This is my first post, and I’m not entirely sure if I’m following the correct procedure, so please let me know if I need to provide more information. Also, English is not my first language, so I apologize if there are any mistakes.
I recently expanded my pool from 3×12 TB to 9×12 TB in a single RAIDZ1 configuration, but the system only reports about 65.28 TB of usable space. Could you please confirm whether this is normal behavior? If this is expected, any guidance on how the final usable capacity is calculated or best practices to optimize the storage would be greatly appreciated.
pool: DATA
state: ONLINE
scan: resilvered 988M in 00:00:06 with 0 errors on Sat Feb 8 20:47:36 2025
expand: expanded raidz1-0 copied 69.2T in 5 days 02:51:54, on Sat Oct 26 12:17:11 2024
NAME STATE READ WRITE CKSUM
DATA ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
1445e11f-5ee5-4f22-a97c-0d4d3bdfcda2 ONLINE 0 0 0
8ab510e3-713b-467e-84f2-27de4bb97008 ONLINE 0 0 0
1d481850-2ae7-46a8-890b-848466ad7b58 ONLINE 0 0 0
7451163e-bc0a-4f38-8d3c-014fb6c13901 ONLINE 0 0 0
3b215c29-3d55-406f-94a5-6cbf5c4fb773 ONLINE 0 0 0
5f455019-0ade-47af-a6be-7fc7dcb847b9 ONLINE 0 0 0
2be2314b-f882-4a4a-acee-85075717ef7a ONLINE 0 0 0
196cc14e-1320-459d-8236-2f942cad2f54 ONLINE 0 0 0
14fd2d0e-4aaf-4b98-9697-8af0e21b4d66 ONLINE 0 0 0
errors: No known data errors
zfs get all DATA
NAME PROPERTY VALUE SOURCE
DATA type filesystem -
DATA creation Sun Apr 30 18:25 2023 -
DATA used 60.0T -
DATA available 5.32T -
DATA referenced 139K -
DATA compressratio 1.00x -
DATA mounted yes -
DATA quota none default
DATA reservation none default
DATA recordsize 128K default
DATA mountpoint /mnt/DATA default
DATA sharenfs off local
DATA checksum on default
DATA compression lz4 local
DATA atime off local
DATA devices on default
DATA exec on default
DATA setuid on default
DATA readonly off default
DATA zoned off default
DATA snapdir hidden default
DATA aclmode discard local
DATA aclinherit discard local
DATA createtxg 1 -
DATA canmount on default
DATA xattr on default
DATA copies 1 default
DATA version 5 -
DATA utf8only off -
DATA normalization none -
DATA casesensitivity sensitive -
DATA vscan off default
DATA nbmand off default
DATA sharesmb off local
DATA refquota none default
DATA refreservation none default
DATA guid 565392711373990559 -
DATA primarycache all default
DATA secondarycache all default
DATA usedbysnapshots 0B -
DATA usedbydataset 139K -
DATA usedbychildren 60.0T -
DATA usedbyrefreservation 0B -
DATA logbias latency default
DATA objsetid 54 -
DATA dedup off default
DATA mlslabel none default
DATA sync standard default
DATA dnodesize legacy default
DATA refcompressratio 1.00x -
DATA written 139K -
DATA logicalused 74.9T -
DATA logicalreferenced 46K -
DATA volmode default default
DATA filesystem_limit none default
DATA snapshot_limit none default
DATA filesystem_count none default
DATA snapshot_count none default
DATA snapdev hidden default
DATA acltype posix local
DATA context none default
DATA fscontext none default
DATA defcontext none default
DATA rootcontext none default
DATA relatime on default
DATA redundant_metadata all default
DATA overlay on default
DATA encryption off default
DATA keylocation none default
DATA keyformat none default
DATA pbkdf2iters 0 default
DATA special_small_blocks 0 default
DATA prefetch all default
Thank you for your response! If I understand correctly, this behavior is normal and it’s just the interface displaying some unexpected values, but the actual capacity is accurate. I appreciate your clarification.
