as you can see in the photo i can not load the install i’ve disabled everything i can for secure boot or boot security even legacy bios i can’t get anywhere. maybe if i knew how to load the kernel from shell
thank you for your time
ok the issue was improper download of image should be 1.3 gigs
i was only getting 100 megas to 800megs but firefox said download completed and didn’t remember the download size.
ok that part is figured out yea some reason the download kept failing before the whole thing was done but some how i was able to image it.
this time the download did not fail and liked that i was able to use dd mode in rufus. but will be giving ventoy a try.
