I do not know exactly how and when it happened but at some point my apps all stopped working and are not starting at all in truenas
This is the error message i get from TureNas:
Critical
Failed to start docker for Applications: Docker service could not be started
This i get when checking in the Shell:
sudo systemctl status docker
[sudo] password for admin:
Γ docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; disabled; preset: disabled)
Drop-In: /etc/systemd/system/docker.service.d
ββoverride.conf
Active: failed (Result: exit-code) since Tue 2024-12-17 00:18:35 CET; 1min 56s ago
TriggeredBy: Γ docker.socket
Process: 12786 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 12786 (code=exited, status=1/FAILURE)
CPU: 699ms
Dec 17 00:18:35 truenas systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Dec 17 00:18:35 truenas systemd[1]: Stopped docker.service - Docker Application Container Engine.
Dec 17 00:18:35 truenas systemd[1]: docker.service: Start request repeated too quickly.
Dec 17 00:18:35 truenas systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 17 00:18:35 truenas systemd[1]: Failed to start docker.service - Docker Application Container Engine.
this i get when digging deeper
sudo journalctl -xe
ββ Subject: Unit process exited
ββ Defined-By: systemd
ββ An ExecStart= process belonging to unit docker.service has exited.
ββ
ββ The process' exit code is 'exited' and its exit status is 1.
Dec 17 00:27:38 truenas systemd[1]: docker.service: Failed with result 'exit-code'.
ββ Subject: Unit failed
ββ The unit docker.service has entered the 'failed' state with result 'exit-code'.
Dec 17 00:27:38 truenas systemd[1]: Failed to start docker.service - Docker Application Container Engine.
ββ Subject: A start job for unit docker.service has failed
ββ A start job for unit docker.service has finished with a failure.
ββ
ββ The job identifier is 3013 and the job result is failed.
Dec 17 00:27:38 truenas sudo[13265]: pam_unix(sudo:session): session closed for user root
Dec 17 00:27:40 truenas systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
ββ Subject: Automatic restarting of a unit has been scheduled
ββ Automatic restarting of the unit docker.service has been scheduled, as the result for
ββ the configured Restart= setting for the unit.
Dec 17 00:27:40 truenas systemd[1]: Stopped docker.service - Docker Application Container Engine.
ββ Subject: A stop job for unit docker.service has finished
ββ A stop job for unit docker.service has finished.
ββ
ββ The job identifier is 3085 and the job result is done.
Dec 17 00:27:40 truenas systemd[1]: Starting docker.service - Docker Application Container Engine...
ββ Subject: A start job for unit docker.service has begun execution
ββ
ββ A start job for unit docker.service has begun execution.
ββ
ββ The job identifier is 3085.
Dec 17 00:27:40 truenas dockerd[13486]: time="2024-12-17T00:27:40.380706306+01:00" level=info msg="Starting up"
Dec 17 00:27:41 truenas dockerd[13486]: time="2024-12-17T00:27:41.515721632+01:00" level=info msg="[graphdriver] trying configured driver: overlay2"
Dec 17 00:27:44 truenas systemd[1]: mnt-.ix\x2dapps-docker-overlay2-metacopy\x2dcheck131454234-merged.mount: Deactivated successfully.
ββ Subject: Unit succeeded
ββ
ββ The unit mnt-.ix\x2dapps-docker-overlay2-metacopy\x2dcheck131454234-merged.mount has successfully entered the 'dead' state.
Dec 17 00:27:45 truenas dockerd[13486]: time="2024-12-17T00:27:45.398698328+01:00" level=info msg="Loading containers: start."
Dec 17 00:27:52 truenas dockerd[13486]: time="2024-12-17T00:27:52.293850161+01:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.16.0>
Dec 17 00:27:52 truenas dockerd[13486]: time="2024-12-17T00:27:52.298282245+01:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>">
Dec 17 00:27:52 truenas dockerd[13486]: failed to start daemon: Error initializing network controller: error creating default "bridge" network: cannot create netwo>
Dec 17 00:27:52 truenas systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
ββ
Dec 17 00:27:52 truenas systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 17 00:27:52 truenas systemd[1]: Failed to start docker.service - Docker Application Container Engine.
ββ
ββ The job identifier is 3085 and the job result is failed.
Dec 17 00:27:54 truenas systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Dec 17 00:27:54 truenas systemd[1]: Stopped docker.service - Docker Application Container Engine.
ββ
ββ The job identifier is 3157 and the job result is done.
Dec 17 00:27:54 truenas systemd[1]: Starting docker.service - Docker Application Container Engine...
ββ
ββ The job identifier is 3157.
