Pool Offline After Every Reboot
Hello im not Linux expert but understand that will be destroyed all my data.
I tried suggestion width export an import what works but is really annoying.
Do they know what is the root cause of the issue?
Option 2 - using the wipefs commands - will not erase your data, when using the -n parameter. This will display if there are any additional filesystem labels (from previously-used disks) that may be interfering with pool mounting.
Here are the Logs from blkid
truenas_admin@truenas[~]$ sudo blkid --probe /dev/sda1
/dev/sda1: UUID=“b29fa450-f494-bc2d-f917-e66c654e69ea” UUID_SUB=“1a157d0c-4913-1601-b64f-d3db93975ba6” LABEL=“truenas:swap1” VERSION=“1.2” TYPE=“linux_raid_member” USAGE=“raid” PART_ENTRY_SCHEME=“gpt” PART_ENTRY_NAME=“data” PART_ENTRY_UUID=“2221560f-91a9-4e9b-807e-8df5fbc0ef10” PART_ENTRY_TYPE=“6a898cc3-1dd2-11b2-99a6-080020736631” PART_ENTRY_NUMBER=“1” PART_ENTRY_OFFSET=“2048” PART_ENTRY_SIZE=“30001852416” PART_ENTRY_DISK=“8:0”
truenas_admin@truenas[~]$ sudo blkid --probe /dev/sdb1
/dev/sdb1: UUID=“2274b232-16b5-8348-c501-5fbdb474bbbe” UUID_SUB=“b2ba7f31-a809-c83b-1faa-5fcdbe4f9b66” LABEL=“truenas:swap0” VERSION=“1.2” TYPE=“linux_raid_member” USAGE=“raid” PART_ENTRY_SCHEME=“gpt” PART_ENTRY_NAME=“data” PART_ENTRY_UUID=“c801a42e-9304-4169-9013-c9ba867041cb” PART_ENTRY_TYPE=“6a898cc3-1dd2-11b2-99a6-080020736631” PART_ENTRY_NUMBER=“1” PART_ENTRY_OFFSET=“2048” PART_ENTRY_SIZE=“30001852416” PART_ENTRY_DISK=“8:16”
truenas_admin@truenas[~]$ sudo blkid --probe /dev/sdc1
/dev/sdc1: UUID=“b29fa450-f494-bc2d-f917-e66c654e69ea” UUID_SUB=“b45c0571-c9c5-669b-1753-04df5a8b065d” LABEL=“truenas:swap1” VERSION=“1.2” TYPE=“linux_raid_member” USAGE=“raid” PART_ENTRY_SCHEME=“gpt” PART_ENTRY_NAME=“data” PART_ENTRY_UUID=“19ca012b-c023-4ff1-936b-a31951418583” PART_ENTRY_TYPE=“6a898cc3-1dd2-11b2-99a6-080020736631” PART_ENTRY_NUMBER=“1” PART_ENTRY_OFFSET=“2048” PART_ENTRY_SIZE=“30001852416” PART_ENTRY_DISK=“8:32”
truenas_admin@truenas[~]$ sudo blkid --probe /dev/sdd1
/dev/sdd1: UUID=“2274b232-16b5-8348-c501-5fbdb474bbbe” UUID_SUB=“8905edb4-88c6-c9d4-778f-91221ca1966a” LABEL=“truenas:swap0” VERSION=“1.2” TYPE=“linux_raid_member” USAGE=“raid” PART_ENTRY_SCHEME=“gpt” PART_ENTRY_NAME=“data” PART_ENTRY_UUID=“23fe06e8-17f3-498e-b042-fe3849a57903” PART_ENTRY_TYPE=“6a898cc3-1dd2-11b2-99a6-080020736631” PART_ENTRY_NUMBER=“1” PART_ENTRY_OFFSET=“2048” PART_ENTRY_SIZE=“30001852416” PART_ENTRY_DISK=“8:48”
truenas_admin@truenas[~]$ sudo blkid --probe /dev/nvme0n1p1
/dev/nvme0n1p1: PART_ENTRY_SCHEME=“gpt” PART_ENTRY_UUID=“80674f7f-7936-4379-b2c9-420985a11329” PART_ENTRY_TYPE=“21686148-6449-6e6f-744e-656564454649” PART_ENTRY_FLAGS=“0x4” PART_ENTRY_NUMBER=“1” PART_ENTRY_OFFSET=“4096” PART_ENTRY_SIZE=“2048” PART_ENTRY_DISK=“259:0”
truenas_admin@truenas[~]$ sudo blkid --probe /dev/nvme0n1p2
/dev/nvme0n1p2: LABEL_FATBOOT=“EFI” LABEL=“EFI” UUID=“A290-88A5” VERSION=“FAT32” BLOCK_SIZE=“512” TYPE=“vfat” USAGE=“filesystem” PART_ENTRY_SCHEME=“gpt” PART_ENTRY_UUID=“1a40d718-4693-470a-8731-2f8693ada95d” PART_ENTRY_TYPE=“c12a7328-f81f-11d2-ba4b-00a0c93ec93b” PART_ENTRY_NUMBER=“2” PART_ENTRY_OFFSET=“6144” PART_ENTRY_SIZE=“1048576” PART_ENTRY_DISK=“259:0”
