Actual installs on uGreen hardware - observations, experiences & tips
You have a dxp6800, correct?
Are you running scale version 24.04.2 on baremetal, or on top of something like proxmox?
Yes, I have a 6800, and I’m running SCALE 24.04.2 on bare metal. I upgraded the RAM to 64 GB the other day, so the factory-installed DIMM is no longer there, if that makes a difference.
I see the MSRP has increased–during the kickstarter, we were told it was US$999; now it’s up to $1199. I don’t think I’d pay either of those prices, but I think it represents good value at the $649 kickstarter price.
Odd. I wonder why I get messages about an EDAC memory controller on my machine and you don’t. Do you have the stock boot drive removed from the machine? Did you ever install ugos?
Nice to see users trying these out. I have a couple racks so wouldn’t use these, but they looked like a fantastic option for people that want something smaller. Have wanted to recommend these as a cheaper alternative to established brands, but not until seeing how they perform. The price increase really blunts the value prospect during the Kickstarter.
LED issue is minor and I expect it’s something they can easily resolve. The cooling seems ‘good enough’ but definitely not great. What fans are installed? I don’t see much on the product page. I’ve got some older U-NAS 810A 8-bay cases that keep the drives at a nice ~30-35c, but they have 2 x 120mm fans for the drives.
Yes, I replaced it and installed TrueNAS on the new one. I never did boot or install UGOS, but figured I’d keep the option open.
I expect it could be done easily enough, but I haven’t seen that it has yet. The script linked up-topic turns the network LED blue and the drive LEDs green, from which they don’t change–I think there’s more work to be done, to the extent anyone thinks it’s important (which I really don’t, but it’d be nice to have a drive LED turn red on a disk fault).
This is probably the biggest limitation. My drives idle at around 40°C, and that’s in a 21°C room where it’s pretty much free-standing–no external obstructions to airflow. I hit thermal throttling on the CPU a bit. I’ve seen occasional reference to fan swaps, but as it’s in the living room right now I don’t want to increase the noise level significantly.
How is the noise level, anyway? Fans and disks?
I figured they selected fans that are as quiet as possible while keeping the ‘good enough’ temps. I try to shoot for ~35c which is why my storage is loud and in a rack in a separate room. 40c wouldn’t really bother me, especially for the use-case I imagine people get the U-Greens – to sit in a room they actually use without being obnoxiously loud.
Throttling CPU kind of stinks, but may not be a big deal. Wonder why they didn’t go with AMD?
I can’t really quantify it–it’s noticeable, but not bothersome. I hear the disks more than the fans.
As mentioned above, custom kernel drivers are required if you want to enable the HDD status LEDs, or monitor the chassis fan speed via the onboard SuperIO IT8613E chip.
The miskcoo/ugreen_leds_controller repo at GitHub (linked above already) does the trick and can be configured to show network and drive activity.
Only downside is that with a new TrueNAS version, the new kernel module needs to be loaded again. There are pre-compiled ones for TrueNAS available on the repo!
In order to read values of the chassis fan, you mentioned a similar driver would be required. Are you aware of a project that tackled this already, or can you give some guidance on how to get the fan speed values working as well?
I’ll have to take a look at that LED repo again now that I’ve moved the NAS into my home office. Those flashing lights are getting annoying. :rofl:
I have not found anything built explicitly for TrueNAS, but I know of a few people using the it87 driver for unraid on their Ugreen systems. It allows them to configure additional temperature monitoring and smart fan speed control.
The above project is based off of this: GitHub - frankcrawford/it87 which, theoretically, should work on any debian system (like TrueNAS) if configured correctly.
Messing with the SuperIO chip can potentially be dangerous if you don’t know what you’re doing, so I haven’t explored it in depth.
If you haven’t yet, take a look at the Ugreen NASync discord server and subreddit. That seems to be where most Ugreen NAS modding info is being shared. I’ll still post my updates here as I think a webforum is more appropriate for documentation.
DXP2800 User here. Disabled emmc and installed TrueNas Scale on a 16GB Partion of a 1TB NVMe Drive. Rest Capacity used as Volume Pool for Apps.
Planning to upgrade to 16GB Ram ( wonder if 32GB RAM will work hence not supported officially )
Running Jellyfin, Immich, Paperless-ngx for now.
Anyone did the upgrade from TrueNAS-24.10.1 → TrueNAS-24.10.2 yet?
I’ve got 32Gb installed in an N100 based Mini PC, and that’s fine. Also read a few people have put 32Gb into their DXP2800’s and found it works ok too.
I’m seeing the exact same EDAC errors at same address. I have installed 64GB of RAM and only started looking in dmesg because I’m finding that I’m having cksum errors on my first pool scrub after completing a truenas replication to this new ugreen NAS.
Not sure it is related. But certainly interesting that we have the exact same error while others have none. May try putting back in the original RAM.
root@truenasugreen[~]# dmesg -T | grep EDAC
[Tue Jun 10 22:41:56 2025] EDAC MC: Ver: 3.0.0
[Tue Jun 10 22:42:17 2025] EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
[Tue Jun 10 22:42:17 2025] EDAC MC1: Giving out device to module igen6_edac controller Intel_client_SoC MC#1: DEV 0000:00:00.0 (INTERRUPT)
[Tue Jun 10 22:42:17 2025] EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
[Tue Jun 10 22:42:17 2025] EDAC igen6 MC1: ADDR 0x7fffffffe0
[Tue Jun 10 22:42:17 2025] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[Tue Jun 10 22:42:17 2025] EDAC igen6 MC0: ADDR 0x7fffffffe0
[Tue Jun 10 22:42:17 2025] EDAC igen6: v2.5.1
seing the same message with a 32GB Memory installed. By the way now running fangtooth.
