Since upgrading to Dragonfish, I’ve noticed that the Apps UI has becomes very glitchy. It seems to constantly refresh itself with flickering (gives a headache after a while tbh), and it is impossible to view Kubernetes events properly because the scrolling is reset every second.
Is this a known issue or should I file a bug report?
Workloads view also only shows stats for a split second:
You should file a bug report.