Dec 17 00:27:54 truenas dockerd[13699]: time="2024-12-17T00:27:54.377635015+01:00" level=info msg="Starting up"
Dec 17 00:27:59 truenas sudo[13733]: @cee:{"sudo":{"accept":{"uuid":"de4fd32d38-ddb6-45a3-443d-3d30c9625c","server_time":{"seconds":1734391679,"nanoseconds":532238>
Dec 17 00:27:59 truenas sudo[13733]: pam_unix(sudo:session): session opened for user root(uid=0) by admin(uid=950)
as well as
sudo dockerd --debug
INFO[2024-12-17T00:33:23.060292517+01:00] Starting up
DEBU[2024-12-17T00:33:23.060882788+01:00] Listener created for HTTP on unix (/var/run/docker.sock)
DEBU[2024-12-17T00:33:23.066187918+01:00] Golang's threads limit set to 227070
DEBU[2024-12-17T00:33:23.066375343+01:00] metrics API listening on /var/run/docker/metrics.sock
DEBU[2024-12-17T00:33:23.067465501+01:00] Using default logging driver json-file
DEBU[2024-12-17T00:33:23.067558934+01:00] processing event stream module=libcontainerd namespace=plugins.moby
DEBU[2024-12-17T00:33:23.067691178+01:00] No quota support for local volumes in /mnt/.ix-apps/docker/volumes: Filesystem does not support, or has not enabled quotas
INFO[2024-12-17T00:33:24.466594045+01:00] [graphdriver] trying configured driver: overlay2
DEBU[2024-12-17T00:33:26.881576349+01:00] successfully detected metacopy status storage-driver=overlay2 usingMetacopy=false
DEBU[2024-12-17T00:33:27.874100110+01:00] backingFs=zfs, projectQuotaSupported=false, usingMetacopy=false, indexOff="index=off,", userxattr="" storage-driver=overlay2
DEBU[2024-12-17T00:33:27.874165785+01:00] Initialized graph driver overlay2
DEBU[2024-12-17T00:33:27.900884111+01:00] Max Concurrent Uploads: 5
DEBU[2024-12-17T00:33:27.900887304+01:00] Max Download Attempts: 5
INFO[2024-12-17T00:33:27.900895017+01:00] Loading containers: start.
DEBU[2024-12-17T00:33:27.901011904+01:00] processing event stream module=libcontainerd namespace=moby
DEBU[2024-12-17T00:33:27.902408906+01:00] loaded container container=06bff1f83d7e2375e555fb64898dfc0541ff8c7828f964f4253a978bb72435df paused=false running=false
DEBU[2024-12-17T00:33:27.902417159+01:00] loaded container container=b83e25b91be59c985f85dd88cdd734db458480805d654d07b60464270b03ab44 paused=false running=false
DEBU[2024-12-17T00:33:27.902419276+01:00] loaded container container=8c806c6d39e3e08a1f151c31cce87ef47d0d0d763ebd46e0ab7ddd8d338ac396 paused=false running=false
DEBU[2024-12-17T00:33:27.902494724+01:00] loaded container container=35a06b72d4fe0129f55d86c657e48573ee8b2116f928ab1b67b1cacd8e89f1ac paused=false running=false
DEBU[2024-12-17T00:33:27.902503652+01:00] loaded container container=38a941c28b3a344ec85a6616d662c46c643ce2baa8755375ebf0ea8e7921ce77 paused=false running=false
DEBU[2024-12-17T00:33:27.902558040+01:00] loaded container container=0bed7c9899c4d7a2df96fd11d12b7df52dbd8b8bfa666bdaf50c308517abd4a2 paused=false running=false
DEBU[2024-12-17T00:33:27.902589121+01:00] loaded container container=9a615323c8083f8368d9c0a65a6d9aeda22a3e2fcd30cc465839bdb249189057 paused=false running=false
DEBU[2024-12-17T00:33:27.902588948+01:00] loaded container container=39080773c5291db38436170f75c9f38693bded255c83d09d6d0c3659f7deeed3 paused=false running=false
DEBU[2024-12-17T00:33:27.902568929+01:00] loaded container container=f380cb65fb2ca8f48423c95b2477b4d8462c30d7e0c18e9b5203446e4f889557 paused=false running=false
DEBU[2024-12-17T00:33:27.902596714+01:00] loaded container container=ac86969a4a64eaa52ebb0c6a23294cd75d13ae61f39c9024d7202fa51a566665 paused=false running=false
DEBU[2024-12-17T00:33:27.902729555+01:00] loaded container container=aa5d044e4bb05749454d604d76cb8c7d5704c2b21ce203b8d46eb1e6c7c1adc7 paused=false running=false
DEBU[2024-12-17T00:33:27.902769409+01:00] loaded container container=e1221ec2575f26dad59c2805683d82013ef1c8221c1f36ca96448c465c46b1a5 paused=false running=false
DEBU[2024-12-17T00:33:27.902794893+01:00] loaded container container=0644260c98ad6e0abae7627e88d54be2fedde24033b71bab923f2cad0115c622 paused=false running=false
DEBU[2024-12-17T00:33:34.640262646+01:00] restoring container container=e1221ec2575f26dad59c2805683d82013ef1c8221c1f36ca96448c465c46b1a5 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.640326710+01:00] restoring container container=aa5d044e4bb05749454d604d76cb8c7d5704c2b21ce203b8d46eb1e6c7c1adc7 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.640626627+01:00] restoring container container=06bff1f83d7e2375e555fb64898dfc0541ff8c7828f964f4253a978bb72435df paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.640583233+01:00] restoring container container=39080773c5291db38436170f75c9f38693bded255c83d09d6d0c3659f7deeed3 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.640573412+01:00] restoring container container=38a941c28b3a344ec85a6616d662c46c643ce2baa8755375ebf0ea8e7921ce77 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.640889490+01:00] restoring container container=0bed7c9899c4d7a2df96fd11d12b7df52dbd8b8bfa666bdaf50c308517abd4a2 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.640810058+01:00] restoring