Crafty-4 creds don't work
Truenas Scale 25.04.2.5
App:
App Version: v4.5.5
Version: v1.0.22
The app notes indicate that the server username is admin and that the password is found in /crafty/app/config/default-creds.txt. I can load the app’s web UI and enter the username and password. It also asks for an authenticator code if MFA is enabled. I have not enabled MFA since I haven’t logged into the server yet, so I just hit the Log In button, and then I get the error “Incorrect username, password, or MFA”.
I tried using the “Forgot Password” button, but this just refers me back to the default-creds.txt file whose contents have not changed, and I’m still not able to log in.
What’s the secret to getting logged in for the first time?
idk if it helps but if you use video-guide “EASY Budget Minecraft Servers With Crafty“ re instal craftu in casaos and skip part with changing “/DATA/AppData/crafty“
after that it log in me
