80 TB storage solution
we may have to build a storgae solution that holds about 80TB of data - which means we would have to be able to install 240TB of storage capacity in order to have acceptable redundancy.
I’ve never come accross any motherboard where I could install more than 12 drives and even those are too small.
I would love to build this system myself with TrueNAS, but I’m a bit afraid I’m getting too far out of my abilities here.
Looking at some of the commercial cloud storage providers who offer storage at $7 per TB/month this would mean 7*80 = $540 per month (!) for the storage. This is definitely and very much out of our price range.
Or am I better off segementing the data on “cheap” 10 year old hardware (like those office PCs with Core i5 or similar processors and a couple of SATA ports each) each running a TrueNAS instance with 3 or 4 harddrives in them?
I’m at a bit of a loss here, as you can tell.
Perhaps someone can point me to some reading up on creating storage in this capacity range on a budget.
Welcome!
What probably you will need, Is not setup more different system, but a good server grade motherboard where place 1 or more HBA, according to your need of disks.
Certainly not; you’d need a disk controller.[1] A LSI/Broadcom/Avago SAS HBA is what you want, probably in the 9300 series. Combine that with SAS expanders (probably in the backplane of your chassis) and you can manage a practically-unlimited number of disks. See:
  1. Well, not “need.” 12 x 20 TB drives gets you the 240 TB you mention. ↩︎
The TrueNAS R Series line scales quite well and is very affordable TrueNAS R-Series with OpenZFS: Scale-Up & Out Storage
Using triple mirrors?
Is there a reason that RaidZ2 doesn’t get you the redundancy you need? Or maybe draid.
RAID is not a backup.
I mean the mirrors make sense if you’re reading/writing to the pool, but instead of triple mirroring you could use RaidZ3 have more redundancy and use less disks.
Perhaps allowing backup too.
Anywho, maybe you know exactly what you need
But then you’d know you need to use a SAS HBA :wink:
Thank you. I will read up on SAS.
This would be purely an archive system - We would archive new projects to that storage about 5 to 6 times a year (roughly 500GB per project) and retrieve material from old projects probably with the same frequency. Transfer speed is not that crucial, because we access the data so little that we can wait a bit. Stability and reliability are more important.
We are not working off of these drives, our working drives are attached directly to our workstations (music production).
I thought for data to be relatively safe it needs to exist 3 times hence the idea of 4 X of 3 20TB drives (each triplet of drives mirroring) to achieve 80TB of usable storage space - so we could lose 2 drives of a triplet and still be relatively safe. But perhaps I’m not understanding modern storage concepts (zfs) correctly in that way… I may be stuck in the old way of me wanting to understand on which drive a specific file actually sits…
4 x 3-way mirrors would indeed roughly give you 80TB of space but here’s another idea.
2 x 6 disk Z2 would roughly give you 160TB with the same protection level per vdev.
Or how about
12 disk Z3 giving you roughly 200TB with a greater protection level per vdev.
Simply from a safety point of view option 2 is the best but if you’re trying to get the most bang for your buck with no plans to increase the system (unless in 12 disk chunks) then option 3 looks decent.
Or alternatively,
One system and a backup for a proper 3 2 1 backup
Indeed. No RAID config replaces a backup.
I would recommend RaidZ2 for availability, and another pool/system with RaidZ2 as an online backup
6-way raidz2 would do it, as mentioned.
But the question is, did you just want to buy 6 disks instead of 12? Or do you want more space?
If more space? Do you want a lot more space?
Another nice thing with the the 6-way raidz2 is you could start with 6 disks and add another 6 later.
Or add individual disks.
Lots of options.
Mirrors like you suggested is normally used for performance. Or when serving block storage for VMs.
Thank you everybody for taking the time.
My main takeaway and something that I really did not fully understand before being pointed to it is: raid is not a backup.
“Fortunately” during this research a colleagues raid system (directly attached storage) died during this time so I saw firsthand what it means.
So thank you.
I haven’t decided on a solution yet, but I think we’re just going with several 20TB drives (2 sets in one location and 1 set in the other location) and refresh those every 2 or 3 years or so…
