today I cleaned my NAS PC, after booting the pool called tank disapeard. I tried to import the pool in the GUI, but just got the error message: “[EZFS_IO] Failed to import ‘tank’ pool: cannot import ‘tank’ as ‘tank’: I/O error”.
Under more Info is written:
` Error: concurrent.futures.process._RemoteTraceback:
File “/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py”, line 438, in import_pool
zfs.import_pool(found, pool_name, properties, missing_log=missing_log, any_host=any_host)
File “libzfs.pyx”, line 1265, in libzfs.ZFS.import_pool
File “libzfs.pyx”, line 1293, in libzfs.ZFS.__import_pool
libzfs.ZFSException: cannot import ‘tank’ as ‘tank’: I/O error
File “/usr/lib/python3.9/concurrent/futures/process.py”, line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File “/usr/lib/python3/dist-packages/middlewared/worker.py”, line 115, in main_worker
res = MIDDLEWARE._run(*call_args)
File “/usr/lib/python3/dist-packages/middlewared/worker.py”, line 46, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File “/usr/lib/python3/dist-packages/middlewared/worker.py”, line 40, in _call
return methodobj(*params)
File “/usr/lib/python3/dist-packages/middlewared/schema.py”, line 1383, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py”, line 444, in import_pool
self.logger.error(
File “libzfs.pyx”, line 465, in libzfs.ZFS.exit
File “/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py”, line 442, in import_pool
raise CallError(f’Failed to import {pool_name!r} pool: {e}', e.code)
middlewared.service_exception.CallError: [EZFS_IO] Failed to import ‘tank’ pool: cannot import ‘tank’ as ‘tank’: I/O error
The above exception was the direct cause of the following exception:
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 427, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 465, in __run_body
File “/usr/lib/python3/dist-packages/middlewared/schema.py”, line 1379, in nf
File “/usr/lib/python3/dist-packages/middlewared/schema.py”, line 1247, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/pool.py”, line 1459, in import_pool
await self.middleware.call(‘zfs.pool.import_pool’, guid, opts, any_host, use_cachefile, new_name)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1368, in call
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1325, in _call
return await self._call_worker(name, *prepared_call.args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1331, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1246, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1231, in run_in_executor
middlewared.service_exception.CallError: [EZFS_IO] Failed to import ‘tank’ pool: cannot import ‘tank’ as ‘tank’: I/O error`
I googled the error and found the way of importing in CLI with zpool. When I tryed to import the following error came up:
I even tried with -fF but still the same error. What could I do to get the pool back online?
