Bare Metal Install Issues
Since this cannot be flashed to IT mode (AFAIK) is this still an issue?
Indeed it looks like you removed the one which was already flashed to IT mode instead:
Wow, odd - the drives are still showing up as connected to the “onboard” controller, and the pool appears healthy in TrueNAS. I will confirm the controller mode in iDRAC and see what I can see.
But also interesting - I wonder if that means I could use that external card to connect an SC220 enclosure if I wanted
Yup, looks like the controller is still correctly reporting HBA mode (PERC H730)
Again the H730 works in my setup in HBA mode flawlessly .
Knowing that extra SAS controller is already flashed to IT mode is great to know too - depending on the testing I’ll do this weekend, I might test functionality there too :).
