Here are the smartctl -x for the 4 drives.
First Disk
sda
root@HomeServer[~]# smartctl -x /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.32-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFZX-68AWUN0
Serial Number: WD-WX22DC1RNK8N
LU WWN Device Id: 5 0014ee 2bfab56ec
Firmware Version: 81.00B81
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Nov 23 01:13:41 2024 CET
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (42600) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
Self-test supported.
No Selective Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 452) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 241 221 021 - 2950
4 Start_Stop_Count -O--CK 100 100 000 - 65
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 072 072 000 - 20879
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 64
192 Power-Off_Retract_Count -O--CK 200 200 000 - 33
193 Load_Cycle_Count -O--CK 200 200 000 - 69
194 Temperature_Celsius -O---K 119 093 000 - 31
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 1
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb6 GPL,SL VS 1 Device vendor specific log
0xb7 GPL,SL VS 78 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 4
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 4 [3] occurred at disk power-on lifetime: 16244 hours (676 days + 20 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 80 00 00 a3 a4 35 da 40 00 Error: UNC at LBA = 0xa3a435da = 2745447898
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 58 00 68 00 00 a3 a4 40 d8 40 08 00:13:34.700 READ FPDMA QUEUED
60 03 18 00 60 00 00 a3 a4 3d c0 40 08 00:13:34.700 READ FPDMA QUEUED
60 07 e8 00 40 00 00 a3 a4 35 d8 40 08 00:13:34.700 READ FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 a0 08 00:13:34.676 FLUSH CACHE EXT
60 02 68 00 20 00 00 a3 a4 33 70 40 08 00:13:34.666 READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 7728 hours (322 days + 0 hours)
10 -- 51 00 00 00 01 af dd cc 48 40 00 Error: IDNF at LBA = 0x1afddcc48 = 7245515848
61 00 08 00 b0 00 01 ba 46 a4 d8 40 08 31d+14:23:48.066 WRITE FPDMA QUEUED
61 00 08 00 38 00 01 af dd cc 48 40 08 31d+14:23:48.066 WRITE FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 a0 08 31d+14:23:43.369 FLUSH CACHE EXT
61 00 08 00 30 00 01 d1 c0 bd 98 40 08 31d+14:23:43.368 WRITE FPDMA QUEUED
61 00 08 00 28 00 01 d1 c0 bb 98 40 08 31d+14:23:43.368 WRITE FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 7727 hours (321 days + 23 hours)
10 -- 51 00 00 00 01 ba 43 89 c0 40 00 Error: IDNF at LBA = 0x1ba4389c0 = 7419955648
61 00 08 00 98 00 01 b7 0e 59 18 40 08 31d+13:32:41.695 WRITE FPDMA QUEUED
61 00 08 00 20 00 01 ba 43 89 c0 40 08 31d+13:32:41.695 WRITE FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 a0 08 31d+13:32:37.191 FLUSH CACHE EXT
61 00 08 00 80 00 01 d1 c0 bd e8 40 08 31d+13:32:37.191 WRITE FPDMA QUEUED
61 00 08 00 78 00 01 d1 c0 bb e8 40 08 31d+13:32:37.191 WRITE FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 3998 hours (166 days + 14 hours)
10 -- 51 00 00 00 01 c6 c1 a1 98 40 00 Error: IDNF at LBA = 0x1c6c1a198 = 7629545880
61 00 10 00 28 00 01 c6 c1 a1 98 40 08 4d+21:32:31.932 WRITE FPDMA QUEUED
61 00 10 00 e0 00 01 c6 43 6a c8 40 08 4d+21:32:31.932 WRITE FPDMA QUEUED
61 00 10 00 d8 00 01 c6 42 a6 68 40 08 4d+21:32:31.932 WRITE FPDMA QUEUED
61 00 08 00 20 00 01 c5 c3 72 00 40 08 4d+21:32:31.932 WRITE FPDMA QUEUED
61 00 08 00 18 00 01 c0 44 4f 60 40 08 4d+21:32:31.932 WRITE FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Extended offline Completed without error 00% 20830 -
