Hi;
I’ve got a fresh install of Cobia 23.10.2 on Supermicro hardware with a single pool of mirrored disks. I’ve created a dataset on that pool. In the shell zfs list shows “pool0/op-nas3-4”. In the UI the ist is empty. Why?
Hi;
Is this an upgrade installation or the first ever install?
Did you try clearing the browser cache?
It’s a fresh install on empty sdds/hard disks, the system hasn’t bseen any updates.
I’ve cleared the browser cache - nothing changes.
Did you create the pool/dataset using the UI or the cli?
Problem solved by updating the browser.
Thanks anyway.
