25.04.0 VM Permission Issue
Hello, hope someone can help me.
I want to import my vm to instances but it dont work.
I have following issue after create the instances
WARNING: Your user does not have sudo privileges so /usr/bin/incus command will run
on your behalf. This might cause permission issues.
Error: mkdir /var/empty/.config: operation not permitted
i have the same issue with a new instances, i dont know whats wrong
Is this being presented in the UI or are you running incus commands via shell? Note that this isn’t a permissions issue, it’s a “your user account has its homedir set to our default immutable directory” issue.
via shell on truenas gui, how it works to work with a normal account ?
Shell in truenas GUI is still shell and changes via that mechanism still are subject to the MOTD warning.
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI, CLI, and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
