I know this was possible under Core in the Advanced options in GRUB, but how could I force to boot my TrueNAS Scale install without trying to address or mount the zPool ?
I have some nVME disks that have failed not only causing the pool to be degraded/offline, but also causes the machine to hang while booting resulting in a kernel panic.
I would like to get into the Truenas install and then try to import the pool in read-only with a combination of disks to try to recover as much data as possible.
It was a 4 disk pool consisting of a stripe of 2 mirrored vDEVs, so normally 1 disk per VDEV could fail, my I guess I got lucky (sarcasticly speaking) and two disks in the same VDEV failed.
I learned my lesson of trying to use consumer grade disks… Will replace them by either SATA/SAS enterprise SSDs with power loss protection with an NVME LOG (U.2 or U.3) VDEV and NVME Cache or outright 4 enterprise NVME disks without a LOG.
I was using this appliance as a SAN for my VMs, mounted the storage via iSCSI to a VMWARE cluster via 2* 40 Gbit NICs…
Any other ideas/suggestions are also welcome regarding to the data recovery.
EDIT: I know it is the disks, because I am able to boot into Truenas with only the 2 good disks installed. I verified the slots also, it is really the disks.
