Allow passing through devices to docker container apps
note: this is the same request as NAS-111106 in Jira
Although I am not the original author of the linked ticket, I will copy what he wrote, as I have the identical usecase (zwave USB stick for usage in home automation):
Description:
When creating a docker image, the ability to add devices is not present. This creates problems for containers which need access to devices such as serial ports (for example, a zwave controller) and as a result, the container has to run in host networking mode and with privileged access in order to access the device.
I imagine this could be expressed in the UI the same way that host-folders or external-interfaces would be or a free-form field.
A docker-compose example would be:
devices:
 /dev/ttyACM0:/dev/ttyACM0
I guess I could create my own docker-compose yaml, but I still believe having this option in the UI would make a lot of people’s live easier.
Benefits
Adding this option will allow everyone to use host devices inside docker apps without introducing security issues by using privileged access.
Second this. Many, if not all, “Community” apps on the Discover page do not have the device field. “Custom App” also does not have this field. Most “Stable” apps, such as Plex, have this field.
At the moment, I have to Install via YAML (Docker Compose).
