no, I have VMs on a RAID-Z1 with HD Sas that manages the Raid and a controller
Hi, I have a fairly similar problem - I wasn’t sure if I should make my own post or not. I’m running ElectricEel-24.10.2 and after upgrading from 23 I haven’t been able to get my P400 to passthrough to the apps I’m running (I’m not running any VMs). Running nvidia-smi shows the P400 (and no processes) and lspci shows “01:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P400] (rev a1)”. I’ve updated the BIOS settings so only the integrated graphics are running (and verified this with a monitor) but lspci still shows the VGA message. I also cannot see the GPU in settings > advanced settings > isolate GPU or in the edit menu of the apps. I have checked the Install Nvidia drivers and rebooted (several times). I also found that there isn’t a /var/log/nvidia-installer.log log file, but that may just have been a AI chatbot hallucination - I’m not really sure that file should have been there.
Update: I’m seeing the option to add the GPU to the app, but nothing in settings > advanced settings > isolate gpus. When I check the box to add the GPU it errors out; I think the error message indicates that the UUID was not passed in the GPU object correctly? I’m not sure. When I click the question mark next the the GPU in the app configuration it provides the correct UUID.
Blockquote Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 509, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 556, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1367, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1364, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 268, in nf
rv = func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 55, in nf
res = f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 183, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 287, in do_update
app = self.update_internal(job, app, data, trigger_compose=app[‘state’] != ‘STOPPED’)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 317, in update_internal
update_app_config(app_name, app[‘version’], new_values, custom_app=app[‘custom_app’])
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py”, line 59, in update_app_config
render_compose_templates(
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py”, line 50, in render_compose_templates
raise CallError(f’Failed to render compose templates: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last):
File “/usr/bin/apps_render_app”, line 33, in
sys.exit(load_entry_point(‘apps-validation==0.1’, ‘console_scripts’, ‘apps_render_app’)())
File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 47, in main
render_templates_from_path(args.path, args.values)
File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 19, in render_templates_from_path
rendered_data = render_templates(
File “/usr/lib/python3/dist-packages/catalog_templating/render.py”, line 36, in render_templates
).render({‘ix_lib’: template_libs, ‘values’: test_values})
File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 1301, in render
self.environment.handle_exception()
File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/docker-compose.yaml”, line 11, in top-level template code
{% set postgres = tpl.deps.postgres(values.consts.pgvecto_container_name, “pgvecto_image”, pg_config, perm_container) %}
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/library/base_v2_1_14/deps.py”, line 26, in postgres
return PostgresContainer(self._render_instance, name, image, config, perms_instance)
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/library/base_v2_1_14/deps_postgres.py”, line 48, in init
c = self._render_instance.add_container(name, image)
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/library/base_v2_1_14/render.py”, line 53, in add_container
container = Container(self, name, image)
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/library/base_v2_1_14/container.py”, line 89, in init
self.deploy: Deploy = Deploy(self._render_instance)
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/library/base_v2_1_14/deploy.py”, line 15, in init
self.resources: Resources = Resources(self._render_instance)
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/library/base_v2_1_14/resources.py”, line 24, in init
self._auto_add_gpus_from_values()
File “/mnt/.ix-apps/app_configs/immich/versions/1.7.26/templates/library/base_v2_1_14/resources.py”, line 55, in _auto_add_gpus_from_values
raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")
base_v2_1_14.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]
Try the workaround noted in the 24.10.0 Known Issues
Thank you so much! That worked perfectly!
