Degraded RAID-Z1 pool and unused disk after expansion
I recently build my first NAS to upgrade from my single 20TB Media drive.
The plan was to create a RAID-Z1 pool with three drives. Since I didn’t have enough storage to offload my files, I created a RAID-Z1 pool with two drives via shell and imported it to the UI.
Afterwards I used the new expansion feature released with EE. After several days of copying data, I am now greeted with a Degraded Pool and 1 unused disk. :face_with_raised_eyebrow:
02
Output of ‘sudo zpool status -x’:
  pool: Media
 state: DEGRADED
status: One or more devices could not be used because the label is missing or
	invalid.  Sufficient replicas exist for the pool to continue
	functioning in a degraded state.
action: Replace the device using 'zpool replace'.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-4J
  scan: scrub repaired 0B in 12:38:28 with 0 errors on Sat Nov  9 11:31:30 2024
expand: expanded raidz1-0 copied 31.4T in 5 days 23:41:18, on Fri Nov  8 22:53:02 2024
	NAME                                      STATE     READ WRITE CKSUM
	Media                                     DEGRADED     0     0     0
	  raidz1-0                                DEGRADED     0     0     0
	    ata-TOSHIBA_MG10ACA20TE_5430A1JXF4MJ  ONLINE       0     0     0
	    ata-TOSHIBA_MG10ACA20TE_5430A1JMF4MJ  ONLINE       0     0     0
	    13054896084018409198                  UNAVAIL      0     0     0  was /dev/disk/by-partuuid/eab34848-c78d-432f-850b-c327e77ad7bf
errors: No known data errors
The unavailable disk is my old media drive.
I’m a beginner and unsure how to proceed. Can I just replace the unavailable disk with the unused disk (,even though it’s the same drive)?
Any advice would be appreciated.
Thanks for reading.
Hi!
I have the exact same issue here after extending my 3-disk zraid1 with one more disk.
it says, the new disk is now UNAVAIL, allthough it’s listed to be avail&unused.
strangely enough, fdisk does list the disk, but blkid doesnt. Maybe that’s why it’s only half detected?
pls help!
thanks,
Mike
ah, btw, after adding the fourth disk (waiting 48 hrs) all looked nice.
then it decided to to a scrub for anoth 10 hours.
after that, now the disk is lost but there…somewhere in a transient state :slight_smile:
I just do not dare to add the disk again to the zraid1, since it was there already…
regards,
Mike
Need details for your systems please.
https://forums.truenas.com/t/joes-rules-to-asking-for-help/12740
sorry, also newbie here :slight_smile:
OS Version:TrueNAS-SCALE-24.10.0.2
Product:ProLiant MicroServer
Model:AMD Turion™ II Neo N54L Dual-Core Processor
Memory:16 GiB
NIC: 2.5Gb
4x 16TB Seagate ST16000NM001G-2KK103
Here is, what fdisk sees:
truenas_admin@truenas:~$ sudo fdisk -l /dev/sda
Disk /dev/sda: 14.55 TiB, 16000900661248 bytes, 31251759104 sectors
Disk model: ST16000NM001G-2K
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 7FB75C4C-D652-4209-B220-46B46B624F5D
Device     Start         End     Sectors  Size Type
/dev/sda1   2048 31251757055 31251755008 14.6T Solaris /usr & Apple ZFS
here is what blkid sees:
truenas_admin@truenas:~$ sudo blkid
/dev/sdf3: LABEL="boot-pool" UUID="3370188939962827323" UUID_SUB="13189111619698390422" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="7e3b6cf8-eaa2-4d48-a443-40a145ecbf9e"
/dev/sdf2: LABEL_FATBOOT="EFI" LABEL="EFI" UUID="0D4D-2BA7" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="4796eaee-887d-4982-b509-9917f97bf0b5"
/dev/sdd1: UUID_SUB="544723011062381214" BLOCK_SIZE="4096" TYPE="zfs_member" PARTLABEL="data" PARTUUID="b953b2f5-e269-43bf-9d20-b4d34e5ece63"
