Apps and Custom Routing 25.04
I tried doing a quick search or this topic, but couldn’t find anything. So sorry if it is a duplicate.
I know 25.04 implemented the ability to bind an app to a host IP for incoming requests. Is there any functionality to handle the routing for return traffic or outbound based traffic?
I have a test 25.04 instance that I spun up to do some basic testing on before I upgrade my 24.10 instance. In my test the system has two IPs, 192.168.1.20/24 and 172.16.0.20/24. It only allows to specify a single gateway to be configured. So if the management network and gateway is setup as 192.168.1.1, but I specify an app to listen for traffic on 172.16.0.20, response traffic will be on the 192.168.1.20 IP if the request originated from the 192.168.1.0/24 network or from a separate network. Outgoing traffic originating from the container will also use the 192.168.1.20 IP and it’s gateway.
I currently solve this problem on 24.10 with some custom routing table rules through IPTABLES.
I have certain containers that I want isolated and be subject to traffic inspection through a firewall. With these custom rules, the return traffic and any outgoing traffic is required to route up to the firewall before being able to reach a different network.
A better search should return a number of posts by @pmh explaining that this is standard IP behaviour.
If you want some apps to have their own networking, separate from the rest of the NAS, run these in VMs with their own NIC passed through: Separate network stack and routing.policy.
I will just continue with my solution of controlling it with IPTABLES. It’s capable of managing and maintaining the traffic with the current stack. Still probably not a supported solution, but it works for me and keeps me from having to maintaining more VMs.
Hi @clifford64 I was under the idea that the new functionality would work for outgoing traffic, not for incoming (single) ports.
I am now pondering whether to use mac_vlan (with portainer) or smth else.
You mentioned using custom iptables SNAT rules… could you share your solution for this? Where do you intercept the iptables configuration in Truenas?
thx!!
This is standard IP behaviour but I was arguing this point concerning file sharing services and the UI - because these share a single IP stack.
In CORE you could easily map both jails and VMs to a different layer 2 interface and since both come with their own isolated IP stack you could run them as required and expected by the OP.
I still do that on my CORE system. All externally reachable jail based services are in VLAN 2 and all VMs in VLAN 3 all separated by my OPNsense. No asymmetric routing anywhere. Like e.g. VMware and port groups.
Only file sharing and the UI share the single “trusted” VLAN. Not possible to really separate these.
Now I just tried the new IP address per app feature and it seems like no real separation is taking place as the OP wrote.
If this is the intended behaviour, the IP address per app feature is mostly useless, IMHO. I expected something like I do with jails.
@clifford64 Could you do a short write up about what exactly you do with IPtables? I am not a Linux person :wink:
so… I had a 24.04 system that I had to upgrade, which had an apps setup that made extensive use of container IP addresses (which on the old k3s system would basically add an interface to the container and allow you to define the route in the container, simple but powerful). this is hugely important because controlling outbound traffic is necessary for a lot of use-cases, for example I have services that need to request web traffic from multiple different WAN connections.
And so given that Container IP addressing was supposed to come June 1st I held out until last week, expecting that once I upgraded from Dragonfish my apps would just not work for a few days… not pleasant but I dealt with it.
only today I find out that I need to create aliases on the bridge interface which provides binding and not addressing… I’m sorry this isn’t the same thing? and it especially doesn’t help my use-case unless I want to redo all my apps again outside of the truenas apps ui… fantastic.
UPDATE: I was able to make a docker ipvlan network on the cli, convert the apps to YAML and add them to this with not too much fuss.
Here is my script I use for my docker traffic routing. I have it configured as a postinit script and it works for the most part. The requirement is the container needs to be running for the docker bridge to be initialized and be available for the script to manipulate it with IPTABLES. I also have all of my containers configured through YAML configuration and I specify the specific bridge network they will run on in that YAML configuration.
If you plan to use this script, you will need to update the bridge interface and your network interfaces at the very least.
Also, my knowledge comes from Googling and I don’t fully know what I am doing, so use with caution.
