Anyone got an recent hotio qbittorrent with wireguard running?
sometime in december an update broke the docker. ok, not broke - more changes on VPN_forward or so prevented my qbit to run. I have a wg0.conf with a mullvad wireguard config (was running fine until december) and the yaml looks like this
services:
  qbittorrent:
    cap_add:
      - NET_ADMIN
    container_name: qbittorrent
    environment:
      - PUID=568
      - PGID=568
      - UMASK=002
      - TZ=Europe/Paris
      - WEBUI_PORTS=8080/tcp,8080/udp
      - VPN_ENABLED=true
      - VPN_CONF=wg0
      - VPN_PROVIDER=generic
      - VPN_LAN_NETWORK=10.10.0.0/24
      - VPN_NAMESERVERS=9.9.9.9
      - VPN_LAN_LEAK_ENABLED=false
      - VPN_EXPOSE_PORTS_ON_LAN=
      - VPN_AUTO_PORT_FORWARD=
      - VPN_PORT_REDIRECTS=
      - VPN_KEEP_LOCAL_DNS=false
      - VPN_FIREWALL_TYPE=auto
      - PRIVOXY_ENABLED=false
      - UNBOUND_ENABLED=false
    image: ghcr.io/hotio/qbittorrent:latest
    ports:
      - '8080:8080'
    restart: unless-stopped
    sysctls:
      - net.ipv4.conf.all.src_valid_mark=1
      - net.ipv6.conf.all.disable_ipv6=1
    volumes:
      - /mnt/apps/configs/qbit/:/config
      - /mnt/datapool/media:/media
Container starts, but I can not connect to the gui
2026-01-28 21:27:36.547100+00:00s6-rc: info: service init-wireguard successfully started
2026-01-28 21:27:36.547757+00:00s6-rc: info: service service-unbound: starting
2026-01-28 21:27:36.547966+00:00s6-rc: info: service service-qbittorrent: starting
2026-01-28 21:27:36.548289+00:00s6-rc: info: service service-forwarder: starting
2026-01-28 21:27:36.552537+00:00s6-rc: info: service service-unbound successfully started
2026-01-28 21:27:36.552647+00:00s6-rc: info: service service-forwarder successfully started
2026-01-28 21:27:36.553491+00:00s6-rc: info: service service-qbittorrent successfully started
2026-01-28 21:27:36.553798+00:00s6-rc: info: service legacy-services: starting
2026-01-28 21:27:36.564995+00:00s6-rc: info: service legacy-services successfully started
2026-01-28 21:27:36.565130+00:00[2026-01-28 22:27:36] [INF] [QBITTORRENT] Delaying start until forwarded port is available.
2026-01-28 21:27:36.571042+00:00[2026-01-28 22:27:36] [INF] [UNBOUND] Adding nameserver [VPN][9.9.9.9].
2026-01-28 21:27:36.666900+00:00[1769635656] unbound[323:0] info: start of service (unbound 1.23.1).
2026-01-28 21:27:46.574090+00:00[2026-01-28 22:27:46] [WRN] [FORWARDER] The file [/config/wireguard/forwarded_port] was not found. Set [VPN_AUTO_PORT_FORWARD=false] if you don't plan on providing that file yourself.
any combination of VPN_AUTO_PORT_FORWARD I tried gives different errors - using 51820 (the only port in the wg0.conf), leaving it blank, a different number…
what should be changed in the yaml (i assume it is an variable in the yaml) to make it work again?
Same issue. You can see in the log it is saying:
”The file [/config/wireguard/forwarded_port] was not found.”
So I guess we need to create this file. But I am unsure of the syntax
Actually - looking at the qbittorrent for linux it was updated to use this new variable:
”TORRENTING_PORT=”
But when I try that with my airvpn port I don’t see that it connects.
could you solve this? Or are you still as lost as me?
I got a step closer to the solution - at least qbit and wireguard are running. I followed this example:
https://wiki.serversatho.me/qBittorrent (tab “Linuxserver Wireguard” in step 1 “Deploy qBittorrent”)
but I struggle with the tunnel, wireguard logs look like it is running, but qBit is indicating “firewalled” and shows no I/O traffic. I will report back
seems like I found the solution: I simply restartet the whole TrueNAS box. I have no idea why this fixed the wireguard when restarting the stack of qbit+wireguard or the single wireguard container did not.
Another lesson learned: I had to change the default download path from “/downloads” to the existing path “/media/Download”. There was a folder expected but not present and so I got a permission denied with resulted in errored status on test torrents even if I could see peers…
I am still learning :slight_smile:
Om very interested to know what the final yaml code looked like. I also struggle with this currently.
Im running airVPN.
I followed https://wiki.serversatho.me/qBittorrent (in step 1 open the second tab “Linuxserver Wireguard”) and was able to start two containers. On my first try it did work. I am using mullvad. But since then I am struggleing again - wireguard starts, qbit starts and wireguards ditches. After some searching I found that mullvad restricted the use of port forwarding and maybe this can be the cause - but why it did work for at least 1 day is beyond me. In fact I was eyeing airVPN as a possible alternative to mullvad (especially because they mention being ok with port forwarding), but If you struggle as well to get a connection I don’t know anymore…
Could you check the YAML from the wiki.serversatho.me and give it a try and report back here if this was the solution for you?
I might give it another try with airVPN then…
I got it working with airvpn and the latest yaml code.
In the #insert forwarded port here, I added the port that I opened in airVPN.
Also, make sure to add the 5.1.20 or whatever release on qbit that the new yaml code from servers@ho.me update with.
All is good in the “Linux iso hoarding” world again :grinning_face_with_smiling_eyes::grinning_face_with_smiling_eyes:.
I’ve started with a LXC container and using
  • Bookworm
  • qBittorent-nox
  • NordVPN
So far I’ve got
  • qBittorent-nox installed and WebGUI access
  • NordVPN installed (probably should have done this first)
  • it sorta working - manually
  • running as root - limitation for disks access to host?
Will need to get it automated
I’ve got it working again. I switched back to the YAML for qubittorrent Hotio. The dual container solution (qbit+wireguard) did not work reliably for me. Sometimes wireguard would switch to “unhealthy” as soon as qbit started, I could not reach the qbit WebGUI and so on.
fixing the qbit from Hotio to the version 5.1.2 and ditching the extra wg0.conf-line with “postup…” (I commented it out with #) did it for me. The container came immediatly online, webgui could be reached and the old files were already there. Interface wg0 seems not to leak additional information so I am satisfied for the moment.