/dev/sdb1: LABEL="RAID" UUID="1901115498841768824" UUID_SUB="12922634147688021886" BLOCK_SIZE="4096" TYPE="zfs_member" PARTLABEL="data" PARTUUID="a83058de-032f-4f81-9c0a-f62bb50cc359"
/dev/sde1: LABEL="RAID" UUID="1901115498841768824" UUID_SUB="538098376802416322" BLOCK_SIZE="4096" TYPE="zfs_member" PARTLABEL="data" PARTUUID="bb9f4f4b-9457-4f2b-a398-b9eab36d5e96"
/dev/sdc1: LABEL="RAID" UUID="1901115498841768824" UUID_SUB="4407132540304298790" BLOCK_SIZE="4096" TYPE="zfs_member" PARTLABEL="data" PARTUUID="6fb1e42b-76a5-44a4-b63a-c608e643435a"
/dev/sdf1: PARTUUID="09d4a535-53ad-4f0f-86dc-bfa14b3ad6c6"
here is what zstatus says:
truenas_admin@truenas:~$ sudo zpool status -x
  pool: RAID
 state: DEGRADED
  scan: scrub repaired 0B in 10:59:19 with 0 errors on Sat Nov 16 20:37:35 2024
expand: expanded raidz1-0 copied 28.2T in 2 days 01:31:58, on Sat Nov 16 09:38:16 2024
        RAID                                      DEGRADED     0     0     0
            a83058de-032f-4f81-9c0a-f62bb50cc359  ONLINE       0     0     0
            bb9f4f4b-9457-4f2b-a398-b9eab36d5e96  ONLINE       0     0     0
            6fb1e42b-76a5-44a4-b63a-c608e643435a  ONLINE       0     0     0
            2e58e50f-49bc-4ada-979d-68ed8582e70c  UNAVAIL      0     0     0
        cache
          b953b2f5-e269-43bf-9d20-b4d34e5ece63    ONLINE       0     0     0
truenas_admin@truenas:~$ sudo zpool list
NAME        SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
RAID       43.7T  29.5T  14.2T        -     14.5T     0%    67%  1.00x  DEGRADED  /mnt
boot-pool  56.5G  4.64G  51.9G        -         -     2%     8%  1.00x    ONLINE  -
truenas_admin@truenas:~$ sudo smartctl -x /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate Exos X16
Device Model:     ST16000NM001G-2KK103
Serial Number:    ZL26DXG6
LU WWN Device Id: 5 000c50 0c6471213
Firmware Version: SN03
User Capacity:    16,000,900,661,248 bytes [16.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sun Nov 17 04:07:11 2024 PST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Write SCT (Get) Feature Control Command failed: Connection timed out
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
...and so on...
and finally
truenas_admin@truenas:~$ sudo lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda      8:0    0  14.6T  0 disk
└─sda1   8:1    0  14.6T  0 part
sdb      8:16   0  14.6T  0 disk
└─sdb1   8:17   0  14.6T  0 part
sdc      8:32   0  14.6T  0 disk
└─sdc1   8:33   0  14.6T  0 part
sdd      8:48   0 953.9G  0 disk
└─sdd1   8:49   0 953.9G  0 part
sde      8:64   0  14.6T  0 disk
└─sde1   8:65   0  14.6T  0 part
sdf      8:80   1  57.3G  0 disk
├─sdf1   8:81   1     1M  0 part
├─sdf2   8:82   1   512M  0 part
└─sdf3   8:83   1  56.8G  0 part
I’ll wait for someone more experienced to comment on the missing drive.
On another issue. What is the ‘cache’ drive listed? Is it L2ARC? Your specs only show 16GB of RAM and adding L2ARC starts at around 64GB of RAM. L2ARC eats into RAM that can be used for regular ARC below that and should only be added if necessary, according to the ARC stats. Please see the ZFS primer and hardware doc section for your TrueNAS version for more info.
https://www.truenas.com/docs/references/zfsprimer/
“cache” in zpool status is indeed L2ARC, and 16 GB is way too low to consider that.
The drive is not shown by blkid. Does sudo lsblk shows more?
Have you checked cables?
FYI, @mkropfbe continued his problem in another thread due to new poster limits. First post looks like we helped.
https://forums.truenas.com/t/degraded-raid-z1-pool-and-unused-disk-after-expansion-continued/24794/2
