Could not delete Dataset in WebUI / zfs destroy aslo tricky
Greetings,
Wondering what I did wrong here.
I set up a single disk as a potential bkup candidate. I created a replication to the dataset “bkups” via Replication Tasks. Replication worked fine. Wanted to delete the entire VDEV and start over again.
When I tried to delete the dataset in WebUI it said that there was no storage remaining so it wouldn’t delete.
I went to command line and typed:
zfs destroy mnt/bkups
reponse: does not exist
so I cd’d to mnt
sudo zfs destroy -r bkups (←- this sucessfully removed bkups)
then had to
sudo zpool destroy bkups (←- this successfully removed the pool)
VDEV had to be removed from UI
Any “right way” to process deletion of a datset and VDEV from the WebUI?
