Electric Eel, NextCloud App, NGINX proxy. All working. However, I did a stupid thing and pointed the user data directory to an internal ixVolume. I now can’t change this option. Is there a way, or do I need to remove and re-install? I’d hate to do that, but I don’t see any other way.
Thanks,
Kelly
DjP-iX
November 8, 2024, 5:29pm
You will have to reinstall. You cannot change from ixvolumes to host paths on an existing installation
Well, I removed the app. Now, trying to re-install it and it fails with
[2024/11/08 16:13:49] (ERROR) app_lifecycle.compose_action():56 - Failed ‘up’ action for ‘nextcloud’ app: Network ix-nextcloud_default Creating
Network ix-nextcloud_default Created
Container ix-nextcloud-permissions-1 Creating
time=“2024-11-08T16:13:49-05:00” level=warning msg=“config uid
, gid
and mode
are not supported, they will be ignored”
, gid
and mode
Error response from daemon: invalid mount config for type “bind”: bind source path does not exist: /mnt/.ix-apps/app_mounts/nextcloud/postgres_data
I think that some of the old install is still there. How do I forcfully remove it? Migrate the apps to a different volume and then back?
I figured it out. I am such a dope. The new dataset I created for data storage was set to ReadOnly. SMH.
