I have a ProLiant MicroServer Gen8 with 16 GB of ram. Is this enough to run scale? Reading the documentation makes me think that this would be a bit underpowered for what Scale needs. I mainly want to just run something like immich which isn’t available on core and Nextcloud. Is there a way to run docker on core?
Run a Linux VM, and run Docker in there, is the only real option. Running SCALE would have less overhead. But both Nextcloud and Immich are pretty heavy.
In my experience Scale runs better on low memory systems than Core did.
You should upgrade to Scale. Core is effectively EOL.
Thanks. That is what I ended up doing. Runs just fine.