#delay script on startup to allow for containers to startup
sleep 10m
#Create a custom routing table
grep -qxF '200 docker_traffic' /etc/iproute2/rt_tables || echo '200 docker_traffic' | sudo tee -a /etc/iproute2/rt_tables
grep -qxF '201 docker_homeassistant' /etc/iproute2/rt_tables || echo '201 docker_homeassistant' | sudo tee -a /etc/iproute2/rt_tables
#Set up routing rule and default route for Docker network
#Set up routing rules only if they don't already exist
ip rule show | grep -q 'from 192.168.237.0/24 lookup docker_traffic' || ip rule add from 192.168.237.0/24 lookup docker_traffic
ip rule show | grep -q 'from 192.168.238.0/24 lookup docker_traffic' || ip rule add from 192.168.238.0/24 lookup docker_traffic
ip rule show | grep -q 'from 192.168.239.0/24 lookup docker_homeassistant' || ip rule add from 192.168.239.0/24 lookup docker_homeassistant
# Routes for docker_traffic (table 200)
ip route show table 200 | grep -q 'default via 10.0.7.1 dev vlan7' || ip route add default via 10.0.7.1 dev vlan7 src 10.0.7.50 table 200
ip route show table 200 | grep -q '10.0.7.0/24 dev vlan7' || ip route add 10.0.7.0/24 dev vlan7 src 10.0.7.50 table 200
# Routes for docker_homeassistant (table 201)
ip route show table 201 | grep -q 'default via 10.0.7.1 dev vlan7' || ip route add default via 10.0.7.1 dev vlan7 src 10.0.7.51 table 201
ip route show table 201 | grep -q '10.0.7.0/24 dev vlan7' || ip route add 10.0.7.0/24 dev vlan7 src 10.0.7.51 table 201
# Enable NAT for Docker bridge traffic
#"-o br-..." is the docker bridge interface
#Always remove and re-insert SNAT rule for bridge to ensure it is first.
#When docker container starts and initializes docker bridge, a masquerade rule is created and set as first rule in IPTABLES
iptables -t nat -D POSTROUTING -s 192.168.237.0/24 ! -o docker0 -j SNAT --to-source 10.0.7.50 2>/dev/null
iptables -t nat -I POSTROUTING 1 -s 192.168.237.0/24 ! -o docker0 -j SNAT --to-source 10.0.7.50
iptables -t nat -D POSTROUTING -s 192.168.239.0/24 ! -o br-33bf59121eaf -j SNAT --to-source 10.0.7.51 2>/dev/null
iptables -t nat -I POSTROUTING 1 -s 192.168.239.0/24 ! -o br-33bf59121eaf -j SNAT --to-source 10.0.7.51
iptables -t nat -D POSTROUTING -s 192.168.238.0/24 ! -o br-c5bbe5b233b7 -j SNAT --to-source 10.0.7.50 2>/dev/null
iptables -t nat -I POSTROUTING 1 -s 192.168.238.0/24 ! -o br-c5bbe5b233b7 -j SNAT --to-source 10.0.7.50
I had to manually create the docker bridge networks with the below commands.
#bridge creation
sudo docker network create --driver=bridge --subnet=192.168.238.0/24 --ip-range=192.168.238.128/25 --gateway=192.168.238.1 --opt com.docker.network.bridge.host_binding_ipv4=10.0.7.50 docker_vlan7_bridge
sudo docker network create --driver=bridge --subnet=192.168.239.0/24 --ip-range=192.168.239.0/24 --gateway=192.168.239.1 --opt com.docker.network.bridge.host_binding_ipv4=10.0.7.51 docker_homeassistant_bridge
It would probably be better to handle this with mac_vlan or some other method, I just haven’t looked into anything else yet as I have been busy with some other things as my setup is mostly around having a single entry point (Nginx Proxy Manager) proxying traffic inside to my containers.
Thank you for sharing your scripts!
I did some tests on my truenas testing VM.
I was able to get containers talk to the Internet with a different IP with this approach:
  • Assign some(*) IP Aliases to the Truenas interface that has access to the Internet.