container container=9a615323c8083f8368d9c0a65a6d9aeda22a3e2fcd30cc465839bdb249189057 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.641651690+01:00] restoring container container=ac86969a4a64eaa52ebb0c6a23294cd75d13ae61f39c9024d7202fa51a566665 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.641775197+01:00] restoring container container=0644260c98ad6e0abae7627e88d54be2fedde24033b71bab923f2cad0115c622 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.641909586+01:00] restoring container container=35a06b72d4fe0129f55d86c657e48573ee8b2116f928ab1b67b1cacd8e89f1ac paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.642676087+01:00] done restoring container container=38a941c28b3a344ec85a6616d662c46c643ce2baa8755375ebf0ea8e7921ce77 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.640851794+01:00] restoring container container=b83e25b91be59c985f85dd88cdd734db458480805d654d07b60464270b03ab44 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.642849808+01:00] done restoring container container=e1221ec2575f26dad59c2805683d82013ef1c8221c1f36ca96448c465c46b1a5 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643056466+01:00] done restoring container container=39080773c5291db38436170f75c9f38693bded255c83d09d6d0c3659f7deeed3 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643232722+01:00] done restoring container container=aa5d044e4bb05749454d604d76cb8c7d5704c2b21ce203b8d46eb1e6c7c1adc7 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.641023373+01:00] restoring container container=8c806c6d39e3e08a1f151c31cce87ef47d0d0d763ebd46e0ab7ddd8d338ac396 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643454309+01:00] done restoring container container=0644260c98ad6e0abae7627e88d54be2fedde24033b71bab923f2cad0115c622 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643574867+01:00] done restoring container container=35a06b72d4fe0129f55d86c657e48573ee8b2116f928ab1b67b1cacd8e89f1ac paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643658180+01:00] done restoring container container=06bff1f83d7e2375e555fb64898dfc0541ff8c7828f964f4253a978bb72435df paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643897227+01:00] done restoring container container=9a615323c8083f8368d9c0a65a6d9aeda22a3e2fcd30cc465839bdb249189057 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643921896+01:00] done restoring container container=b83e25b91be59c985f85dd88cdd734db458480805d654d07b60464270b03ab44 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.643716515+01:00] done restoring container container=ac86969a4a64eaa52ebb0c6a23294cd75d13ae61f39c9024d7202fa51a566665 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.644151757+01:00] done restoring container container=0bed7c9899c4d7a2df96fd11d12b7df52dbd8b8bfa666bdaf50c308517abd4a2 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.645878216+01:00] done restoring container container=8c806c6d39e3e08a1f151c31cce87ef47d0d0d763ebd46e0ab7ddd8d338ac396 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.689211786+01:00] restoring container container=f380cb65fb2ca8f48423c95b2477b4d8462c30d7e0c18e9b5203446e4f889557 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.690132873+01:00] done restoring container container=f380cb65fb2ca8f48423c95b2477b4d8462c30d7e0c18e9b5203446e4f889557 paused=false restarting=false running=false
DEBU[2024-12-17T00:33:34.690328055+01:00] Option DefaultDriver: bridge
DEBU[2024-12-17T00:33:34.690381103+01:00] Option DefaultNetwork: bridge
DEBU[2024-12-17T00:33:34.690395875+01:00] Network Control Plane MTU: 1500
DEBU[2024-12-17T00:33:34.698641915+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION]
DEBU[2024-12-17T00:33:34.702604411+01:00] /sbin/iptables, [--wait -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:34.738262434+01:00] /sbin/iptables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER]
DEBU[2024-12-17T00:33:34.790227290+01:00] /sbin/iptables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:34.794786123+01:00] /sbin/iptables, [--wait -t nat -D PREROUTING]
DEBU[2024-12-17T00:33:34.798623897+01:00] /sbin/iptables, [--wait -t nat -D OUTPUT]
DEBU[2024-12-17T00:33:34.802163008+01:00] /sbin/iptables, [--wait -t nat -F DOCKER]
DEBU[2024-12-17T00:33:34.834273140+01:00] /sbin/iptables, [--wait -t nat -X DOCKER]
DEBU[2024-12-17T00:33:34.889903122+01:00] /sbin/iptables, [--wait -t filter -F DOCKER]
DEBU[2024-12-17T00:33:34.893380219+01:00] /sbin/iptables, [--wait -t filter -X DOCKER]
DEBU[2024-12-17T00:33:34.934275595+01:00] /sbin/iptables, [--wait -t filter -F DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:34.954246268+01:00] /sbin/iptables, [--wait -t filter -X DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:34.974103087+01:00] /sbin/iptables, [--wait -t filter -F DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:34.994194478+01:00] /sbin/iptables, [--wait -t filter -X DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.014207945+01:00] /sbin/iptables, [--wait -t filter -F DOCKER-ISOLATION]
