905P Optane Not Showing on Older MB (X8DT6-F)
I’m trying to get two 1.5TB 905p Optane SSDs working as data disks in TrueNAS Scale. I suspect my issue is due to my older motherboard. I can’t find anyone commenting on using these with a Tylersburg chipset.
Would love any tips from this community. Figured worst case this might help someone else trying to mix new with old.
TrueNAS version: Dragonfish-24.04.2
Motherboard: X8DT6-F
RAM: 12x16GB DDR3 1333MT/S ECC
CPU: 2x Intel X5690
NIC: Intel X540-2 10gbps (only 1 NIC in use) in PCIe slot 7
Disks currently recognized include 4x patriot burst elite SSDs, 20 4TB enterprise HDDs [10 WD40EFRX, 6 WD40EZRX, and a 4 other miscellaneous), and 2 500gb HDDs I don’t plan to use which were buried in the chassis by the prior owner and aren’t worth trying to remove.
Chassis is a Supermicro 847 with 36 drive bays (24 front, 12 rear).
Controllers: 9211-8i in PCIe Slot 5, currently running version 20 IT mode. Front and rear backplanes are connected to this controller.
The Motherboard’s built-in SAS controller is on version 7, non-IT mode and as far as I can tell is not in use(?)
Current Status:
No indication in BIOS that the 905p are seen. This is an older BIOS though so I’m not sure it would tell me anyways. Of course, no sign of them in TrueNAS Scale either.
What I’ve Tried:
  • Updated BIOS to latest version 2.2 published 7/9/2018
  • Disabled OPROM on all PCIe slots except slot 5 (it is required by the HBA)
  • Set SATA Controller to AHCI (originally IDE).
  • Set ACPI to v3.0 (from v2.0)
  • Booted to live Ubuntu 24.04 via USB. Tried to find disk with GParted, unsuccessfully.
lspci and fdisk -l results do not indicate the 905p and are copied below for reference.
To connect the 905p SSDs, I used this adaptor cable
to this PCIe adaptor card to the motherboard PCIe slots 6 and 3 as labeled on the motherboard manual.
I do not have anything plugged into the SATA power portion of the adaptor cable. My understanding is that these SSDs should draw sufficient power from the PCIe slot.
LSPCI Results:
00:00.0 Host bridge: Intel Corporation 5520 I/O Hub to ESI Port (rev 22)
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 22)
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 22)
00:05.0 PCI bridge: Intel Corporation 5520/X58 I/O Hub PCI Express Root Port 5 (rev 22)
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 22)
00:09.0 PCI bridge: Intel Corporation 7500/5520/5500/X58 I/O Hub PCI Express Root Port 9 (rev 22)
00:0d.0 Host bridge: Intel Corporation Device 343a (rev 22)
00:0d.1 Host bridge: Intel Corporation Device 343b (rev 22)
00:0d.2 Host bridge: Intel Corporation Device 343c (rev 22)
00:0d.3 Host bridge: Intel Corporation Device 343d (rev 22)
00:0d.4 Host bridge: Intel Corporation 7500/5520/5500/X58 Physical Layer Port 0 (rev 22)
00:0d.5 Host bridge: Intel Corporation 7500/5520/5500 Physical Layer Port 1 (rev 22)
00:0d.6 Host bridge: Intel Corporation Device 341a (rev 22)
00:0e.0 Host bridge: Intel Corporation Device 341c (rev 22)
00:0e.1 Host bridge: Intel Corporation Device 341d (rev 22)
00:0e.2 Host bridge: Intel Corporation Device 341e (rev 22)
00:0e.4 Host bridge: Intel Corporation Device 3439 (rev 22)
00:13.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub I/OxAPIC Interrupt Controller (rev 22)
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 22)
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 22)
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 22)
00:14.3 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Throttle Registers (rev 22)
00:16.0 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:16.1 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:16.2 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:16.3 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:16.4 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:16.5 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:16.6 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:16.7 System peripheral: Intel Corporation 5520/5500/X58 Chipset QuickData Technology Device (rev 22)
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
01:03.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200eW WPCM450 (rev 0a)
03:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
04:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
05:00.0 Serial Attached SCSI controller: Broadcom / LSI SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 02)
06:00.0 RAID bus controller: Broadcom / LSI SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03)
