I get it when I go to Storage/Disks/ Edit drive and without doing anything get out. Then the GUI hangs for a few minutes.
Python stack trace
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 246, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 111, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 985, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 87, in query
pools = [i.__getstate__(**state_kwargs) for i in zfs.pools]
File "libzfs.pyx", line 402, in libzfs.ZFS.__exit__
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 87, in <listcomp>
File "libzfs.pyx", line 2489, in libzfs.ZFSPool.__getstate__
File "libzfs.pyx", line 2693, in libzfs.ZFSPool.healthy.__get__
File "libzfs.pyx", line 2675, in libzfs.ZFSPool.status_code.__get__
File "/usr/local/lib/python3.9/enum.py", line 384, in __call__
return cls.__new__(cls, value)
File "/usr/local/lib/python3.9/enum.py", line 702, in __new__
raise ve_exc
ValueError: 30 is not a valid PoolStatus
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 139, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1240, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk.py", line 89, in query
return await super().query(filters, options)
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 483, in query
result = await self.middleware.call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1283, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 164, in query
result = await self._queryset_serialize(
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 208, in _queryset_serialize
extend_context_value = await self.middleware.call(extend_context, extra_options)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk.py", line 136, in disk_extend_context
for pool in await self.middleware.call('zfs.pool.query'):
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1248, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1254, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1173, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1156, in run_in_executor
EDIT: The above is also in middleware.log and is preceded by
(ERROR) EtcService.generate():436 - Failed to render py:ctld
