I have been using a WD Purple 2Tb disk for cctv recordings etc . This is the 2nd one in just over 4 years. Now this one has just failed and is not quite 2 years old.
It has failed the last 21 SMART tests, and I am not getting any more cctv recordings on it for the last 2 days.
Can anyone recommend a good reliable disk for cctv recordings.
Thanks
Thanks, yes I just found out that I should be using a surveillance HD, Doh!
I didn’t know that before as I thought a WD Purple would do the job.
I have now ordered a 2TB WD surveillnce HD
