9 08:32:57 truenas kernel: Memory: 31560764K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756268K reserved, 262144K cma-reserved)
Jun  9 08:32:57 truenas kernel: x86/mm: Memory block size: 128MB
Jun  9 08:32:57 truenas kernel: Freeing initrd memory: 76420K
Jun  9 08:32:57 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  9 08:32:57 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  9 08:32:57 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  9 08:32:57 truenas kernel: nvme nvme2: allocated 64 MiB host memory buffer.
Jun  9 08:32:57 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun  9 08:32:57 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  9 08:32:58 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  9 08:32:58 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  9 08:32:58 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  9 08:33:31 truenas lxcfs[3558]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun  9 19:52:26 truenas kernel: DMI: Memory slots populated: 2/4
Jun  9 19:52:26 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun  9 19:52:26 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun  9 19:52:26 truenas kernel: Early memory node ranges
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c79000-0x80c79fff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  9 19:52:26 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun  9 19:52:26 truenas kernel: Freeing SMP alternatives memory: 40K
Jun  9 19:52:26 truenas kernel: Memory: 31560700K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756260K reserved, 262144K cma-reserved)
Jun  9 19:52:26 truenas kernel: x86/mm: Memory block size: 128MB
Jun  9 19:52:26 truenas kernel: Freeing initrd memory: 76420K
Jun  9 19:52:26 truenas kernel: Freeing unused decrypted memory: 2028K
Jun  9 19:52:26 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun  9 19:52:26 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun  9 19:52:26 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun  9 19:52:26 truenas kernel: nvme nvme2: allocated 64 MiB host memory buffer.
Jun  9 19:52:26 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun  9 19:52:27 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun  9 19:52:27 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun  9 19:52:27 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun  9 19:53:00 truenas lxcfs[3573]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun 10 06:47:58 truenas kernel: DMI: Memory slots populated: 2/4
Jun 10 06:47:58 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun 10 06:47:58 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun 10 06:47:58 truenas kernel: Early memory node ranges
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c79000-0x80c79fff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun 10 06:47:58 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun 10 06:47:58 truenas kernel: Freeing SMP alternatives memory: 40K
Jun 10 06:47:58 truenas kernel: Memory: 31560816K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756264K reserved, 262144K cma-reserved)
Jun 10 06:47:58 truenas kernel: x86/mm: Memory block size: 128MB
Jun 10 06:47:58 truenas kernel: Freeing initrd memory: 76420K
Jun 10 06:47:58 truenas kernel: Freeing unused decrypted memory: 2028K
Jun 10 06:47:58 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun 10 06:47:58 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun 10 06:47:58 truenas kernel: nvme nvme1: allocated 64 MiB host memory buffer.
Jun 10 06:47:58 truenas kernel: nvme nvme2: allocated 64 MiB host memory buffer.
Jun 10 06:47:58 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun 10 06:47:59 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun 10 06:47:59 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun 10 06:47:59 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun 10 06:48:32 truenas lxcfs[3558]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jun 11 10:45:18 truenas kernel: DMI: Memory slots populated: 2/4
Jun 11 10:45:18 truenas kernel: ACPI: Reserving FACP table memory at [mem 0x8d274000-0x8d274113]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving DSDT table memory at [mem 0x8d1f8000-0x8d26ae4a]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving FACS table memory at [mem 0x8f263000-0x8f26303f]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d276000-0x8d27e16b]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d275000-0x8d275220]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving FIDT table memory at [mem 0x8d26e000-0x8d26e09b]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving MCFG table memory at [mem 0x8d26d000-0x8d26d03b]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving HPET table memory at [mem 0x8d26c000-0x8d26c037]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving FPDT table memory at [mem 0x8d26b000-0x8d26b043]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving VFCT table memory at [mem 0x8d1ed000-0x8d1f7e83]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving TPM2 table memory at [mem 0x8d273000-0x8d27304b]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d1e8000-0x8d1ecded]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d272000-0x8d272040]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving WPBT table memory at [mem 0x8d271000-0x8d271035]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8d270000-0x8d2706d3]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53d000-0x8c53e69d]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c53a000-0x8c53caa5]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c530000-0x8c539a6b]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52d000-0x8c52f8f1]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving WSMT table memory at [mem 0x8d26f000-0x8d26f027]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving APIC table memory at [mem 0x8c52c000-0x8c52c15d]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving IVRS table memory at [mem 0x8c52b000-0x8c52b0c7]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c52a000-0x8c52a4ff]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c529000-0x8c52947b]
Jun 11 10:45:18 truenas kernel: ACPI: Reserving SSDT table memory at [mem 0x8c528000-0x8c52844d]
Jun 11 10:45:18 truenas kernel: Early memory node ranges
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x80c7a000-0x80c7afff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8527f000-0x8b27efff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8b27f000-0x8d27efff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8d27f000-0x8f27efff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x8f27f000-0x9727efff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9727f000-0x973fefff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x99ff7000-0x99ffbfff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9a000000-0x9bffffff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9c000000-0x9d7f2fff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun 11 10:45:18 truenas kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
Jun 11 10:45:18 truenas kernel: Freeing SMP alternatives memory: 40K
Jun 11 10:45:18 truenas kernel: Memory: 31560792K/32595296K available (16384K kernel code, 2483K rwdata, 11552K rodata, 4224K init, 5024K bss, 756260K reserved, 262144K cma-reserved)
Jun 11 10:45:18 truenas kernel: x86/mm: Memory block size: 128MB
Jun 11 10:45:18 truenas kernel: Freeing initrd memory: 76420K
Jun 11 10:45:18 truenas kernel: Freeing unused decrypted memory: 2028K
Jun 11 10:45:18 truenas kernel: Freeing unused kernel image (initmem) memory: 4224K
Jun 11 10:45:18 truenas kernel: Freeing unused kernel image (rodata/data gap) memory: 736K
Jun 11 10:45:18 truenas kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jun 11 10:45:18 truenas kernel: nvme nvme1: allocated 64 MiB host memory buffer.
Jun 11 10:45:18 truenas kernel: mpt3sas_cm0: Allocated physical memory: size(15992 kB)
Jun 11 10:45:19 truenas kernel: amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jun 11 10:45:19 truenas kernel: [drm] amdgpu: 512M of VRAM memory ready
Jun 11 10:45:19 truenas kernel: [drm] amdgpu: 15587M of GTT memory ready.
Jun 11 10:45:52 truenas lxcfs[3578]:   0: fd:   6: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
root@truenas[/var/empty]# grep -i oom /var/log/syslog
root@truenas[/var/empty]# grep -i "killed process" /var/log/syslog
sorry for long post, I do see hardware error. Does this mean ram stick is bad even though it passed memtest?
We’re in experiment mode. If you think you see a bad stick in that log and can isolate it, pull it and see what happens next. While the machine is off, of course. My brain couldn’t parse that wall of text haha.
I won’t be home until this weekend so I will not be able to extended memtest. but could this be faulty mobo? not ram stick?
