Hi, I’m on ElectricEel 24.10.0.2 and after upgrading to ElectricEel I’ve had issues with folder ACLs set by setfacl command. First it was that default group acl was set to none instead of previous rwx (group::—) instead of (group::rwx) on some folders and now I’m having issues that new folders sometimes don’t have default permissions of parent folder so some users can’t even access folders they have created. The ACL structure is quite complex, because of move from legacy ye olde fedora to truenas, but it worked flawlessly until ElectricEel. Since then I have these problems and I often have to run setfacl command on the whole dataset because I can’t be bothered to find specific folders, so I can at least backup them. Any help with this would be highly appreciated, because I really don’t know what to do
This is one of the problematic directories for example. As you can see, defaults are there, but are not applied, also when it was created the group IH-vedouci had — permissions, so none of the two people who needed access couldn’t get there including the owner of the directory.