Anyone got any setup running with 2 SSD to mirror the OS and/or App
Hi all,
I wanted to share my experience running TrueNAS SCALE on a Ugreen NASync DXP6800 Pro – in case it helps others, or if anyone has further insights.
:wrench: Hardware Overview:
CPU: Intel Core i5-1235U
RAM: 64GB DDR4
Disks: 6× Seagate IronWolf Pro 8TB in RAIDZ2
OS Drive: NVMe (Removed orginal disk and added a new one.)
No UPS
Network: 1 Gbps via enp87s0 bridged to br0
The Issues:
After initial setup everything looked fine, but I started getting random reboots – particularly during rsync over NFS. No kernel panic, no crash log, just sudden restarts.
Troubleshooting Performed:
  1. RAM:
    Ran full memtest86+ overnight – no errors.
  2. NVMe suspected:
    System drive and NVMe-related power-saving parameters (nvme_core.default_ps_max_latency_us) tested.
Ultimately removed both NVMe drives on my nvmepool physically to rule out instability. No crashes since.
(The nevmepool was never used… But remeved them rule out problem)
3. Networking
Interface enp87s0 passed all ethtool -S stats: no errors or drops.
However, TrueNAS would crash or reboot during heavy rsync over NFS.
  1. System Logs:
    Monitored dmesg, journalctl -k, and SMART data.
    All clean: no thermal issues, no disk read/write/SMART errors.
  2. Power management:
    EEE was disabled on NIC.
No evidence of power-related problems.
Current Status:
System has been 100% stable for 12+ hours, including under rsync, scrub, and light stress testing.
Plan to reintroduce NVMe (only one brand/model) later, once baseline is solid.
healthcheck.sh script running regularly to track disk/SMART status.
Summary:
This box has good potential – but stability scritcal for me.
To try - Disabling NIC offloading features.
Tips on probelms with NVMe, brands to avoid etc.
mine.
Hope some one have additional things for me to test.
– Johan
PS a have the EDAC error: dmesg -T | grep EDAC
[Sun Jul 13 22:12:03 2025] EDAC MC: Ver: 3.0.0
[Sun Jul 13 22:12:16 2025] EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
[Sun Jul 13 22:12:16 2025] EDAC MC1: Giving out device to module igen6_edac controller Intel_client_SoC MC#1: DEV 0000:00:00.0 (INTERRUPT)
[Sun Jul 13 22:12:16 2025] EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
[Sun Jul 13 22:12:16 2025] EDAC igen6 MC1: ADDR 0x7fffffffe0
[Sun Jul 13 22:12:16 2025] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[Sun Jul 13 22:12:16 2025] EDAC igen6 MC0: ADDR 0x7fffffffe0
[Sun Jul 13 22:12:16 2025] EDAC igen6: v2.5.1
Did you disable watchdog?
Yes I have, the problem is that I can’t find the reason for my reboot. It can run fine for 2-3 days and then a reboot and only 1-2 hours later another reboot and then it runs fine for 1-2 days. We’ll see if it gets better now that I’ve removed my two nvme disks.
Based on this thread (and many other sources) I jumped on buying one (DXP 6800 Pro) - so far, it’s going well. I was looking at a “NAS” solution or doing a DIY, to replace my supermicro box that is power hungry. Lately I’ve been thinking towards downsizing, so this fits the bill.
I immediately upgraded the RAM to 64GB, and I have the HDD bays loaded with WD Gold 10TB drives; underneath installed 2x WD Black 1TB NVMe, and I swapped out the boot drive for a Micron/Crucial 1TB NVMe after some disassembly. Of note, these slots are not equal; the boot position is a Gen3x1, and the other two M.2 are a Gen3x2 and a Gen4x4 slot; though I don’t know which, from what I’ve read the one closer to the RAM is the 4x4. The PCIe slot is a Gen3x2 slot and does not support Bifurcation. I am thinking towards moving one of the M.2 Blacks to a PCIe card, and then pop in a NVMe for L2ARC in the 4x4 slot.
It was a bit of a trick getting into BIOS, but once in, disabled watchdog; then installed TrueNAS Scale 25.04. It’s been solid. Copied over my 7TB of data, and watched as the CPU certainly runs hot. If someone comes up with a solution for something better, I’m in.
Otherwise, it’s been quick; never not-responsive, and once my data was transferred in, my data doesn’t change that much. The 2x 10GBe NICs are a nice add on, and I do get speeds that justify them.
I opted to swap those 10TB WD Gold from the air based model to the HE based model (I have 2 file servers that I’d loaded them with both) as the HE based models run cooler and consume less power. I’ve replaced up to 2 at a time so 4 disks spinning heavy (mirrors) and it’s not missed a beat.
As to my pool; I did 3x mirrored vDEVs, 1M record size, 256K small blocks with the black drives as a special vDEV mirror, ZSTD compression. Seems to handle everything I want out of it, which, sure it’s not as fast as my U.3/SATASSD Supermicro box, but it also consumes about half as much power and I don’t need to run my aux AC unit…lol
The slot is Gen 3x4 (a x8 card will fit).
After disassembling the unit a couple of times, I decided to use an external USB-C 3.2 Gen 2 external NVMe as my boot drive instead on the M.2 3x1 connection. It’s worked great and, if it fails, I’m back up and running in a couple of minutes.
The drive lights are kind of annoying but I’m not going to customizes my install just to fix them.
That fails the “TrueNAS as an appliance” test. I’m a purist :slight_smile:
