I would like my network storage AOE (ATA Over Ethernet) to be detected by the WebUI in my TrueNAS Scale.
The /dev/etherd/e1.1 disk is visible in the system:
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 1.8T 0 disk
└─sda1 8:1 0 1.8T 0 part
sdb 8:16 0 1.8T 0 disk
└─sdb1 8:17 0 1.8T 0 part
sdc 8:32 0 1.8T 0 disk
└─sdc1 8:33 0 1.8T 0 part
etherd/e1.1 152:0 0 14.6T 0 disk
blkid
/dev/sdb1: LABEL="pool1" UUID="16442082168976559051" UUID_SUB="7093590244684122422" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="91d591ef-faa5-4110-a901-08edadc571a4"
/dev/sdc1: LABEL="pool1" UUID="16442082168976559051" UUID_SUB="13984627305268308369" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="7cfca192-6dab-4846-9502-c7a0d11580fa"
/dev/sda1: LABEL="pool1" UUID="16442082168976559051" UUID_SUB="4698163313041713279" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="7b986604-bd45-41f5-b417-88d7f1486b58"
/dev/etherd/e1.1: LABEL="pool-coraid-lun1" UUID="4956428258616236964" UUID_SUB="10545282909607564340" BLOCK_SIZE="512" TYPE="zfs_member"
and I can even manually create a pool
zpool create -m /mnt/aoe-pool aoe-pool /dev/etherd/e1.1
zfs list
NAME USED AVAIL REFER MOUNTPOINT
aoe-pool 132K 14.4T 24K /mnt/aoe-pool
but I would like to do everything through the WebUI, because I have problems with sharing that pool (some permissions related errors).
I know that AOE disks are not recommended for TrueNAS, but I have such an array and I would like to use it as an additional ZFS pool.
