I’m trying to set up a debian VM in TrueNAS scale. However, after the reboot at the end of the debian installation guide, it doesn’t boot into the new debian OS, it goes back to the install screen of debian.
Thx in advance!
Remove the (virtual) CDROM device.
How?
By going to the VM screen described in the documentation:
Select your VM and then click the “Devices” button underneath. There you will see, among other things, the CDROM drive, if one exists in that VM. Use the three dots on the right hand side to interact with it.
Cool, thanks. Once the install is done again… I’ll give it a try.