  • Create a custom bridge with masquerading turned OFF (this prevents any traffic leakage to the Internet until I add a SNAT rule):
docker network create \
  --driver=bridge \
  --subnet=192.168.250.0/24 \
  --opt com.docker.network.bridge.enable_ip_masquerade=false \
  --opt com.docker.network.bridge.host_binding_ipv4=192.168.0.204 \
  custom_bridge
  • And then, in a post-init command (with a long timeout), wait for docker to start and then insert a SNAT rule:
until systemctl --quiet is-active docker; do sleep 1; done ; /sbin/iptables -t nat -I POSTROUTING -s 192.168.250.0/24 ! -o docker0 -j SNAT --to-source 192.168.0.204
(*) Why “some” IP aliases: I noticed that when assigning only 1 or 2 additional IP addresses, sometimes one of those is chosen as the “main” one for outgoing traffic, which would result in other containers (+the nas itself) to go to the Internet with the wrong IP.
I tested this with an alpine docker container that starts on boot and check if there were any leakages on reboot (by capturing on the router), and there were none.
this is the docker compose I used for testing:
version: '3.8'
services:
  ping_container:
    image: alpine
    container_name: always_on_ping
    command: ["sh", "-c", "while true; do ping -i 0.2 -c 5 1.1.1.1; sleep 0.1; done"]
    restart: unless-stopped
    networks:
      - custom_bridge
networks:
  custom_bridge:
    external: true
I also tested macvlan and they work fine, but I like the idea of assigning just 1 IP to a series of containers so I’m sticking to the SNAT approach for now.
It is unfortunate that this is not covered by the TN gui :frowning:
cheers.
I wasn’t aware of the ability to disable masquerading when creating a bridge. That sounds like a much better approach.
LXC is the equivalent of jails and should/does support this afaik.
The docker networking stack is just… Not optimal and not well documented in some places, thats not really an iX fault, actually even for many other docker-container based backends forcing egress through specific adapters for specific pods is troublesome at best.
I am implementing this now and my testing so far shows this is a far better solution than what I originally had. Thank you for sharing.
I may have found an issue with this implementation. In my setup, I have two IPs on the same VLAN on my host that map to different docker bridges. I found that whatever one boots first works, but the other does not. For example, most of my containers are on 10.0.7.50, but I have homeassistant setup on 10.0.7.51 bridge. Everything on 10.0.7.50 routes as expected, but homeassistant shows the binding as 0.0.0.0. While the SNAT iptables rule is applying the proper routing, the docker TCP stack is not sending the traffic on the correct physical interface, so it is forced out the incorrect interface and leads to an asymmetric routing scenario that my firewall doesn’t like because it doesn’t see the source traffic.
I was able to fix it by re-applying some of my routing rules, but this may not be the best fix. Most likely the best fix for my scenario would probably be switching the single homeassistant container over to MACVLAN so the single IP can be dedicated to it.
So, 1 main IP and 2 secondary IPs on same nic, same subnet and same vlan and these 2 secondaries mapped each to a custom bridge?
Something like:
root@truenas[~]# ip a l | grep inet | grep " br0"
    inet 192.168.0.205/24 brd 192.168.0.255 scope global br0
    inet 192.168.0.203/24 brd 192.168.0.255 scope global secondary br0
    inet 192.168.0.202/24 brd 192.168.0.255 scope global secondary br0
    inet 192.168.0.201/24 brd 192.168.0.255 scope global secondary br0
    inet 192.168.0.200/24 brd 192.168.0.255 scope global secondary br0
    inet 192.168.0.204/24 brd 192.168.0.255 scope global secondary br0
I picked .203 and .204 here:
  --driver=bridge \
  --opt com.docker.network.bridge.host_binding_ipv4=192.168.0.203 \
  custom_bridge1
  --driver=bridge \
  --subnet=192.168.251.0/24 \
  custom_bridge2
And then in post-boot script:
until systemctl --quiet is-active docker; do sleep 1; done ; /sbin/iptables -t nat -I POSTROUTING -s 192.168.250.0/24 ! -o docker0 -j SNAT --to-source 192.168.0.203 ; /sbin/iptables -t nat -I POSTROUTING -s 192.168.251.0/24 ! -o docker0 -j SNAT --to-source 192.168.0.204
and then 1 container on each bridge… and their traffic correctly mapped to the expected bridge.