08:00.0 Ethernet controller: Intel Corporation Ethernet Controller 10-Gigabit X540-AT2 (rev 01)
08:00.1 Ethernet controller: Intel Corporation Ethernet Controller 10-Gigabit X540-AT2 (rev 01)
fe:00.0 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture Generic Non-core Registers (rev 02)
fe:00.1 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture System Address Decoder (rev 02)
fe:02.0 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 0 (rev 02)
fe:02.1 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 0 (rev 02)
fe:02.2 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 0 (rev 02)
fe:02.3 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 1 (rev 02)
fe:02.4 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 1 (rev 02)
fe:02.5 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 1 (rev 02)
fe:03.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Registers (rev 02)
fe:03.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Target Address Decoder (rev 02)
fe:03.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller RAS Registers (rev 02)
fe:03.4 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Test Registers (rev 02)
fe:04.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Control (rev 02)
fe:04.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Address (rev 02)
fe:04.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Rank (rev 02)
fe:04.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Thermal Control (rev 02)
fe:05.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Control (rev 02)
fe:05.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Address (rev 02)
fe:05.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Rank (rev 02)
fe:05.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Thermal Control (rev 02)
fe:06.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Control (rev 02)
fe:06.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Address (rev 02)
fe:06.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Rank (rev 02)
fe:06.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Thermal Control (rev 02)
ff:00.0 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture Generic Non-core Registers (rev 02)
ff:00.1 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 0 (rev 02)
ff:02.3 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 1 (rev 02)
ff:02.4 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 1 (rev 02)
ff:02.5 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 1 (rev 02)
ff:03.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Registers (rev 02)
ff:03.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Target Address Decoder (rev 02)
ff:03.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller RAS Registers (rev 02)
ff:03.4 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Test Registers (rev 02)
ff:04.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Control (rev 02)
ff:04.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Address (rev 02)
ff:04.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Rank (rev 02)
ff:04.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Thermal Control (rev 02)
ff:05.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Control (rev 02)
ff:05.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Address (rev 02)
ff:05.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Rank (rev 02)
ff:05.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Thermal Control (rev 02)
ff:06.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Control (rev 02)
ff:06.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Address (rev 02)
ff:06.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Rank (rev 02)
ff:06.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Thermal Control (rev 02)
fdisk -l results:
Disk /dev/sdy: 223.57 GiB, 240057409536 bytes, 468862128 sectors
Disk model: Patriot Burst El
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 0485A4D4-76C0-471F-8F17-3C7F489B6EAB
Device     Start       End   Sectors   Size Type
/dev/sdy1   4096 468860928 468856833 223.6G Solaris /usr & Apple ZFS
Disk /dev/sdf: 223.57 GiB, 240057409536 bytes, 468862128 sectors
Disklabel type: gpt
Disk identifier: 2E63A136-0C83-4A69-9FA5-B2DAC1B545B9
/dev/sdf1      4096      6143      2048     1M BIOS boot
/dev/sdf2      6144   1054719   1048576   512M EFI System
/dev/sdf3  34609152 468862094 434252943 207.1G Solaris /usr & Apple ZFS
/dev/sdf4   1054720  34609151  33554432    16G Linux swap
Partition table entries are not in disk order.
