Was getting close to having everything up an running, only to trip near the final hurdle it seems, entirely brought on by myself, any help getting back up and running would be much appreciated,
Specs if it helps:
Version 24.10
i5-14500
Asus W680-Ace IPMI
32 GB ECC ram (on the QVL list)
64gb Optane - Boot Drive
1TB NVME - SN850x
3x28TB Exos - raid Z-1
I restarted my system earlier after attempting to delete some files with the “mc” command, files would delete for a while and then seemingly get stuck, I noticed that my restart time was sitting around 30-45 mins, which I thought was abit excessive so I decided to look for the cause,
I stopped all my running containers, restart was still sitting around 30-45mins, then I disabled/stopped my SMB share, again restart was taking quite a while to complete, after one of the restarts I noticed the “running jobs” had an icon, when I click to view it shows
pool.import_on_boot, sitting at 0.00%, sat for about 40 mins before I hoped another restart would fix this (I know I know), has been sitting with pool.import_on_boot as a running job for just over an hour now
If I go to my storage dashboard I can see my 1TB nvme pool, all seems fine with it, I can click into the individual datasets within it
on the 28x3 - Raid Z-1 pool, it shows the Topology, Usage - it reports 23.61TiB used, 31.02TiB free, but If I click manage dataset and try to click on any of the sub-datasets I get an error
“CallError” - [EFAULT] Failed retreiving GROUP quotas for MyDataset/SubDataset or
“CallError” [ENOENT] Path /mnt/MyDataset/SubDataset not found - depending on which subt-dataset I click on
I had a google and zpool list -v
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
Docker Containers 928G 97.9G 830G - - 2% 10% 1.00x ONLINE /mnt
44a84041-4c32-4c3a-bd0b-649cd0dbff0e 932G 97.9G 830G - - 2% 10.5% - ONLINE
The_Library 76.4T 31.1T 45.3T - - 1% 40% 1.00x ONLINE /mnt
raidz1-0 76.4T 31.1T 45.3T - - 1% 40.7% - ONLINE
9afcb73e-682d-42e6-a636-3d3e3b65a11d 25.5T - - - - - - - ONLINE
128addd9-c515-4104-8348-852da83b0325 25.5T - - - - - - - ONLINE
0900f966-326c-42e5-994a-746f41d98cfd 25.5T - - - - - - - ONLINE
boot-pool 54G 5.20G 48.8G - - 3% 9% 1.00x ONLINE -
nvme1n1p3
so my HDDs are seen to some degree here,
zpool status
pool: Docker Containers
state: ONLINE
scan: scrub repaired 0B in 00:00:33 with 0 errors on Sun Jan 19 00:00:34 2025
NAME STATE READ WRITE CKSUM
Docker Containers ONLINE 0 0 0
44a84041-4c32-4c3a-bd0b-649cd0dbff0e ONLINE 0 0 0
errors: No known data errors
pool: The_Library
state: ONLINE
The_Library ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
9afcb73e-682d-42e6-a636-3d3e3b65a11d ONLINE 0 0 0
128addd9-c515-4104-8348-852da83b0325 ONLINE 0 0 0
0900f966-326c-42e5-994a-746f41d98cfd ONLINE 0 0 0
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:03 with 0 errors on Sun Feb 16 03:45:04 2025
boot-pool ONLINE 0 0 0
nvme1n1p3 ONLINE 0 0 0
I tried zpool import The_Library but it comes back that a pool woth that name already exists, if I go back to the Storage Dashboard and try to export (to try and import again) the pool I get the error that its bust and cant unmount
Not really sure what I’ve broken or how to fix it, if you need any other info be sure to say,
Many Thanks in advance.
