Critical sector errors for one drive
I recently started using a new NAS, upgrading from my old nas4free box.
I started fresh with four new drives.
Took me a while to setup everything like I wanted in Truenas, and transfer all the data to the new box, which took me 4 days using rsync…
I forgot to burn in the new drives…
They are Seagate ST12000VN0008 12TB drives.
Now all of a sudden I am getting these errors for one of them:
I started a full smart test but it failed:
I’m currently running it again, which takes some time.
But I suspect something is seriously wrong.
I’d like to do the burn-in tests described here: Hard Drive Burn-in Testing | TrueNAS Community
Considering how long it took me to transfer all my data, setup shares and permissions… Is there a way to recover at least that setup work?
I have my four drives in 2x mirror setup, so could I offline one drive, do the burn-in tests and then resilver it, repeating this for each drive?
Worst case I still have my old NAS, and the data didn’t change since I transferred it.
Full report, the second test failed again:
admin@nas[~]$ sudo smartctl -a /dev/sdc
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.1.74-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST12000VN0008-2YS101
Serial Number:    <redacted>
LU WWN Device Id: <redacted>
Firmware Version: SC60
User Capacity:    12,000,138,625,024 bytes [12.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Apr 22 20:18:12 2024 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      ( 121) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1039) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   083   064   044    Pre-fail  Always       -       212077992
  3 Spin_Up_Time            0x0003   092   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       7
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   069   060   045    Pre-fail  Always       -       8400691
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       165
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       7
 18 Head_Health             0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   056   054   000    Old_age   Always       -       44 (Min/Max 39/46)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       294
194 Temperature_Celsius     0x0022   044   046   000    Old_age   Always       -       44 (0 22 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       2
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       2
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Pressure_Limit          0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   100   000    Old_age   Offline      -       157h+23m+34.230s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       4218995240
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       144161467
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed: read failure       90%       165         -
# 2  Extended offline    Completed: read failure       90%       162         -
The above only provides legacy SMART information - try 'smartctl -x' for more
RMA said drive, period. And cool the others down.
I’m not the most experienced in assessing smart data but for me it looks like the drive is indeed faulty.
You could try switching cables and check if everything is seated properly, but if that fails I’d RMA the drive.
Possible, but with 12 TB drives this will take a very long time, given that you can only burn in one drive at a time.
You’ll have no redundancy when you burn in the other drives and losing another disk will kill the whole pool.
I’d advise you get your other NAS up to speed on the data right now.
Do you have another source of backup?
Then you can check the cabling, if the drive still throws errors RMA it. Then burn in all drives simultaneously and recreate the pool from scratch.
In my experience you don’t get pending sectors and test failures from bad cables… not without CRC errors at the very least.
Yes, I found this page: Hard Drive Troubleshooting Guide (All Versions of FreeNAS) | TrueNAS Community and it’s clear this drive is problematic.
But I want to fully test the three other drives so I only have to RMA once.
So any chance of doing the burn-in tests without redoing all the setup?
jgreco’s solnet-array-test | TrueNAS Community can burn-in without data loss.
CRC is usually my go to indicator for bad cables, I wasn’t sure if OPs smart data will rule out any cabling for sure.
I can’t really remember, I think I also got pending sectors with a bad cable on one of my SSDs.
You still need to act now though, I interpret @Davvo meant this with cooling down the other drives. Two mirrored vdevs with one lost drive is not safe at this point, especially with untested drives.
Get your backups in order ASAP.
You can check the three remaining drives and already start the RMA process. Waiting for other drives to be burned in won’t speed up anything. If they all come back clean you’re already a few days ahead since you started the RMA process on the known faulty one.
I meant literally cooling the drives since I do not like seeing them at 44°C.
As far as I understand @Nikotine’s data is safely stored on his other Nas as well; if that’s not so, prioritize the backup of your data.
You don’t get them at all, unless there’s a firmware bug in the disk. They’re both strictly internal things.
Yeah the temperatures are a bit too high, I agree. The NAS is a Terramaster F4-424 pro and I just confirmed that the fan is spinning. I need to check if I can increase the speed in the BIOS.
I have mym original NAS still, and the only thing that was added since migration are some snapshots from my Proxmox server.
I’ll start the RMA process.
That looks like a very handy script, although read-only?
Will it test the full disk this way?
Just for my understanding, I need to let this script run for a few passes, then do the SMART test again to check for errors?
Similarly to memtest, run the script for as much as you want but at least a single pass. Then a long test at the end.
This is usually enough for 90% of the drives. If you want to be more zealous, run badblocks.