# 2 Short offline Completed without error 00% 20821 -
# 3 Short offline Completed without error 00% 20820 -
# 4 Extended offline Completed without error 00% 16260 -
# 5 Short offline Completed without error 00% 16201 -
# 6 Short offline Completed without error 00% 579 -
Selective Self-tests/Logging not supported
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 31 Celsius
Power Cycle Min/Max Temperature: 20/37 Celsius
Lifetime Min/Max Temperature: 18/57 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/65 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (399)
Index Estimated Time Temperature Celsius
400 2024-11-22 17:16 31 ************
... ..( 47 skipped). .. ************
448 2024-11-22 18:04 31 ************
449 2024-11-22 18:05 32 *************
... ..(173 skipped). .. *************
145 2024-11-22 20:59 32 *************
146 2024-11-22 21:00 33 **************
147 2024-11-22 21:01 32 *************
... ..( 22 skipped). .. *************
170 2024-11-22 21:24 32 *************
171 2024-11-22 21:25 33 **************
... ..( 3 skipped). .. **************
175 2024-11-22 21:29 33 **************
176 2024-11-22 21:30 32 *************
177 2024-11-22 21:31 32 *************
178 2024-11-22 21:32 33 **************
... ..( 10 skipped). .. **************
189 2024-11-22 21:43 33 **************
190 2024-11-22 21:44 32 *************
191 2024-11-22 21:45 32 *************
192 2024-11-22 21:46 33 **************
193 2024-11-22 21:47 32 *************
194 2024-11-22 21:48 32 *************
195 2024-11-22 21:49 32 *************
196 2024-11-22 21:50 33 **************
197 2024-11-22 21:51 33 **************
198 2024-11-22 21:52 32 *************
... ..(155 skipped). .. *************
354 2024-11-23 00:28 32 *************
355 2024-11-23 00:29 31 ************
... ..( 4 skipped). .. ************
360 2024-11-23 00:34 31 ************
361 2024-11-23 00:35 32 *************
362 2024-11-23 00:36 31 ************
... ..( 36 skipped). .. ************
399 2024-11-23 01:13 31 ************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 64 --- Lifetime Power-On Resets
0x01 0x010 4 20879 --- Power-on Hours
0x01 0x018 6 34560115016 --- Logical Sectors Written
0x01 0x020 6 1620968669 --- Number of Write Commands
0x01 0x028 6 72299307123 --- Logical Sectors Read
0x01 0x030 6 161249870 --- Number of Read Commands
0x01 0x038 6 2149955968 --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 20754 --- Spindle Motor Power-on Hours
0x03 0x010 4 20739 --- Head Flying Hours
0x03 0x018 4 103 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 1 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 33 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 4 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 31 --- Current Temperature
0x05 0x010 1 31 --- Average Short Term Temperature
0x05 0x018 1 32 --- Average Long Term Temperature
0x05 0x020 1 57 --- Highest Temperature
0x05 0x028 1 23 --- Lowest Temperature
0x05 0x030 1 53 --- Highest Average Short Term Temperature
0x05 0x038 1 30 --- Lowest Average Short Term Temperature
0x05 0x040 1 48 --- Highest Average Long Term Temperature
0x05 0x048 1 32 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 65 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 418 --- Number of Hardware Resets
0x06 0x010 4 199 --- Number of ASR Events
0x06 0x018 4 1 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 8 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 10 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 212637 Vendor specific
Second Disk
sdb
root@HomeServer[~]# smartctl -x /dev/sdb
Serial Number: WD-WX22DC1RND3T
LU WWN Device Id: 5 0014ee 26a5555e1
Local Time is: Sat Nov 23 01:16:23 2024 CET
was never started.
been run.
command.
power-saving mode.
