I would be glad if someone could help me fix this issue by walking me through the commands that I need to be using in the Truenas Scale shell in order to add this PCI Passthrough Device “0000:06:00.0 ‘Multimedia controller’: DVB Tuner PCIe Card by ‘TBS Technologies’” to my Ubuntu VM, here’s what error msg I get when trying to start the VM after adding my desired device named above,
[EFAULT] internal error: qemu unexpectedly closed the monitor: 2024-08-08T13:54:20.820270Z qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:06:00.0","id":"hostdev0","bus":"pci.0","addr":"0x7"}: vfio 0000:06:00.0: group 9 is not viable Please ensure all devices within the iommu_group are bound to their vfio bus driver.
More info …
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 182, in start
if self.domain.create() < 0:
File "/usr/lib/python3/dist-packages/libvirt.py", line 1373, in create
raise libvirtError('virDomainCreate() failed')
libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2024-08-08T13:54:20.820270Z qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:06:00.0","id":"hostdev0","bus":"pci.0","addr":"0x7"}: vfio 0000:06:00.0: group 9 is not viable
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 198, in call_method
result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1466, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1417, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 187, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 47, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 58, in start
await self.middleware.run_in_thread(self._start, vm['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1324, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1321, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 68, in _start
self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name))
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 191, in start
raise CallError('\n'.join(errors))
middlewared.service_exception.CallError: [EFAULT] internal error: qemu unexpectedly closed the monitor: 2024-08-08T13:54:20.820270Z qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:06:00.0","id":"hostdev0","bus":"pci.0","addr":"0x7"}: vfio 0000:06:00.0: group 9 is not viable
Please ensure all devices within the "iommu_group" are bound to their "vfio bus driver".
all I know is that I have to use the shell to do some kind of commands to bind the entire devices in “9” group to their vfio bus driver. problem is I tried ChatGPT to help me do that since I don’t have much knowledge when it comes to “command lines” in Truenas Shell unfortunately therefore I need an easy to understand and clear command lines to use in order to fix this issue.