I tried both outgoing and incoming traffic.
To test I used this stack (on portainer):
version: "3.6"
networks:
  custom_bridge1:
    external: true
  custom_bridge2:
    external: true
services:
  netdata203:
    image: "netdata/netdata:v2.5.4"
    environment:
      - "NETDATA_LISTENER_PORT=20489"
      - "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
      - "DEBIAN_FRONTEND=noninteractive"
      - "NETDATA_OFFICIAL_IMAGE=true"
      - "NETDATA_EXTRA_DEB_PACKAGES="
    networks:
      - custom_bridge1
    ports:
      - "192.168.0.203:20489:20489/tcp"
    security_opt:
      - "apparmor=unconfined"
    volumes:
      - "/etc/group:/host/etc/group:ro"
      - "/etc/os-release:/host/etc/os-release:ro"
      - "/etc/passwd:/host/etc/passwd:ro"
      - "/proc:/host/proc:ro"
      - "/sys:/host/sys:ro"
      - "/var/run/docker.sock:/var/run/docker.sock:ro"
  netdata204:
    environment:
    networks:
      - custom_bridge2
    ports:
      - "192.168.0.204:20489:20489/tcp"
    security_opt:
    volumes:
Does it work for you if you do a similar test?
Cheers.
I will have to give that a try. I think because I was only specifying the port instead of host_ip:port, it was binding to 0.0.0.0 and using the wrong host interface, but IPTABLES was forcing it to SNAT to the right IP.
Also, you are specifying as “not docker0” but wouldn’t the custom bridge IDs be something else? So for example, if one was using nginx or npm or some reverse proxy, the SNAT rules would prevent their traffic from working if it was setup on the custom bridge? When I used the IPTABLES rules, I used the custom bridge ID that got created instead of docker0.
Was playing around with this some more today as it stopped working and here is what I came up with. I found that if I don’t also create the rules and routes, the traffic still passed on the internal management network. While this somehow works, it means that containers could more easily access internal network items that they shouldn’t be. I also found that if any network changes are made, the whole thing kind of breaks and needs to be re-applied. At least, that was my experience.
Yes I understand that docker containers are not security boundaries and nor should they be looked at as security boundaries.
So here is my script with the custom rules. My internal management network is 192.168.5.0/24. The 10.0.7.0/24 network is a separate VLAN that I want the host to listen on for the docker bridges. Container traffic outbound should use the 10.0.7.0/24 network and the TrueNAS host for standard management and regular services should use the 192.168.5.0/24 network.
#!/bin/bash
# Do until docker daemon has started. Timeout set on postinit config in truenas
# Enable SNAT for Docker bridge traffic
iptables -t nat -I POSTROUTING -s 192.168.238.0/24 ! -o br-42f14e372c10 -j SNAT --to-source 10.0.7.50
iptables -t nat -I POSTROUTING -s 192.168.239.0/24 ! -o br-384099e0597d -j SNAT --to-source 10.0.7.51
####### Break default bridge docker0 by forcing all traffic to route out 10.0.7.50 as nothing should be using default bridge
iptables -t nat -I POSTROUTING -s 192.168.237.0/24 -j SNAT --to-source 10.0.7.50
#view route table entry
#ip route show table docker_traffic
#iptables -t nat -L -n -v
#bridge creation
#sudo docker network create --driver=bridge --subnet=192.168.238.0/24 --ip-range=192.168.238.128/25 --gateway=192.168.238.1 --opt com.docker.network.bridge.enable_ip_masquerade=false --opt com.docker.network.bridge.host_binding_ipv4=10.0.7.50 docker_vlan7_bridge
#sudo docker network create --driver=bridge --subnet=192.168.239.0/24 --ip-range=192.168.239.0/24 --gateway=192.168.239.1 --opt com.docker.network.bridge.enable_ip_masquerade=false --opt com.docker.network.bridge.host_binding_ipv4=10.0.7.51 docker_homeassistant_bridge