DEBU[2024-12-17T00:33:35.018285837+01:00] /sbin/iptables, [--wait -t filter -X DOCKER-ISOLATION]
DEBU[2024-12-17T00:33:35.021835043+01:00] /sbin/iptables, [--wait -t nat -n -L DOCKER]
DEBU[2024-12-17T00:33:35.025145829+01:00] /sbin/iptables, [--wait -t nat -N DOCKER]
DEBU[2024-12-17T00:33:35.028322304+01:00] /sbin/iptables, [--wait -t filter -n -L DOCKER]
DEBU[2024-12-17T00:33:35.031863093+01:00] /sbin/iptables, [--wait -t filter -n -L DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.035184535+01:00] /sbin/iptables, [--wait -t filter -n -L DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.038459006+01:00] /sbin/iptables, [--wait -t filter -N DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.041383466+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -j RETURN]
DEBU[2024-12-17T00:33:35.045037303+01:00] /sbin/iptables, [--wait -A DOCKER-ISOLATION-STAGE-1 -j RETURN]
DEBU[2024-12-17T00:33:35.048319772+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -j RETURN]
DEBU[2024-12-17T00:33:35.051891749+01:00] /sbin/iptables, [--wait -A DOCKER-ISOLATION-STAGE-2 -j RETURN]
DEBU[2024-12-17T00:33:35.054836890+01:00] /sbin/ip6tables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION]
DEBU[2024-12-17T00:33:35.057955908+01:00] /sbin/ip6tables, [--wait -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.061004916+01:00] /sbin/ip6tables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst ::1/128 -j DOCKER]
DEBU[2024-12-17T00:33:35.064230861+01:00] /sbin/ip6tables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.067448844+01:00] /sbin/ip6tables, [--wait -t nat -D PREROUTING]
DEBU[2024-12-17T00:33:35.070159864+01:00] /sbin/ip6tables, [--wait -t nat -D OUTPUT]
DEBU[2024-12-17T00:33:35.073407248+01:00] /sbin/ip6tables, [--wait -t nat -F DOCKER]
DEBU[2024-12-17T00:33:35.076131669+01:00] /sbin/ip6tables, [--wait -t nat -X DOCKER]
DEBU[2024-12-17T00:33:35.110361599+01:00] /sbin/ip6tables, [--wait -t filter -F DOCKER]
DEBU[2024-12-17T00:33:35.114073402+01:00] /sbin/ip6tables, [--wait -t filter -X DOCKER]
DEBU[2024-12-17T00:33:35.142276300+01:00] /sbin/ip6tables, [--wait -t filter -F DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.186186841+01:00] /sbin/ip6tables, [--wait -t filter -X DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.222304869+01:00] /sbin/ip6tables, [--wait -t filter -F DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.254257544+01:00] /sbin/ip6tables, [--wait -t filter -X DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.290170455+01:00] /sbin/ip6tables, [--wait -t filter -F DOCKER-ISOLATION]
DEBU[2024-12-17T00:33:35.294173005+01:00] /sbin/ip6tables, [--wait -t filter -X DOCKER-ISOLATION]
DEBU[2024-12-17T00:33:35.297975326+01:00] /sbin/ip6tables, [--wait -t nat -n -L DOCKER]
DEBU[2024-12-17T00:33:35.301367522+01:00] /sbin/ip6tables, [--wait -t nat -N DOCKER]
DEBU[2024-12-17T00:33:35.304572207+01:00] /sbin/ip6tables, [--wait -t filter -n -L DOCKER]
DEBU[2024-12-17T00:33:35.308068785+01:00] /sbin/ip6tables, [--wait -t filter -N DOCKER]
DEBU[2024-12-17T00:33:35.311216981+01:00] /sbin/ip6tables, [--wait -t filter -n -L DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.314131851+01:00] /sbin/ip6tables, [--wait -t filter -N DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.316935625+01:00] /sbin/ip6tables, [--wait -t filter -n -L DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.319715581+01:00] /sbin/ip6tables, [--wait -t filter -N DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.322662295+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -j RETURN]
DEBU[2024-12-17T00:33:35.325608410+01:00] /sbin/ip6tables, [--wait -A DOCKER-ISOLATION-STAGE-1 -j RETURN]
DEBU[2024-12-17T00:33:35.328674670+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -j RETURN]
DEBU[2024-12-17T00:33:35.331797389+01:00] /sbin/ip6tables, [--wait -A DOCKER-ISOLATION-STAGE-2 -j RETURN]
DEBU[2024-12-17T00:33:35.334765940+01:00] /sbin/ip6tables, [--wait -t filter -P FORWARD DROP]
DEBU[2024-12-17T00:33:35.371150150+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -s 172.16.0.0/24 ! -o docker0 -j MASQUERADE]
DEBU[2024-12-17T00:33:35.375051472+01:00] /sbin/iptables, [--wait -t nat -C DOCKER -i docker0 -j RETURN]
DEBU[2024-12-17T00:33:35.378512799+01:00] /sbin/iptables, [--wait -t nat -I DOCKER -i docker0 -j RETURN]
DEBU[2024-12-17T00:33:35.381796394+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -m addrtype --src-type LOCAL -o docker0 -j MASQUERADE]
DEBU[2024-12-17T00:33:35.385684334+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i docker0 -o docker0 -j DROP]
DEBU[2024-12-17T00:33:35.389363454+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i docker0 -o docker0 -j ACCEPT]
DEBU[2024-12-17T00:33:35.392858604+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i docker0 ! -o docker0 -j ACCEPT]
