Application can't connect to update.ixsystems.com, connection reset by peer
I’ve been dealing with this problem since TrueNAS core, I through that it was because I never upgraded to scale some weird cypher mismatch happens, but it has been happening after I upgraded to Scale too, so it has been a pain.
This is the python traceback:
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1098, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs, sock=sock)
  File "/usr/lib/python3.11/asyncio/base_events.py", line 1113, in create_connection
    transport, protocol = await self._create_connection_transport(
  File "/usr/lib/python3.11/asyncio/base_events.py", line 1146, in _create_connection_transport
    await waiter
  File "/usr/lib/python3.11/asyncio/selector_events.py", line 974, in _read_ready__get_buffer
    nbytes = self._sock.recv_into(buf)
ConnectionResetError: [Errno 104] Connection reset by peer
The above exception was the direct cause of the following exception:
  File "/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py", line 323, in process_method_call
    result = await method.call(app, params)
  File "/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py", line 52, in call
    result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 911, in call_with_audit
    result = await self._call(method, serviceobj, methodobj, params, app=app,
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 731, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 624, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 178, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update.py", line 143, in set_train
    return self.__set_train(train)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update.py", line 150, in __set_train
    trains = self.get_trains()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update.py", line 105, in get_trains
    trains_data = self.middleware.call_sync('update.get_trains_data')
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1030, in call_sync
    return self.run_coroutine(methodobj(*prepared_call.args))
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1070, in run_coroutine
    return fut.result()
  File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result
    return self.__get_result()
  File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result
    raise self._exception
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/trains.py", line 63, in get_trains_data
    **(await self.fetch(f"{self.update_srv}/trains.json"))
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/trains.py", line 25, in fetch
    async with client.get(url) as resp:
  File "/usr/lib/python3/dist-packages/aiohttp/client.py", line 1359, in __aenter__
    self._resp: _RetType = await self._coro
  File "/usr/lib/python3/dist-packages/aiohttp/client.py", line 663, in _request
    conn = await self._connector.connect(
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 563, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1032, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1366, in _create_direct_connection
    raise last_exc
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1335, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
  File "/usr/lib/python3/dist-packages/aiohttp/connector.py", line 1106, in _wrap_create_connection
    raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host update.ixsystems.com:443 ssl:default [Connection reset by peer]
From the host, it seems that it has no problem connecting to the ixsystems servers:
truenas01% echo | openssl s_client -showcerts -servername update.ixsystems.com -connect update.ixsystems.com:443 2>/dev/null | openssl x509 -inform pem -noout -text
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            54:29:03:7a:7e:5f:a3:f2:0e:a4:aa:d3:db:b7:60:f0
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: C = US, O = Google Trust Services, CN = WR1
        Validity
            Not Before: Sep 15 06:43:28 2025 GMT
            Not After : Dec 14 06:43:27 2025 GMT
        Subject: CN = update.ixsystems.com
        Subject Public Key Info:
            Public Key Algorithm: id-ecPublicKey
                Public-Key: (256 bit)
                pub:
                    04:95:97:32:4b:db:f7:5a:1a:1b:50:24:e8:04:8e:
                    65:27:96:54:7a:58:3f:64:b0:a4:54:6b:7c:cc:3b:
                    59:f3:e9:d3:30:90:d4:e0:bd:3e:27:8f:32:49:65:
                    e8:d7:18:db:8e:0b:cd:a1:0c:c3:69:ab:f5:fc:49:
                    4c:b0:05:16:74
                ASN1 OID: prime256v1
                NIST CURVE: P-256
        X509v3 extensions:
            X509v3 Key Usage: critical
                Digital Signature
            X509v3 Extended Key Usage:
                TLS Web Server Authentication
            X509v3 Basic Constraints: critical
                CA:FALSE
            X509v3 Subject Key Identifier:
                06:B6:13:66:EB:10:E7:52:7B:F3:CC:FB:F9:1E:C1:7B:80:BE:56:BF
            X509v3 Authority Key Identifier:
                66:69:49:D4:DE:2A:9C:91:03:CF:89:0E:24:B8:0E:30:03:6E:88:2E
            Authority Information Access:
                OCSP - URI:http://o.pki.goog/s/wr1/VCk
                CA Issuers - URI:http://i.pki.goog/wr1.crt
            X509v3 Subject Alternative Name:
                DNS:update.ixsystems.com
            X509v3 Certificate Policies:
                Policy: 2.23.140.1.2.1
            X509v3 CRL Distribution Points:
                Full Name:
                  URI:http://c.pki.goog/wr1/S3hvOSet3rM.crl
            CT Precertificate SCTs:
                Signed Certificate Timestamp:
                    Version   : v1 (0x0)
                    Log ID    : 1A:04:FF:49:D0:54:1D:40:AF:F6:A0:C3:BF:F1:D8:C4:
                                67:2F:4E:EC:EE:23:40:68:98:6B:17:40:2E:DC:89:7D
                    Timestamp : Sep 15 07:43:28.987 2025 GMT
                    Extensions: none
                    Signature : ecdsa-with-SHA256
                                30:45:02:21:00:E0:24:23:64:92:01:EA:D3:FE:FC:24:
                                BA:79:83:11:1C:99:10:D4:31:03:C8:B0:EE:63:D6:EB:
                                62:CA:95:00:C5:02:20:7E:0E:8B:56:09:EC:48:3F:35:
                                BB:BF:8D:37:9D:4E:E5:FB:7B:8E:8B:3F:E6:57:92:12:
                                57:22:D9:7E:27:71:13
                    Version   : v1 (0x0)
                    Log ID    : DD:DC:CA:34:95:D7:E1:16:05:E7:95:32:FA:C7:9F:F8:
                                3D:1C:50:DF:DB:00:3A:14:12:76:0A:2C:AC:BB:C8:2A
                    Timestamp : Sep 15 07:43:28.974 2025 GMT
                    Extensions: none
                                30:46:02:21:00:9F:9E:2A:3B:DF:37:AC:99:85:5B:E4:
                                89:DC:C2:A2:AE:29:77:1B:A8:3E:2E:06:6F:9E:1F:4B:
                                69:F8:5B:DD:0A:02:21:00:EB:35:D0:FB:7D:60:C4:13:
                                74:7A:F3:52:74:BC:EA:9F:43:EC:2C:F9:7E:65:13:11:
                                F5:5F:BB:D1:6B:9A:26:BB
    Signature Value:
        ab:3f:71:f9:25:b1:7a:a5:12:23:23:84:7d:b4:b6:f2:1f:21:
        24:fc:f7:a1:14:1f:10:32:fe:d8:c9:a2:79:b2:d2:30:3d:61:
        dc:6f:a0:94:ec:2e:4c:86:3e:41:6b:24:ac:1c:d9:90:f2:eb:
        33:0c:4a:19:ac:17:0d:27:07:38:f3:a1:08:4b:5f:93:25:cf:
        89:28:de:b9:cb:4c:0a:e0:5a:fe:93:35:4b:3c:c9:17:2b:49:
        6f:db:f2:32:db:fc:a4:ec:1c:cf:e7:af:23:91:fa:4a:52:73:
        63:5f:f2:7b:61:76:87:4a:92:55:40:18:f4:59:08:3c:23:42:
        87:19:ed:a1:10:f1:40:11:f2:16:43:67:4c:f9:1c:92:a7:d2:
        78:91:ff:d2:d6:28:0c:f2:2b:bd:18:d7:6d:0b:49:ec:b3:14:
        38:ae:db:59:c0:5c:f6:d1:bc:d9:36:7f:94:35:bd:8a:5e:5c:
        b1:35:8c:ea:f1:73:b2:65:f2:82:7e:a3:f5:72:81:e5:da:dc:
        5d:a6:bd:5e:01:33:95:a6:29:48:aa:a2:94:ab:b1:6f:6b:0f:
        80:81:d6:f0:4b:a5:32:4a:9d:9b:c3:a1:c5:cf:f3:fe:60:a0:
        fb:63:cd:eb:0a:b6:1f:ef:63:2e:89:76:8a:84:8e:2c:11:17:
        26:51:36:27
I tried to capture the exchange with tcpdump, but everything is hidden behind the TLS layer:
Is your bios time set to utc and your local time set through the webui?
There were cases when the ssl connection got refused when the time was too far out of sync.
Everything is set to UTC. The bios and the webui.
truenas01% timedatectl
               Local time: Sun 2025-10-19 22:27:46 UTC
           Universal time: Sun 2025-10-19 22:27:46 UTC
                 RTC time: Sun 2025-10-19 22:27:47
                Time zone: Etc/UTC (UTC, +0000)
System clock synchronized: yes
              NTP service: active
          RTC in local TZ: no
The last thing I can think of in my sleep depraved state would be this issue if you’re from Spain Italy or the UK
Considering that I’m on Dominican Republic and that it seems that I’m able to speak with the server, I doubt that’s the problem.
Try setting your time zone, the Dominican Republic is in UTC-0400 and four hours is probably far enough out of sync that SSL refuses the connection.
Leave your BIOS/hardware time set to UTC, but change your time zone and local time to be correct.
Still nothing:
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 705, in urlopen
    httplib_response = self._make_request(
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 388, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 1050, in _validate_conn
    conn.connect()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 414, in connect
    self.sock = ssl_wrap_socket(
  File "/usr/lib/python3/dist-packages/urllib3/util/ssl_.py", line 449, in ssl_wrap_socket
    ssl_sock = _ssl_wrap_socket_impl(
  File "/usr/lib/python3/dist-packages/urllib3/util/ssl_.py", line 493, in _ssl_wrap_socket_impl
    return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
  File "/usr/lib/python3.11/ssl.py", line 517, in wrap_socket
    return self.sslsocket_class._create(
  File "/usr/lib/python3.11/ssl.py", line 1104, in _create
    self.do_handshake()
  File "/usr/lib/python3.11/ssl.py", line 1382, in do_handshake
    self._sslobj.do_handshake()
  File "/usr/lib/python3/dist-packages/requests/adapters.py", line 489, in send
    resp = conn.urlopen(
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 789, in urlopen
    retries = retries.increment(
  File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 552, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/lib/python3/dist-packages/six.py", line 718, in reraise
    raise value.with_traceback(tb)
    conn.connect()
    self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 562, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 627, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update.py", line 305, in download
    return self.middleware.call_sync('update.download_update', job, train, location, 100)
    return fut.result()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update.py", line 310, in download_update
    return await self.middleware.call('update.download_impl', *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1005, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 720, in _call
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/download_linux.py", line 7, in download_impl
    return await self.middleware.call('update.download_impl_scale', job, train, location, progress_proportion)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/download.py", line 54, in download_impl_scale
    with requests.get(
  File "/usr/lib/python3/dist-packages/requests/api.py", line 73, in get
    return request("get", url, params=params, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 587, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 701, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/adapters.py", line 547, in send
    raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
Also, to the underlying library the local timezone shouldn’t matter, if it does that is an actual bug.
Something that is important to note: sometimes it worked. I just had to be really insistent. In this case I just find it less likely for my insistence to succeed.