3 Spin_Up_Time POS--K 245 221 021 - 2725
4 Start_Stop_Count -O--CK 100 100 000 - 59
9 Power_On_Hours -O--CK 072 072 000 - 20872
12 Power_Cycle_Count -O--CK 100 100 000 - 58
192 Power-Off_Retract_Count -O--CK 200 200 000 - 27
193 Load_Cycle_Count -O--CK 200 200 000 - 64
194 Temperature_Celsius -O---K 118 094 000 - 32
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
Device Error Count: 3
ER = Error register
Error 3 [2] occurred at disk power-on lifetime: 16237 hours (676 days + 13 hours)
40 -- 51 00 80 00 00 a3 a4 27 1a 40 00 Error: UNC at LBA = 0xa3a4271a = 2745444122
60 07 e8 00 e8 00 00 a3 a4 31 b8 40 08 00:13:34.928 READ FPDMA QUEUED
60 07 e8 00 18 00 00 a3 a4 29 d0 40 08 00:13:34.927 READ FPDMA QUEUED
60 07 e8 00 10 00 00 a3 a4 21 e8 40 08 00:13:34.924 READ FPDMA QUEUED
60 07 e8 00 e0 00 00 a3 a4 1a 00 40 08 00:13:34.924 READ FPDMA QUEUED
60 07 e8 00 38 00 00 a3 a4 0a 30 40 08 00:13:34.916 READ FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 7720 hours (321 days + 16 hours)
10 -- 51 00 00 00 01 ba 47 08 c8 40 00 Error: IDNF at LBA = 0x1ba4708c8 = 7420184776
61 00 08 00 70 00 01 b0 74 bb 18 40 08 31d+14:30:19.613 WRITE FPDMA QUEUED
61 00 08 00 68 00 01 ba 47 08 c8 40 08 31d+14:30:19.613 WRITE FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 a0 08 31d+14:30:16.568 FLUSH CACHE EXT
61 00 08 00 48 00 01 d1 c0 be 08 40 08 31d+14:30:16.566 WRITE FPDMA QUEUED
61 00 08 00 40 00 01 d1 c0 bc 08 40 08 31d+14:30:16.566 WRITE FPDMA QUEUED
10 -- 51 00 00 00 01 c7 c0 dd 18 40 00 Error: IDNF at LBA = 0x1c7c0dd18 = 7646272792
61 00 08 00 90 00 01 c7 c0 dd 18 40 08 4d+21:32:30.434 WRITE FPDMA QUEUED
61 00 08 00 68 00 01 c7 45 0f 48 40 08 4d+21:32:30.434 WRITE FPDMA QUEUED
61 00 10 00 88 00 01 c6 c2 61 50 40 08 4d+21:32:30.434 WRITE FPDMA QUEUED
61 00 10 00 e0 00 01 c6 43 6a c8 40 08 4d+21:32:30.434 WRITE FPDMA QUEUED
61 00 10 00 40 00 01 c9 46 97 10 40 08 4d+21:32:30.434 WRITE FPDMA QUEUED
# 1 Extended offline Completed without error 00% 20831 -
# 2 Short offline Completed without error 00% 20815 -
# 3 Extended offline Interrupted (host reset) 90% 16240 -
# 4 Short offline Completed without error 00% 16194 -
# 5 Short offline Completed without error 00% 579 -
Current Temperature: 33 Celsius
Power Cycle Min/Max Temperature: 20/36 Celsius
Lifetime Min/Max Temperature: 18/56 Celsius
Vendor specific:
Temperature History Size (Index): 478 (460)
461 2024-11-22 17:19 32 *************
... ..( 29 skipped). .. *************
13 2024-11-22 17:49 32 *************
14 2024-11-22 17:50 33 **************
... ..(190 skipped). .. **************
205 2024-11-22 21:01 33 **************
206 2024-11-22 21:02 34 ***************
... ..( 8 skipped). .. ***************
215 2024-11-22 21:11 34 ***************
216 2024-11-22 21:12 33 **************
217 2024-11-22 21:13 34 ***************
... ..( 30 skipped). .. ***************
248 2024-11-22 21:44 34 ***************
249 2024-11-22 21:45 33 **************
250 2024-11-22 21:46 34 ***************
... ..( 10 skipped). .. ***************
261 2024-11-22 21:57 34 ***************
262 2024-11-22 21:58 33 **************
263 2024-11-22 21:59 33 **************
264 2024-11-22 22:00 34 ***************
265 2024-11-22 22:01 34 ***************
266 2024-11-22 22:02 34 ***************
267 2024-11-22 22:03 33 **************
... ..(163 skipped). .. **************
431 2024-11-23 00:47 33 **************
432 2024-11-23 00:48 32 *************
433 2024-11-23 00:49 33 **************
434 2024-11-23 00:50 32 *************
438 2024-11-23 00:54 32 *************
439 2024-11-23 00:55 33 **************
440 2024-11-23 00:56 33 **************
441 2024-11-23 00:57 32 *************
442 2024-11-23 00:58 33 **************
443 2024-11-23 00:59 33 **************
444 2024-11-23 01:00 32 *************
445 2024-11-23 01:01 33 **************
446 2024-11-23 01:02 32 *************
447 2024-11-23 01:03 32 *************
448 2024-11-23 01:04 33 **************
... ..( 5 skipped). .. **************
454 2024-11-23 01:10 33 **************
455 2024-11-23 01:11 32 *************
... ..( 4 skipped). .. *************
460 2024-11-23 01:16 32 *************
0x01 0x008 4 58 --- Lifetime Power-On Resets