DEBU[2024-12-17T00:33:35.396522186+01:00] /sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.399969164+01:00] /sbin/iptables, [--wait -t nat -A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.403137274+01:00] /sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.406599617+01:00] /sbin/iptables, [--wait -t nat -A OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.409972883+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -j DOCKER]
DEBU[2024-12-17T00:33:35.413305744+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -j DOCKER]
DEBU[2024-12-17T00:33:35.416156122+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.419192137+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.422301423+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.425230746+01:00] /sbin/iptables, [--wait -D FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.474059068+01:00] /sbin/iptables, [--wait -I FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.478096762+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.481575317+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.482463882+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP]
DEBU[2024-12-17T00:33:35.483827725+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP]
DEBU[2024-12-17T00:33:35.487107397+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.490579969+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.493695227+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP]
DEBU[2024-12-17T00:33:35.497066476+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP]
DEBU[2024-12-17T00:33:35.500258442+01:00] Network (430bf5d) restored
DEBU[2024-12-17T00:33:35.500500987+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -s 172.16.3.0/24 ! -o br-53ac1cacef23 -j MASQUERADE]
DEBU[2024-12-17T00:33:35.504120490+01:00] /sbin/iptables, [--wait -t nat -C DOCKER -i br-53ac1cacef23 -j RETURN]
DEBU[2024-12-17T00:33:35.507511901+01:00] /sbin/iptables, [--wait -t nat -I DOCKER -i br-53ac1cacef23 -j RETURN]
DEBU[2024-12-17T00:33:35.510751191+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -m addrtype --src-type LOCAL -o br-53ac1cacef23 -j MASQUERADE]
DEBU[2024-12-17T00:33:35.514459067+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-53ac1cacef23 -o br-53ac1cacef23 -j DROP]
DEBU[2024-12-17T00:33:35.517947845+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-53ac1cacef23 -o br-53ac1cacef23 -j ACCEPT]
DEBU[2024-12-17T00:33:35.521548153+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-53ac1cacef23 ! -o br-53ac1cacef23 -j ACCEPT]
DEBU[2024-12-17T00:33:35.525026461+01:00] /sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.528750423+01:00] /sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.532251050+01:00] /sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.535676728+01:00] /sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.539235826+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-53ac1cacef23 -j DOCKER]
DEBU[2024-12-17T00:33:35.543096174+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-53ac1cacef23 -j DOCKER]
DEBU[2024-12-17T00:33:35.546784365+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-53ac1cacef23 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.550471373+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-53ac1cacef23 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.553997162+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.557177416+01:00] /sbin/iptables, [--wait -D FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.610102155+01:00] /sbin/iptables, [--wait -I FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.614108813+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i br-53ac1cacef23 ! -o br-53ac1cacef23 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.618073845+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i br-53ac1cacef23 ! -o br-53ac1cacef23 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.621883198+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o br-53ac1cacef23 -j DROP]
DEBU[2024-12-17T00:33:35.625123726+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o br-53ac1cacef23 -j DROP]
DEBU[2024-12-17T00:33:35.628493445+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i br-53ac1cacef23 ! -o br-53ac1cacef23 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.632113218+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i br-53ac1cacef23 ! -o br-53ac1cacef23 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.635288653+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o br-53ac1cacef23 -j DROP]
DEBU[2024-12-17T00:33:35.638767566+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o br-53ac1cacef23 -j DROP]
DEBU[2024-12-17T00:33:35.642156155+01:00] Network (53ac1ca) restored
DEBU[2024-12-17T00:33:35.642395539+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -s 172.16.1.0/24 ! -o br-ba97ada10526 -j MASQUERADE]
DEBU[2024-12-17T00:33:35.646115076+01:00] /sbin/iptables, [--wait -t nat -C DOCKER -i br-ba97ada10526 -j RETURN]
DEBU[2024-12-17T00:33:35.649409595+01:00] /sbin/iptables, [--wait -t nat -I DOCKER -i br-ba97ada10526 -j RETURN]
DEBU[2024-12-17T00:33:35.652418468+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -m addrtype --src-type LOCAL -o br-ba97ada10526 -j MASQUERADE]
DEBU[2024-12-17T00:33:35.656067421+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-ba97ada10526 -o br-ba97ada10526 -j DROP]
DEBU[2024-12-17T00:33:35.659762927+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-ba97ada10526 -o br-ba97ada10526 -j ACCEPT]
DEBU[2024-12-17T00:33:35.663296727+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-ba97ada10526 ! -o br-ba97ada10526 -j ACCEPT]
DEBU[2024-12-17T00:33:35.666861184+01:00] /sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.670294374+01:00] /sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.673658139+01:00] /sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.677079238+01:00] /sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.680425126+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-ba97ada10526 -j DOCKER]
DEBU[2024-12-17T00:33:35.684008042+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-ba97ada10526 -j DOCKER]
DEBU[2024-12-17T00:33:35.687510577+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-ba97ada10526 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.691189118+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-ba97ada10526 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.694772017+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.697959810+01:00] /sbin/iptables, [--wait -D FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.734207196+01:00] /sbin/iptables, [--wait -I FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.738147516+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i br-ba97ada10526 ! -o br-ba97ada10526 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.742266244+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i br-ba97ada10526 ! -o br-ba97ada10526 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.745782465+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o br-ba97ada10526 -j DROP]
DEBU[2024-12-17T00:33:35.749196241+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o br-ba97ada10526 -j DROP]
DEBU[2024-12-17T00:33:35.752019164+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i br-ba97ada10526 ! -o br-ba97ada10526 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.755431519+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i br-ba97ada10526 ! -o br-ba97ada10526 -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.758606113+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o br-ba97ada10526 -j DROP]
DEBU[2024-12-17T00:33:35.761913057+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o br-ba97ada10526 -j DROP]
DEBU[2024-12-17T00:33:35.765196353+01:00] Network (ba97ada) restored
DEBU[2024-12-17T00:33:35.765513305+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -s 172.16.2.0/24 ! -o br-bbdfd66d8fbe -j MASQUERADE]
DEBU[2024-12-17T00:33:35.768813279+01:00] /sbin/iptables, [--wait -t nat -C DOCKER -i br-bbdfd66d8fbe -j RETURN]
DEBU[2024-12-17T00:33:35.772152937+01:00] /sbin/iptables, [--wait -t nat -I DOCKER -i br-bbdfd66d8fbe -j RETURN]
DEBU[2024-12-17T00:33:35.775218804+01:00] /sbin/iptables, [--wait -t nat -C POSTROUTING -m addrtype --src-type LOCAL -o br-bbdfd66d8fbe -j MASQUERADE]
DEBU[2024-12-17T00:33:35.778762924+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-bbdfd66d8fbe -o br-bbdfd66d8fbe -j DROP]
DEBU[2024-12-17T00:33:35.782230513+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-bbdfd66d8fbe -o br-bbdfd66d8fbe -j ACCEPT]
DEBU[2024-12-17T00:33:35.785878363+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -i br-bbdfd66d8fbe ! -o br-bbdfd66d8fbe -j ACCEPT]
DEBU[2024-12-17T00:33:35.789528086+01:00] /sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.792979386+01:00] /sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2024-12-17T00:33:35.796587209+01:00] /sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.800021803+01:00] /sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]
DEBU[2024-12-17T00:33:35.803412099+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-bbdfd66d8fbe -j DOCKER]
DEBU[2024-12-17T00:33:35.806961467+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-bbdfd66d8fbe -j DOCKER]
DEBU[2024-12-17T00:33:35.810537150+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-bbdfd66d8fbe -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.814108652+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -o br-bbdfd66d8fbe -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]
DEBU[2024-12-17T00:33:35.817654942+01:00] /sbin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.820794291+01:00] /sbin/iptables, [--wait -D FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.854297843+01:00] /sbin/iptables, [--wait -I FORWARD -j DOCKER-ISOLATION-STAGE-1]
