Compression Ratio vanished in SCALE?
Hi All,
Am I being blind or has the compression ratio for your pool and individual datasets vanished from the UI in SCALE?
Personally I think compression is one of the best things about ZFS so it seems a massive oversight to hide these potentially massive benefits from the end-user?
I can see if Atime is enabled or not from the Dataset Home Screen but not my compression ratio, surely that would be more useful information to the average user?
I would even go one step further and have a nice graphic on the dashboard that shows you how much space you’re saving on compression alone.
I don’t see it anywhere when looking.
On Storage tab, Usage section, the link for View Disk Space Reports just brings up the disk reports for temp and disk I/O. No other options to choose.
Dragonfish-24.04.2
I haven’t upgraded my pool features to Scale from running Core, either. I don’t know if that makes any difference
Thanks not just me then. I can’t see a zpool upgrade changing anything.
Not present in SCALE.
Want to make a Feature Request for it to be added?
Nah I’ll just stay with CORE :metal::rofl:
badger fine i'll do it myself
https://forums.truenas.com/t/add-compression-and-dedup-ratio-to-scale-ui/10119/1
Bravo :clap:t2: my friend :blue_heart:
Obviously available on command line, but, not seeing it for Scale UI.
Via cli, you can, for those who may not know but might want to do cli:
zfs list -r -o name,compressratio tank