0x01 0x010 4 20872 --- Power-on Hours
0x01 0x018 6 34690364214 --- Logical Sectors Written
0x01 0x020 6 1619211431 --- Number of Write Commands
0x01 0x028 6 72302221588 --- Logical Sectors Read
0x01 0x030 6 162749786 --- Number of Read Commands
0x01 0x038 6 2124755968 --- Date and Time TimeStamp
0x03 0x008 4 20748 --- Spindle Motor Power-on Hours
0x03 0x010 4 20741 --- Head Flying Hours
0x03 0x018 4 92 --- Head Load Events
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x040 4 27 --- Number of High Priority Unload Events
0x04 0x008 4 3 --- Number of Reported Uncorrectable Errors
0x05 0x008 1 32 --- Current Temperature
0x05 0x010 1 32 --- Average Short Term Temperature
0x05 0x018 1 34 --- Average Long Term Temperature
0x05 0x020 1 56 --- Highest Temperature
0x05 0x030 1 52 --- Highest Average Short Term Temperature
0x05 0x048 1 34 --- Lowest Average Long Term Temperature
0x06 0x008 4 411 --- Number of Hardware Resets
||__ D supports DSN
0x8000 4 212799 Vendor specific
Third Disk
sdc
root@HomeServer[~]# smartctl -x /dev/sdc
Serial Number: WD-WX22DC1RNZ4D
LU WWN Device Id: 5 0014ee 215002892
Local Time is: Sat Nov 23 01:21:18 2024 CET
was never started.
been run.
data collection: (42900) seconds.
command.
power-saving mode.
recommended polling time: ( 455) minutes.
3 Spin_Up_Time POS--K 233 223 021 - 3308
9 Power_On_Hours -O--CK 072 072 000 - 20833
192 Power-Off_Retract_Count -O--CK 200 200 000 - 26
193 Load_Cycle_Count -O--CK 200 200 000 - 72
194 Temperature_Celsius -O---K 117 095 000 - 33
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 2
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
Device Error Count: 1
ER = Error register
10 -- 51 00 00 00 01 c6 43 6a c8 40 00 Error: IDNF at LBA = 0x1c6436ac8 = 7621274312
61 00 10 00 40 00 01 c6 43 6a c8 40 08 4d+21:32:29.436 WRITE FPDMA QUEUED
61 00 10 00 38 00 01 c6 42 a6 68 40 08 4d+21:32:29.436 WRITE FPDMA QUEUED
61 00 08 00 30 00 01 c5 c3 72 00 40 08 4d+21:32:29.436 WRITE FPDMA QUEUED
61 00 08 00 80 00 01 c0 44 4f 60 40 08 4d+21:32:29.436 WRITE FPDMA QUEUED
61 00 10 00 78 00 01 c9 46 97 08 40 08 4d+21:32:29.436 WRITE FPDMA QUEUED
# 1 Extended offline Completed without error 00% 20801 -
# 2 Short offline Completed without error 00% 20775 -
# 3 Short offline Completed without error 00% 16149 -
# 4 Short offline Completed without error 00% 15715 -
# 5 Short offline Completed without error 00% 6351 -
Lifetime Min/Max Temperature: 18/55 Celsius
Vendor specific:
Temperature History Size (Index): 478 (22)
23 2024-11-22 17:24 33 **************
... ..( 74 skipped). .. **************
98 2024-11-22 18:39 33 **************
99 2024-11-22 18:40 34 ***************
... ..( 3 skipped). .. ***************
103 2024-11-22 18:44 34 ***************
104 2024-11-22 18:45 33 **************
110 2024-11-22 18:51 33 **************
111 2024-11-22 18:52 34 ***************
... ..(278 skipped). .. ***************
390 2024-11-22 23:31 34 ***************
391 2024-11-22 23:32 33 **************
... ..(108 skipped). .. **************
22 2024-11-23 01:21 33 **************
0x01 0x010 4 20833 --- Power-on Hours
0x01 0x018 6 33650421625 --- Logical Sectors Written
0x01 0x020 6 1579500897 --- Number of Write Commands
0x01 0x028 6 70096659113 --- Logical Sectors Read
0x01 0x030 6 156581257 --- Number of Read Commands
0x01 0x038 6 1984355968 --- Date and Time TimeStamp
0x03 0x008 4 20707 --- Spindle Motor Power-on Hours
0x03 0x010 4 20692 --- Head Flying Hours
0x03 0x018 4 99 --- Head Load Events
0x03 0x040 4 26 --- Number of High Priority Unload Events
0x04 0x008 4 1 --- Number of Reported Uncorrectable Errors
0x05 0x008 1 33 --- Current Temperature
0x05 0x020 1 55 --- Highest Temperature
0x05 0x038 1 31 --- Lowest Average Short Term Temperature
0x06 0x008 4 412 --- Number of Hardware Resets
0x06 0x010 4 198 --- Number of ASR Events
0x06 0x018 4 2 --- Number of Interface CRC Errors
||__ D supports DSN
0x8000 4 213096 Vendor specific
root@HomeServer[~]#
Forth Disk
Summary
root@HomeServer[~]# smartctl -x /dev/sdd
Serial Number: WD-WX22DC1DL4D6
LU WWN Device Id: 5 0014ee 2bfab52f8
Local Time is: Sat Nov 23 01:23:22 2024 CET
was never started.
