Hi all! I have a very basic setup for simple local home use. 1 SSD to boot and 1 HDD to store data. (I know it’s not redundant but I don’t require high availability, at least not for now.) My concern is that the HDD constantly works and it’s loud. I don’t move any data, no apps are running, this is a vanilla Scale install so far, yet the HDD is in constant work. I moved the system dataset to the boot pool. I set power mode to Idle and advanced power management to the lowest setting (1) which should spin down the disk after 5 mins. (I know this can be problematic, I just want to set a baseline quietness and work up to an optimum setting from there.)
One more thing. I have a 2GB SWAP on both the SSD and the HDD. This was the default. I obviously don’t want the swap on the HDD. How can I remove that? Although it’s empty, so this is probably not the source of the constant HDD noise.
What causes the constant load on the disk? What else can I do for quietness? Thanks for the help!
For quietness, a noise reducing case, move it somewhere else, quieter drives, maybe SSD instead of hard drives, etc. The system is never idle really, it’s a server. Background tasks are always running and logging.
Yeah, it’s not helping, thanks. These are fairly obvious semi-solutions that are (fairly obviously) either already implemented or out of the question. I’m looking for a software solution, if possible, to make the HDD idling for most of the time when there is no load.
For the sake of completeness. The server is behind a soundproofed door, in a noise dampening case. It’s a datacenter drive, very loud, so it’s still audible. Replacing the drive is financially out of the question.
I moved my Scale server into the next room, laundry room, just so it’s out of sight. My Seagate Exos enterprise drives make almost 0 noise actually. Even standing next to it, I can’t really hear it. I guess it depends on the drives, but don’t think you’ll find any software solution. I suppose you could turn it off when not in use.
It’s hard to imagine why your drives are that loud!
I also set the tunable vfs.zfs.txg.timeout to a somewhat large value so the regular syncs don’t happen every 5 seconds.
I would still recommend against idling your drive as that reduces longevity. Keeping it spinning but not accessing data is safer.
I had a unit with some rather noisy Toshibas and this helped quite a bit; just know that naturally this puts more risk on your already quite risky setup. Just be aware of your footguns and if that’s acceptable go for it.
Thanks Tsaukpaetra! How can I set this value on the Truenas interface?
However, I found the culprit of the constant HDD activity: it was the SMART monitoring! I turned it off, and right then the HDD went silent! I’m sure it makes some sense for the experts but it is quite counterintuitive that a monitoring feature would constantly stress the drive when there is absolutely no workload whatsoever.
For future reference:
Storage > Disk health > Manage Disks > Select the disk > Edit > untick “Enable SMART”
I will optimize settings later for the security/quietness tradeoff however, I’m very pleased with it for now. It is dead silent finally!
i use noise cancelling headphones Edifier WH700NB. Cheap and effective. Made the sounds drop from 100% down to 1% or less even when the server rack is in close proximity even.
it’s more convenient solution than relocating everything though you could definitely do that.
I had this same problem, using HGST data center refurb drives. It was just too much, obnoxious to listen to.
I gave up and just built a Windows Storage Space with tiering and the drives are now effectively silent.
I just assumed the problem is with ZFS and how the error checking and parity is managed. Who knows.
