Is there any reason I would be getting this error when trying to pass through an Intel Audio device to a VM running on TrueNAS SCALE 24 Dragonfish?
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 182, in start
if self.domain.create() < 0:
File "/usr/lib/python3/dist-packages/libvirt.py", line 1373, in create
raise libvirtError('virDomainCreate() failed')
libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2024-04-25T19:01:41.670757Z qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:00:1b.0","id":"hostdev0","bus":"pci.0","addr":"0x8"}: vfio 0000:00:1b.0: failed to setup container for group 11: Failed to set iommu for container: Operation not permitted
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 198, in call_method
result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1466, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1417, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 187, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 47, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 58, in start
await self.middleware.run_in_thread(self._start, vm['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1324, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1321, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 68, in _start
self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name))
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 191, in start
raise CallError('\n'.join(errors))
middlewared.service_exception.CallError: [EFAULT] internal error: qemu unexpectedly closed the monitor: 2024-04-25T19:01:41.670757Z qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:00:1b.0","id":"hostdev0","bus":"pci.0","addr":"0x8"}: vfio 0000:00:1b.0: failed to setup container for group 11: Failed to set iommu for container: Operation not permitted
The device is
0000:00:1b.0 ‘Audio device’: 82801JI (ICH10 Family) HD Audio Controller by ‘Intel Corporation’