DEBU[2024-12-17T00:33:35.858160233+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i br-bbdfd66d8fbe ! -o br-bbdfd66d8fbe -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.862219882+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i br-bbdfd66d8fbe ! -o br-bbdfd66d8fbe -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.865715817+01:00] /sbin/ip6tables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o br-bbdfd66d8fbe -j DROP]
DEBU[2024-12-17T00:33:35.868962311+01:00] /sbin/ip6tables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o br-bbdfd66d8fbe -j DROP]
DEBU[2024-12-17T00:33:35.872014932+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-1 -i br-bbdfd66d8fbe ! -o br-bbdfd66d8fbe -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.875361598+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-1 -i br-bbdfd66d8fbe ! -o br-bbdfd66d8fbe -j DOCKER-ISOLATION-STAGE-2]
DEBU[2024-12-17T00:33:35.878326585+01:00] /sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION-STAGE-2 -o br-bbdfd66d8fbe -j DROP]
DEBU[2024-12-17T00:33:35.881513720+01:00] /sbin/iptables, [--wait -t filter -I DOCKER-ISOLATION-STAGE-2 -o br-bbdfd66d8fbe -j DROP]
DEBU[2024-12-17T00:33:35.884624199+01:00] Network (bbdfd66) restored
DEBU[2024-12-17T00:33:35.884912456+01:00] Endpoint (960ba03) restored to network (ba97ada)
DEBU[2024-12-17T00:33:35.885871098+01:00] Allocating IPv4 pools for network ix-nextcloud_default (53ac1cacef23e988588548a9c4590e196dfad33077caf8493babda220b30ab80)
DEBU[2024-12-17T00:33:35.886145212+01:00] RequestPool: {AddressSpace:LocalDefault Pool:172.16.3.0/24 SubPool: Options:map[] Exclude:[172.16.0.0/24 172.16.1.0/24 172.16.2.0/24 172.16.3.0/24 192.168.255.0/24 192.168.255.1/32] V6:false}
DEBU[2024-12-17T00:33:35.886494020+01:00] RequestAddress(LocalDefault/172.16.3.0/24, 172.16.3.1, map[RequestAddressType:com.docker.network.gateway])
DEBU[2024-12-17T00:33:35.886831190+01:00] Request address PoolID:172.16.3.0/24 Bits: 256, Unselected: 254, Sequence: (0x80000000, 1)->(0x0, 6)->(0x1, 1)->end Curr:0 Serial:false PrefAddress:172.16.3.1
DEBU[2024-12-17T00:33:35.886871296+01:00] Allocating IPv4 pools for network ix-immich_default (ba97ada10526bfe35b657bc7cde827794d19aa061fe07378dfdf5bf73dd97fec)
DEBU[2024-12-17T00:33:35.887038830+01:00] RequestPool: {AddressSpace:LocalDefault Pool:172.16.1.0/24 SubPool: Options:map[] Exclude:[172.16.0.0/24 172.16.1.0/24 172.16.2.0/24 172.16.3.0/24 192.168.255.0/24 192.168.255.1/32] V6:false}
DEBU[2024-12-17T00:33:35.887070264+01:00] RequestAddress(LocalDefault/172.16.1.0/24, 172.16.1.1, map[RequestAddressType:com.docker.network.gateway])
DEBU[2024-12-17T00:33:35.887097875+01:00] Request address PoolID:172.16.1.0/24 Bits: 256, Unselected: 254, Sequence: (0x80000000, 1)->(0x0, 6)->(0x1, 1)->end Curr:0 Serial:false PrefAddress:172.16.1.1
DEBU[2024-12-17T00:33:35.887128820+01:00] Allocating IPv4 pools for network ix-plex_default (bbdfd66d8fbe3e4a91ce2776964e9191aaf8ca27b761c6fd1dbb2a8fc3f5a15f)
DEBU[2024-12-17T00:33:35.887256727+01:00] RequestPool: {AddressSpace:LocalDefault Pool:172.16.2.0/24 SubPool: Options:map[] Exclude:[172.16.0.0/24 172.16.1.0/24 172.16.2.0/24 172.16.3.0/24 192.168.255.0/24 192.168.255.1/32] V6:false}
DEBU[2024-12-17T00:33:35.887283796+01:00] RequestAddress(LocalDefault/172.16.2.0/24, 172.16.2.1, map[RequestAddressType:com.docker.network.gateway])
DEBU[2024-12-17T00:33:35.887306941+01:00] Request address PoolID:172.16.2.0/24 Bits: 256, Unselected: 254, Sequence: (0x80000000, 1)->(0x0, 6)->(0x1, 1)->end Curr:0 Serial:false PrefAddress:172.16.2.1
INFO[2024-12-17T00:33:35.887736028+01:00] Default bridge (docker0) is assigned with an IP address 172.16.0.0/24. Daemon option --bip can be used to set a preferred IP address
DEBU[2024-12-17T00:33:35.887793701+01:00] Allocating IPv4 pools for network bridge (887fdea20c91edfef0264b0938daebf2384b021cccee1939bf749b2ee628366e)
DEBU[2024-12-17T00:33:35.887932061+01:00] RequestPool: {AddressSpace:LocalDefault Pool:172.16.0.0/24 SubPool: Options:map[] Exclude:[172.16.0.0/24 172.16.1.0/24 172.16.2.0/24 172.16.3.0/24 192.168.255.0/24 192.168.255.1/32] V6:false}
DEBU[2024-12-17T00:33:35.887961160+01:00] RequestAddress(LocalDefault/172.16.0.0/24, 172.16.0.1, map[RequestAddressType:com.docker.network.gateway])
DEBU[2024-12-17T00:33:35.887984854+01:00] Request address PoolID:172.16.0.0/24 Bits: 256, Unselected: 254, Sequence: (0x80000000, 1)->(0x0, 6)->(0x1, 1)->end Curr:0 Serial:false PrefAddress:172.16.0.1
DEBU[2024-12-17T00:33:35.888140129+01:00] releasing IPv4 pools from network bridge (887fdea20c91edfef0264b0938daebf2384b021cccee1939bf749b2ee628366e)
DEBU[2024-12-17T00:33:35.888157112+01:00] ReleaseAddress(LocalDefault/172.16.0.0/24, 172.16.0.1)
DEBU[2024-12-17T00:33:35.888179636+01:00] Released address Address:172.16.0.1 Sequence:Bits: 256, Unselected: 254, Sequence: (0x80000000, 1)->(0x0, 6)->(0x1, 1)->end Curr:0
DEBU[2024-12-17T00:33:35.888194148+01:00] ReleasePool(LocalDefault/172.16.0.0/24)
DEBU[2024-12-17T00:33:35.888231714+01:00] daemon configured with a 15 seconds minimum shutdown timeout
DEBU[2024-12-17T00:33:35.888536264+01:00] start clean shutdown of all containers with a 15 seconds timeout...
