I have 4 NAS’s. Three running V13.0.U6.7 (NAS-4-5-6) and One V25.10.0.1 (NAS3). NAS4 has connectivity issues where I would be copying files to it and the drive would disconnect. I had the system checked out. Motherboard, NIC card, Power supply and the SSD Boot drive. All tested fine. Even though I had a fixed IP address in the configuration I could not use a Web-GUI to access it or the data pool.So, chose #8 to restore to default configuration, putting in the fixed IP address before realizing that I did not have a backup of the system because it was on the failed NAS. I now have Web-GUI access since the reset.
Now since I’m going to have to manually restore the system config’s, I wanted to know if I would be able to just install the V25.10.7 or V25.10.0.1 and still be able to import the data pool. It’s basically one pool with a bunch of different folders. With 2 users have complete access to everything. I have not updated the 3 NAS’s with the old OS because I’m still trying to figure out V25.
Also what is the REAL difference between the Web-based install and the classic install? I always have had issues setting permissions. Even having V13 window side by side with V25 to configure V25 as a guide it was very time consuming…BUT I did get V25 to work after futzing with the differences between the two versions
The normal TrueNAS installation separates the boot pool from any data pools.
So yes, you should be able to re-load the OS part, and just import your data pool. The sharing configuration and other non-data related configurations will have to be manually re-done. But, that is the result of not backing up your configuration.
One thing some people do, is have a daily cronjob that saves the configuration on to a data pool. (And perhaps keep a history of a dozen backups.) This is because some people run un-mirrored boot pools, which are prone to failures.
I made the mistake of putting the NAS backups on only one NAS and not one of the other NAS.
I have tried to find in the documentation on how to do a manual backup and restore, and can not seem to find it. That way I can do the backups manually and know for sure where they are getting put. Could you point me into the right direction? I would need to backup up both V13.0.U6.7 and V25.10.0.1 OS’s.
Do you know that if I should install V25 would the data pool still be usable should I decide to go back to V13? I though I’d get another boot drive and install V25, and if anything goes wrong I can go back to V13.
Thanks Arwen you’ve been a big help.
What are you calling a backup? Is it just the download of the system configuration along with any necessary secret seeds? Online documentation will show where for both Core and Scale /CE
