Hey everyone. I’m running into this problem with truenas vdev extending. I get this error of [EFAULT] [Errno 6] No such device or address: '/dev/sdh' when trying to expand. I’ve expanded my vdev before no problem but I’ve never ran into this issue before. I’m also thinking it’s because there is currently a resilvering happening and another drive that is in progress to also be added to the vdev. But I’ve extended multiple drives concurrently before with no issue. Is this a hardware failure? When I expand for more info it gives me this:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 560, in __run_body
rv = await self.method(*args)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 174, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 48, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/attach_disk.py", line 78, in attach
await self.middleware.call('pool.format_disks', job, disks, 5, 20)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1005, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 720, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disks
await asyncio_map(unlock_and_format_disk, disks.items(), limit=16)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 19, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 16, in func
return await real_func(arg)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 24, in unlock_and_format_disk
await self.middleware.call('disk.format', disk, config.get('size'))
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 731, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 624, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/format.py", line 33, in format
self.middleware.call_sync('disk.wipe', disk, 'QUICK', False).wait_sync(raise_error=True)
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 487, in wait_sync
raise CallError(self.error)
middlewared.service_exception.CallError: [EFAULT] [Errno 6] No such device or address: '/dev/sdh'
Thanks!