DEBU[2024-12-17T00:33:35.891935454+01:00] Unix socket /var/run/docker/libnetwork/8e8a96f415fd.sock was closed. The external key listener will stop.
DEBU[2024-12-17T00:33:35.892455047+01:00] Cleaning up old mountid : start.
INFO[2024-12-17T00:33:35.892560052+01:00] stopping event stream following graceful shutdown error="<nil>" module=libcontainerd namespace=moby
DEBU[2024-12-17T00:33:35.893808528+01:00] Cleaning up old mountid : done.
failed to start daemon: Error initializing network controller: error creating default "bridge" network: cannot create network 887fdea20c91edfef0264b0938daebf2384b021cccee1939bf749b2ee628366e (docker0): conflicts with network 430bf5d56cfbe36013e031aa964b698d98c871f9221fb0e66da3221cac8253c1 (docker0): networks have same bridge name
INFO[2024-12-17T00:33:35.894951868+01:00] stopping event stream following graceful shutdown error="context canceled" module=libcontainerd namespace=plugins.moby
im running a setup with a i5-12500 and 32GB of ram no dedicated GPU
All storage devices physical and virtual do not exceed 78% usage at the most
What i already tried:
several restarts
Unset and set the pool
run this script:
midclt call -job docker.update '{"address_pools": [{"base": "172.17.0.0/12", "size": 24}]}' -
delete the
/etc/docker/daemom.jsonfile (this seemed to work for a second and showed a started docker in the shell but no active apps or anything and after a restart it failed again and repeting the process does not seem to work anymore) -
i even reverted to an older boot enviroment thatr for sure worked and even in the older boot enviroment the docker service did not start
then i tried to update the older boot enviroment and it still behaves the same
Doese anyone have an idea what i can do ?
Id rather not deal with reinstalling the apps or even TrueNas if it can be avoided.
Edit:
i tried a few steps again to see if maybe something changed ot of sheer luck and i found the following
after now again deleting daemon.json I was able to restart docker from the shell:
β docker.service - Docker Application Container Engine
ββoverride.conf
Active: active (running) since Tue 2024-12-17 15:24:42 CET; 9s ago
TriggeredBy: β docker.socket
Docs: Process: 9371 ExecStartPost=/bin/sh -c iptables -P FORWARD ACCEPT && ip6tables -P FORWARD ACCEPT (code=exited, status=0/SUCCESS)
Main PID: 8573 (dockerd)
Tasks: 44
Memory: 48.7M
CPU: 789ms
CGroup: /system.slice/docker.service
ββ8573 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
ββ8817 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 32014 -container-ip 172.17.0.2 -container-port 8081
ββ8840 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 32015 -container-ip 172.17.0.2 -container-port 32015
ββ8847 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 32016 -container-ip 172.17.0.2 -container-port 32016
Dec 17 15:24:36 truenas systemd[1]: Starting docker.service - Docker Application Container Engine...
Dec 17 15:24:36 truenas dockerd[8573]: time="2024-12-17T15:24:36.726491890+01:00" level=info msg="Starting up"
Dec 17 15:24:36 truenas dockerd[8573]: time="2024-12-17T15:24:36.762159576+01:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Dec 17 15:24:36 truenas dockerd[8573]: time="2024-12-17T15:24:36.769198251+01:00" level=info msg="Loading containers: start."
Dec 17 15:24:37 truenas dockerd[8573]: time="2024-12-17T15:24:37.989718519+01:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.16.0.0/24. Daemon option --bip can be used to set a preferred IP address"
Dec 17 15:24:38 truenas dockerd[8573]: time="2024-12-17T15:24:38.601229420+01:00" level=info msg="Loading containers: done."
Dec 17 15:24:41 truenas dockerd[8573]: time="2024-12-17T15:24:41.973447667+01:00" level=info msg="Docker daemon" commit=cc13f95 containerd-snapshotter=false storage-driver=overlay2 version=27.1.1
Dec 17 15:24:41 truenas dockerd[8573]: time="2024-12-17T15:24:41.974312083+01:00" level=info msg="Daemon has completed initialization"
Dec 17 15:24:42 truenas dockerd[8573]: time="2024-12-17T15:24:42.009006113+01:00" level=info msg="API listen on /run/docker.sock"
Dec 17 15:24:42 truenas systemd[1]: Started docker.service - Docker Application Container Engine.
but still none of my apps were visible in the gui so i tried to install a new app (calibre) and while it showed an successful install still nothing in the GUI so I checked docker in the shell and found that only calibre is running and nither plex or any other app is running
sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
14867f46ba61 lscr.io/linuxserver/calibre:7.22.0 "/init" 8 minutes ago Up 17 seconds (healthy) 3000-3001/tcp, 0.0.0.0:32015-32016->32015-32016/tcp, 0.0.0.0:32014->8081/tcp ix-calibre-calibre-1
so i attempted a restart and nothing worked anymore and i had to again delete daemon.json to even restart docker in the shell
