When adding container via yaml, there is no webui button. Can this be achieved somehow? Or maybe add possibility to add link ?
Put this in your YAML file. Change port off course
x-portals:
- host: 0.0.0.0
path: /
port: 5353
scheme: http
does not seem to do any difference ?
Weird. I used this for example to create the mdblistarr app.
services:
mdblistarr:
container_name: mdblistarr
image: linaspurinis/mdblistarr:v2-beta@sha256:0e66f12d97912b6e80d695979893910f1736d2535ed360728af0ab5b972c2c0f
environment:
- PUID=568
- PGID=568
- UMASK=002
- TZ=Europe/Amsterdam
- PORT=5353
restart: unless-stopped
volumes:
- /mnt/myVol/config/mdblistarr:/usr/src/db
ports:
- "5353:5353"
x-portals:
- host: 0.0.0.0
path: /
port: 5353
scheme: http
When app started i have the Web UI button.
Getting the right icon is by editing the metadata.yaml in
/mnt/.ix-apps/app_configs/mdblistarr
and add the icon file.
host_mounts: []
icon: https://mdblist.com/static/mdblist_logo.png
maintainers: []
Not really an answer to your question, but I stopped using the WebUI altogether and just manage things through Portainer. You get a lot more control that way
Ditto, but using Dockge. Though I do use the Tailscale app.