truenas_admin@truenas[~]$ sudo blkid --probe /dev/nvme0n1p3
/dev/nvme0n1p3: VERSION=“5000” LABEL=“boot-pool” UUID=“13847354830264913250” UUID_SUB=“15545680114051809662” BLOCK_SIZE=“4096” TYPE=“zfs_member” USAGE=“filesystem” PART_ENTRY_SCHEME=“gpt” PART_ENTRY_UUID=“f9eb5e77-8408-4310-aa1b-2096c6e9b844” PART_ENTRY_TYPE=“6a898cc3-1dd2-11b2-99a6-080020736631” PART_ENTRY_NUMBER=“3” PART_ENTRY_OFFSET=“1054720” PART_ENTRY_SIZE=“936648335” PART_ENTRY_DISK=“259:0”
Wha are the commands? you mean use wipefs?
Am I correct that these drives where previously used in a TrueNAS Core system? And then you created a new pool in TrueNAS Scale?
To elaborate the steps for each option in more detail:
Option 1: Recreate the pool
This is useful if you don’t have any data in the pool. This does destroy all data in the pool.
  1. Export the pool in the UI. Do not select the “Destroy data on this pool”. Tick “Confirm Export/Disconnect” checkbox and press “Export/Disconnect”
  2. Go to the disks screen. Click on each disk you want to use in your pool (sda,sdb,sdc,sdd) and press the wipe button, it’s sufficient to select the “quick” method in the dropdown.
  3. After all four disks has been wiped, create the pool as you did initially. You’ll have no more issues rebooting
Option 2: Erase file system marker
This will fix the reboot issue without deleting any data.
Basically you do a careful, targeted wipefs on each partition. Your probe output showed that an old raid signature is detected.
You can first issue the following command to identify file system markers:
  • wipefs --no-act /dev/DISKPART
This should give you an output consisting of mostly zfs_member entries and a single linux_raid_member entry.
**DEVICE                                              OFFSET       TYPE              UUID                                 LABEL
xxx 0x1000       linux_raid_member cf174fb4-6f7b-943b-c217-ec7b7cbbea5c truenas:swap0
xxx 0x3f000      zfs_member        2099482002614675549                  boot-pool
xxx 0x3e000      zfs_member        2099482002614675549                  boot-pool
You’d then proceed by wiping the linux_raid_member signature.
  • wipefs --backup --all -t linux_raid_member /dev/DISKPART
But it is safer if you post the wipefs --no-act .. output here so we can verify that it indeed safe to erase.
Please post output using Preformatted Text (ctrl+e). It looks like (</>) on toolbar
It makes output easier to read
Hello bacon, Thank You.
First time I was thinking the I have HW issue with HBA controller. But after different test and installed Windows Server 2022 was clear the is not the issue. Tired and overwhelming the second day is not possible do simple settings of Truenas Scale was also try Truenas Core but were not possible recognize Broadcom 25 Gbit network interface. So I come back to Truenas Scale (Linux Drivers are here better supported) but stuck widht same issue and suspect correctly that is a bug in SW. Now I try you option 1. Hopefully help to deliver the solution. BTW. Im looking forward to solve issue in next release.
Hello, I experienced the exact same problem as described here. I managed to solve it in a way that did not require to completely recreate the pool, deleting all the files.
Sadly I could not try Option 2 as described by user bacon as both the blkid and wipefs commands gave way to little output to try to manually fix the filesystem issues in my case.
The solution I propose works for a two HDD mirror setup and I cannot guarantee a similar procedure will work for a RAID setup with more disks as well but with the best of my knowledge I think it should also work.
Since I am a new user and cannot post links yet: Here is the title of the discussion on this forum where I posted detailed instructions on how to resolve the issue without having to recreated the pool from scratch: “Have to export/import pool each reboot”.
Thanks for posting this! Strangely, this same pool giving me trouble on boot experienced a disconnect in the middle of the day. Only time it has happened other than boot. Same export / import process “resolved” this too.
I reviewed your post in the other thread and will definitely give it a shot - thanks for laying it out nicely.
Super-helpful post! I encountered the same issue with version 24.10.0.2. Removing and recreating the pool was the only solution that worked for me. However, this approach doesn’t inspire confidence in the product’s reliability. Thankfully, I had a backup, but reliability should be a core feature of any NAS.
我也在 truenas scale 24.10.0.2遇到同樣的問題,
即使我依照 @donnyG 提供的方法設定了我的uefi,
問題依然無法解決,
最後我重新安裝truenas scale 24.04.2.5後這問題就不再出現了。
CPU: i5-4590
MotherBoard: ASUS B85M-PLUS
Storage: 4tb WD red hdd * 4 (Raidz2)
My output is:
sdg    0x200         gpt
sdg    0xcbbbffffe00 gpt
sdg    0x1fe         PMBR
I have 6 disks, all formerly used in a Synology before I created this pool. Any tips?
You need to run the command on the partition. In your case it would be wipefs --no-act /dev/sdg1.
Gotcha, thanks! That output is below. I am guessing I need to remove that ext4 reference, is that correct?
sdg1   0x438         ext4       89dabcc0-2604-49f1-b380-ed22df1291e2 1.42.6-15217
sdg1   0x3f000       zfs_member 6892834326680007410                  Data
sdg1   0x3e000       zfs_member 6892834326680007410                  Data
sdg1   0x3d000       zfs_member 6892834326680007410                  Data
sdg1   0x3c000       zfs_member 6892834326680007410                  Data
sdg1   0x3b000       zfs_member 6892834326680007410                  Data
sdg1   0x3a000       zfs_member 6892834326680007410                  Data
sdg1   0x39000       zfs_member 6892834326680007410                  Data
sdg1   0x38000       zfs_member 6892834326680007410                  Data
sdg1   0x37000       zfs_member 6892834326680007410                  Data
sdg1   0x36000       zfs_member 6892834326680007410                  Data
sdg1   0x35000       zfs_member 6892834326680007410                  Data
sdg1   0x34000       zfs_member 6892834326680007410                  Data
sdg1   0x33000       zfs_member 6892834326680007410                  Data
sdg1   0x32000       zfs_member 6892834326680007410                  Data
sdg1   0x31000       zfs_member 6892834326680007410                  Data
sdg1   0x30000       zfs_member 6892834326680007410                  Data
sdg1   0x2f000       zfs_member 6892834326680007410                  Data
sdg1   0x2e000       zfs_member 6892834326680007410                  Data
sdg1   0x2d000       zfs_member 6892834326680007410                  Data
sdg1   0x2c000       zfs_member 6892834326680007410                  Data
sdg1   0x2b000       zfs_member 6892834326680007410                  Data
sdg1   0x2a000       zfs_member 6892834326680007410                  Data
sdg1   0x29000       zfs_member 6892834326680007410                  Data
sdg1   0x28000       zfs_member 6892834326680007410                  Data
sdg1   0x27000       zfs_member 6892834326680007410                  Data
sdg1   0x26000       zfs_member 6892834326680007410                  Data
sdg1   0x25000       zfs_member 6892834326680007410                  Data
sdg1   0x24000       zfs_member 6892834326680007410                  Data
sdg1   0x23000       zfs_member 6892834326680007410                  Data
sdg1   0x7f000       zfs_member 6892834326680007410                  Data
sdg1   0x7e000       zfs_member 6892834326680007410                  Data
sdg1   0x7d000       zfs_member 6892834326680007410                  Data
sdg1   0x7c000       zfs_member 6892834326680007410                  Data
sdg1   0x7b000       zfs_member 6892834326680007410                  Data
sdg1   0x7a000       zfs_member 6892834326680007410                  Data
sdg1   0x79000       zfs_member 6892834326680007410                  Data
sdg1   0x78000       zfs_member 6892834326680007410                  Data
sdg1   0x77000       zfs_member 6892834326680007410                  Data
sdg1   0x76000       zfs_member 6892834326680007410                  Data
sdg1   0x75000       zfs_member 6892834326680007410                  Data
sdg1   0x74000       zfs_member 6892834326680007410                  Data
sdg1   0x73000       zfs_member 6892834326680007410                  Data
sdg1   0x72000       zfs_member 6892834326680007410                  Data
sdg1   0x71000       zfs_member 6892834326680007410                  Data
sdg1   0x70000       zfs_member 6892834326680007410                  Data
sdg1   0x6f000       zfs_member 6892834326680007410                  Data
sdg1   0x6e000       zfs_member 6892834326680007410                  Data
sdg1   0x6d000       zfs_member 6892834326680007410                  Data
sdg1   0x6c000       zfs_member 6892834326680007410                  Data
sdg1   0x6b000       zfs_member 6892834326680007410                  Data
sdg1   0x6a000       zfs_member 6892834326680007410                  Data
sdg1   0x69000       zfs_member 6892834326680007410                  Data
sdg1   0x68000       zfs_member 6892834326680007410                  Data
sdg1   0x67000       zfs_member 6892834326680007410                  Data
sdg1   0x66000       zfs_member 6892834326680007410                  Data
sdg1   0x65000       zfs_member 6892834326680007410                  Data
sdg1   0x64000       zfs_member 6892834326680007410                  Data
sdg1   0x63000       zfs_member 6892834326680007410                  Data
sdg1   0x62000       zfs_member 6892834326680007410                  Data
sdg1   0x61000       zfs_member 6892834326680007410                  Data
sdg1   0x60000       zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdbf000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdbe000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdbd000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdbc000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdbb000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdba000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb9000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb8000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb7000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb6000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb5000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb4000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb3000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb2000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb1000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdb0000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdaf000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdae000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdad000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdac000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdab000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdaa000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda9000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda8000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda7000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda6000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda5000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda4000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda3000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda2000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda1000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfda0000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdff000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdfe000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdfd000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdfc000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdfb000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdfa000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf9000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf8000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf7000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf6000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf5000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf4000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf3000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf2000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf1000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdf0000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdef000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdee000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfded000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdec000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdeb000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfdea000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde9000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde8000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde7000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde6000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde5000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde4000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde3000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde2000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde1000 zfs_member 6892834326680007410                  Data
sdg1   0xcbbbfde0000 zfs_member 6892834326680007410                  Data
Correct. Command to wipe would be:
  • wipefs --all --backup -t ext4 /dev/sdg1.
Repeat the same for the other drives.
Thanks that did it! Pool is online and good after rebooting now.
For the benefit of others, I ran the above command with --no-act first to check what it would do before it did it. Also, you need to export/disconnect the pool before running the command.
Hi Bacon,
I have the excat same issue. I managed to do the “wipefs --no-act” command but i’m unsure which file system markers are the cause for the problem. My config:
NVMe-Mirror (1 TB - BrandNew) Data-Storage
HDD-Mirror (8 TB - Transfered from Synology DS218J) Data-Storage
BootDisk (SSD) (3 Partitions - Boot installation on Part1)
I can’t identify which file system markers on which partitions had to be wiped in order to function correctly. I’m not a native linux shell user and feel unsecure in using commands I don’t “understand”.
Either the WD Red or the Boot-SSD must be wiped. The NVMe Disks were brand-new on installation. I need some advice, i don’t want to destroy the pool/vdev.
Please post the output.
Of which sda or NVMe disk exactly?
I figured that you wanted help interpreting the result of the wipefs command, if so, you need to post the result here so we can see it.
