Tips for Rackmount TrueNAS build
If you are in the EU I found this reseller in Poland who stocks every conceivable Supermicro part, apparently.
I had ordered a mainboard and chassis combination through our regular German channels (Jacob, Mindfactory, …) only to find I needed some special brackets to mount the case fans, the case did not include the PCIe riser to mount a card horizontally, and Supermicro recommended an “air shroud” (a piece of plastic, but tailored for the chassis) for proper air flow over the passive CPU cooler.
That Polish shop could sell me all the parts. Only alternative I was able to find would have been eBay sellers in the US. 10$ in parts, 70$ for UPS shipping :roll_eyes:
HTH, Patrick
CORE has been forked, https://zvault.io, and there is on-going work on the fork. I’ve got a VM running the Latest release, it looks promising.
Communication wise the project looks dead to me. I sent an email to the single person behind the github repo from EuroBSDCon Zagreb and have not received a response. They also have not got into contact with the FreeBSD Foundation, so far.
I’ll put my bets on FreeBSD Foundation sponsored Sylve instead.
But in the end it all depends on what you expect from a NAS. I started my FreeNAS journey precisely because it could run jails. I need a hyperconverged platform that supports
  • ZFS
  • VMs
  • jails - FreeBSD jails, anything else doesn’t count
So while I do run a dedicated server with TrueNAS CE for all those strictly Docker based applications, no way I am going to move my CORE systems to CE.
Kind regards,
Patrick
P.S. Because you mentioned the “latest release” - well, that’s from early May this year. No visible progress whatsoever since then.
I built this 14U rack out of plywood, I stained and finished it to meet my wife’s requirements that it look somewhat nice :slight_smile: The bottom 4U is my TrueNAS Scale machine. The 2U’s above are Proxmox machines. Networking gear above and the top 1U is my Opnsense firewall/router.
Looks nice, does yours also live in a corner of your living room? :sweat_smile:
No, the basement family room :slight_smile:
That’s an awesome dual-use room heater!!! :rofl:
Yup, it helps in the winter :slight_smile:
Actually though, it doesn’t use a lot of power. On the back I have a 1U power strip that provides power to everything and I have the power strip plugged into a PN2500 power monitor. With everything running, the rack only pulls about 300 watts. A few years ago, I had Solar installed on my house with a PowerWall and the circuit that the rack is on is on the critical circuits panel of the PowerWall which is programmed to power my house in the evening until it gets to 50% of charge. I like to reserve power for outages. The PowerWall acts as my UPS as well. So, with the Solar and my battery backup, my Grid Electric bill is quite low, this past August with all the sunlight, I got an electric bill of $20.00
While we benefit from net metering here, my neighbors also have a lot of tall trees. Usually, it’s early summer, late spring that our bills come out to practically zero. Overall, we’re covering about 1/2 of our annual bill here. Still, I continue to look for ways to reduce constant loads, and the network is one of them.
