Trying to get minidlna working as a custom App on TrueNas Scale, and hitting an issue with SSDP based discovery. If I run on a k3s bridge I get a unique IP but the service drops off the network from a discovery perspective after a short while.
If I use node network namespace I can’t hit port 1900 UDP which is required for SSDP discovery.
With Node Port I can easily re-map the service port. but I need the SSDP port to be 1900
Has anyone found a sane way to run SSDP services on TrueNAS as containers?
