AD group quirk in publishing samba shares
Hi folks,
Loving our TrueNAS, but I am having trouble getting it to publish samba shares to Active Directory groups. A few notes:
  • Active Directory services is working and shows as healthy
  • Kerberos realms are properly autopopulating as expected
  • wbinfo -g and wbinfo -g at the shell shows all of our AD groups and users
When attempting to scroll down the list of groups on a samba share, though, I only see the built-in groups and none of the active directory ones.
The only meaningful error I can find in the logs is here:
/var/log/samba4/log.wb-DOMAIN
Which says ldb: Failed to connect to 'var/db/system/samba4/private/secrets.ldb’with backend ‘tdb’: Unable to open tdb ‘/var/db/system/samba4/private/secrets.ldb’: No such file or directory.
Any and all comments and suggestions welcome.
Thanks and warm regards,
Stu
This sounds like an idmap issue. Seeing the groups in wbinfo doesn’t mean the backend can convert them to proper NSS entries. Check output of getent group.
