Hi TrueNAS Community, long time lurker (since FreeNAS 9,) first time poster.
I have a SCALE array of 7xRAIDZ2 VDEVs | 5 wide each, made of 10TB drives with a Special VDEV for metadata only on 3-way mirrored NVMe. In the past for capacity expansion on simple pools I’ve always build a 2nd pool with larger disks and done a zfs send | zfs recv to migrate then repoint all my shares and services. But due to trying to keep my metadata on NVMe, and being maxed out on NVMe slots, that wasn’t a fit this time. I read on the forum that TrueNAS Scale should be able to do simultaneous replace operations through the GUI so having a few empty drive slots I planned out doing this in 5 round of 7 drives each (one in each VDEV.)
Imagine my surprise when at the end of the resilvering it showed only 1 unused drive and started the second resilvering. Further research shows other have experienced the same …seems to operate in series not parallel…
Was this a capability misunderstanding on my part? Or is there a different process I need to follow to keep from having to do all 34 additional resilvers?