been run.
command.
power-saving mode.
3 Spin_Up_Time POS--K 232 221 021 - 3391
4 Start_Stop_Count -O--CK 100 100 000 - 58
9 Power_On_Hours -O--CK 072 072 000 - 20882
12 Power_Cycle_Count -O--CK 100 100 000 - 57
192 Power-Off_Retract_Count -O--CK 200 200 000 - 25
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
ER = Error register
Error 1 [0] occurred at disk power-on lifetime: 15719 hours (654 days + 23 hours)
40 -- 51 00 00 00 00 94 16 97 b8 40 00 Error: UNC at LBA = 0x941697b8 = 2484508600
60 00 20 00 a8 00 01 c5 40 99 b0 40 08 8d+10:07:02.787 READ FPDMA QUEUED
61 00 08 00 a0 00 01 bf 2e c8 00 40 08 8d+10:07:02.293 WRITE FPDMA QUEUED
61 00 08 00 98 00 01 cb 1d 0d 48 40 08 8d+10:07:02.293 WRITE FPDMA QUEUED
60 00 38 00 90 00 01 08 cd b1 28 40 08 8d+10:06:59.378 READ FPDMA QUEUED
60 00 38 00 08 00 01 98 40 7f 08 40 08 8d+10:06:59.250 READ FPDMA QUEUED
# 1 Extended offline Completed without error 00% 20859 -
# 2 Short offline Completed without error 00% 20824 -
# 3 Short offline Completed without error 00% 16197 -
# 4 Short offline Completed without error 00% 4293 -
Vendor specific:
Temperature History Size (Index): 478 (53)
54 2024-11-22 17:26 32 *************
... ..( 20 skipped). .. *************
75 2024-11-22 17:47 32 *************
76 2024-11-22 17:48 33 **************
... ..(194 skipped). .. **************
271 2024-11-22 21:03 33 **************
272 2024-11-22 21:04 34 ***************
... ..( 75 skipped). .. ***************
348 2024-11-22 22:20 34 ***************
349 2024-11-22 22:21 33 **************
... ..(175 skipped). .. **************
47 2024-11-23 01:17 33 **************
48 2024-11-23 01:18 32 *************
53 2024-11-23 01:23 32 *************
0x01 0x008 4 57 --- Lifetime Power-On Resets
0x01 0x010 4 20882 --- Power-on Hours
0x01 0x018 6 33855739859 --- Logical Sectors Written
0x01 0x020 6 1586265262 --- Number of Write Commands
0x01 0x028 6 71588762464 --- Logical Sectors Read
0x01 0x030 6 166367554 --- Number of Read Commands
0x01 0x038 6 2160755968 --- Date and Time TimeStamp
0x03 0x008 4 20755 --- Spindle Motor Power-on Hours
0x03 0x010 4 20740 --- Head Flying Hours
0x03 0x018 4 98 --- Head Load Events
0x03 0x028 4 5 --- Read Recovery Attempts
0x03 0x040 4 25 --- Number of High Priority Unload Events
0x05 0x038 1 32 --- Lowest Average Short Term Temperature
0x05 0x040 1 47 --- Highest Average Long Term Temperature
0x06 0x008 4 413 --- Number of Hardware Resets
||__ D supports DSN
0x8000 4 213223 Vendor specific