Disk /dev/sds: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disk model: WDC WD40EZRX-00S
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 95DD9F46-32E8-48C0-AC68-0389D5EE48BC
/dev/sds1   4096 7813969920 7813965825  3.6T Solaris /usr & Apple ZFS
Disk /dev/sdr: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disk model: WDC WD40EZRZ-00W
Disk /dev/sde: 223.57 GiB, 240057409536 bytes, 468862128 sectors
Disklabel type: gpt
Disk identifier: 174FF3B8-B5FF-49FB-BF14-9E9EC030F3AC
/dev/sde1      4096      6143      2048     1M BIOS boot
/dev/sde2      6144   1054719   1048576   512M EFI System
/dev/sde3  34609152 468862094 434252943 207.1G Solaris /usr & Apple ZFS
/dev/sde4   1054720  34609151  33554432    16G Linux swap
Disk /dev/sdq: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disk /dev/sdu: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disklabel type: gpt
Disk identifier: 9601EF01-104F-47EC-9813-B50C5B3F69DB
/dev/sdu1   4096 7813969920 7813965825  3.6T Solaris /usr & Apple ZFS
Disk /dev/sdv: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disklabel type: gpt
Disk identifier: 64CB3297-15BF-4DC3-92BA-0D632C3F46AD
/dev/sdv1   4096 7813969920 7813965825  3.6T Solaris /usr & Apple ZFS
Disk /dev/sdw: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disklabel type: gpt
Disk identifier: 6954F52E-00EB-4E1B-ABBE-97C3ADDC3673
/dev/sdw1   4096 7813969920 7813965825  3.6T Solaris /usr & Apple ZFS
Disk /dev/sdx: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disklabel type: gpt
Disk identifier: 928A933B-0E51-42F3-A5A9-87C56C70299C
/dev/sdx1   4096 7813969920 7813965825  3.6T Solaris /usr & Apple ZFS
Disk /dev/sdd: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: WDC WD40EFRX-68W
Disk /dev/sdm: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdz: 223.57 GiB, 240057409536 bytes, 468862128 sectors
Disklabel type: gpt
Disk identifier: 4579C1FD-21B1-4149-9331-FF22AA988749
/dev/sdz1   4096 468860928 468856833 223.6G Solaris /usr & Apple ZFS
Disk /dev/sdn: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdc: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdl: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdj: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdh: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdg: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdk: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdi: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk /dev/sdt: 3.64 TiB, 4000753476096 bytes, 7813971633 sectors
Disklabel type: gpt
Disk identifier: 0835B86E-A741-4E5E-A150-AC90C87D7ADD
/dev/sdt1   4096 7813969920 7813965825  3.6T Solaris /usr & Apple ZFS
Disk /dev/sdo: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: ST4000NM0265-2DC
Disk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: ST3500514NS
Disklabel type: dos
Disk identifier: 0x00098fc8
Device     Boot     Start       End   Sectors   Size Id Type
/dev/sdb1  *         2048   1026047   1024000   500M 83 Linux
/dev/sdb2         1026048 105883647 104857600    50G 83 Linux
/dev/sdb3       105883648 168798207  62914560    30G 83 Linux
/dev/sdb4       168798208 974608383 805810176 384.2G  5 Extended
/dev/sdb5       168800256 202354687  33554432    16G 82 Linux swap / Solaris
/dev/sdb6       202356736 223328255  20971520    10G 83 Linux
/dev/sdb7       223330304 240107519  16777216     8G 83 Linux
/dev/sdb8       240109568 256884735  16775168     8G 83 Linux
/dev/sdb9       256886784 760203263 503316480   240G 83 Linux
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
/dev/sda1  *         2048   1026047   1024000   500M 83 Linux
/dev/sda2         1026048 105883647 104857600    50G 83 Linux
/dev/sda3       105883648 168798207  62914560    30G 83 Linux
/dev/sda4       168798208 974608383 805810176 384.2G  5 Extended
/dev/sda5       168800256 202354687  33554432    16G 82 Linux swap / Solaris
/dev/sda6       202356736 223328255  20971520    10G 83 Linux
/dev/sda7       223330304 240107519  16777216     8G 83 Linux
/dev/sda8       240109568 256884735  16775168     8G 83 Linux
/dev/sda9       256886784 760203263 503316480   240G 83 Linux
Disk /dev/sdp: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: ST4000NM0024-1HT
Disk /dev/md127: 15.98 GiB, 17162043392 bytes, 33519616 sectors
Disk /dev/mapper/md127: 15.98 GiB, 17162043392 bytes, 33519616 sectors
Plug in SATA power. The cable carries only data, not power.
Thank you, I will try this. It will take me some time, as I will need to partially disassemble the chassis to access a power source, as well as find an appropriate power cable. I will circle back with results.
This worked. I simply used a different adaptor, which carries both 12v power and data to/from the pcie slot. (Won’t let me link here from Amazon… the adaptor is not of a very high quality but is working so far, good thing I have redundancy). I feel very silly. Thank you very much for your help, etorix.
Nope, the chain of adaptors you’re using does not carry power from the PCIe slot to the disk. You must plug in the SATA power cable part.
