Every time I access the TrueNAS Scale dashboard, version 24.10.1, through my Chromebook (HP Dragonfly), the network interface graph gradually disappears. This only happens with this graph; the CPU usage graph remains normal. See below: https://gifyu.com/image/SXlpo
If I access it from Chrome on my Windows PC, this does not happen.
Does anyone have any idea what I can do to solve this?
Can you force CSS dimensions and see if it resolves it? (It won’t be a fix fix, just seeing if it fixes at a certain point)
Go into DevTools (F12), edit the CSS and force canvas element to the right size, might need to add the CSS yourself, would look like a little like
canvas {
width: 508px;
height: 150px;
If that fixes it, will confirm if it’s a layout related issue.
Another thing (though not sure how sure here), would be to go into DevTools Console and check for any JavaScript errors
Because it’s not happening on Windows and only ChromeOS, it might be a specific issue with how that version of Chrome is rendering this page, sorry I don’t have a Chromebook to mess around with and have a look as well to see if I can replicate this.
Changes to the CSS won’t be a perm fix, but if you’re able to pinpoint what it is and what fix it was, might be worth giving your steps you did to replicate issue/resolve issue with ChromeOS version etc to iX so they can maybe look into a perm fix if other people are able to replicate this on ChromeOS - could be as simple as a lazy-logic process that is broken on your version of chrome
It almost worked!
I did force the canvas element, but as you can see below, as soon as I hit enter, the graph got back but still fades away: https://gifyu.com/image/SXWXl
Every pixel it gets smaller, I see an error in the DevTools Console saying:
[Violation] 'requestAnimationFrame' handler took 108ms
polyfills-4GSV3QYD.js:1
I just updated my Chromebook today to the latest version 131.0.6778.241, but it didn’t help much.
This is not chromeOS related issue but chrome at general. Im using brave rn on windows and stumbled upon this with page scaling set to anything other than 100%, when i set it to 90, 80 etc it fades away exactly like on GIF created by @carlos
Issue is on both 24.10.2.4 and 25.04.2.4
