Hi all,
what shall I make out of this alert in the UI (and also in TrueCommand)?
Device: /dev/ada1, ATA error count increased from 1 to 2.
In Scrutiny there is no indication of any error counter increasing (they are all at 0, actually).
The full smartctl -x tells a different story, though:
root@freenas[~]# smartctl -x /dev/ada1
smartctl 7.4 2023-08-01 r5530 [FreeBSD 13.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: WDC WD60EFPX-68C5ZN0
Serial Number: WD-*****************
LU WWN Device Id: 5 0014ee 21617f15d
Firmware Version: 81.00A81
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Oct 10 16:51:01 2024 CEST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (63540) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 659) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3039) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 100 253 021 - 0
4 Start_Stop_Count -O--CK 100 100 000 - 2
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 096 096 000 - 3165
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 1
192 Power-Off_Retract_Count -O--CK 200 200 000 - 0
193 Load_Cycle_Count -O--CK 200 200 000 - 2
194 Temperature_Celsius -O---K 116 110 000 - 34
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL R/O 256 Device Statistics log
0x04 SL R/O 255 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x24 GPL R/O 307 Current Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb6 GPL,SL VS 1 Device vendor specific log
0xb7 GPL,SL VS 78 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 3
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 3 [2] occurred at disk power-on lifetime: 3148 hours (131 days + 4 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
04 -- 51 00 0b 00 00 00 00 00 00 40 00 Error: ABRT
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
b0 00 d5 00 01 00 00 00 c2 4f e1 40 08 31d+18:17:52.974 SMART READ LOG
b0 00 d6 00 01 00 00 00 c2 4f e0 40 08 31d+18:17:52.974 SMART WRITE LOG
b0 00 d6 00 01 00 00 00 c2 4f e0 40 08 31d+18:17:52.973 SMART WRITE LOG
b0 00 d5 00 01 00 00 00 c2 4f e0 40 08 31d+18:17:52.972 SMART READ LOG
61 00 20 00 d0 00 02 2d 36 3c 38 40 08 31d+18:17:52.969 WRITE FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 2908 hours (121 days + 4 hours)
b0 00 d5 00 01 00 00 00 c2 4f e1 40 08 21d+18:32:06.300 SMART READ LOG
b0 00 d6 00 01 00 00 00 c2 4f e0 40 08 21d+18:32:06.300 SMART WRITE LOG
b0 00 d6 00 01 00 00 00 c2 4f e0 40 08 21d+18:32:06.299 SMART WRITE LOG
b0 00 d5 00 01 00 00 00 c2 4f e0 40 08 21d+18:32:06.299 SMART READ LOG
61 00 08 00 a0 00 02 1e 04 ac 88 40 08 21d+18:32:06.286 WRITE FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 439 hours (18 days + 7 hours)
b0 00 d5 00 01 00 00 00 c2 4f e1 40 08 18d+07:04:08.527 SMART READ LOG
b0 00 d6 00 01 00 00 00 c2 4f e0 40 08 18d+07:04:08.527 SMART WRITE LOG
b0 00 d6 00 01 00 00 00 c2 4f e0 40 08 18d+07:04:08.526 SMART WRITE LOG
b0 00 d5 00 01 00 00 00 c2 4f e0 40 08 18d+07:04:08.526 SMART READ LOG
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 3154 -
# 2 Short offline Completed without error 00% 3130 -
# 3 Short offline Completed without error 00% 3106 -
# 4 Short offline Completed without error 00% 3082 -
# 5 Short offline Completed without error 00% 3058 -
# 6 Extended offline Completed without error 00% 3046 -
# 7 Short offline Completed without error 00% 3010 -
# 8 Short offline Completed without error 00% 2986 -
# 9 Short offline Completed without error 00% 2962 -
#10 Short offline Completed without error 00% 2938 -
#11 Short offline Completed without error 00% 2915 -
#12 Short offline Completed without error 00% 2891 -
#13 Extended offline Completed without error 00% 2878 -
#14 Short offline Completed without error 00% 2843 -
#15 Short offline Completed without error 00% 2819 -
#16 Short offline Completed without error 00% 2795 -
#17 Short offline Completed without error 00% 2771 -
#18 Short offline Completed without error 00% 2747 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 34 Celsius
Power Cycle Min/Max Temperature: 20/40 Celsius
Lifetime Min/Max Temperature: 20/40 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/65 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (36)
Index Estimated Time Temperature Celsius
37 2024-10-10 08:54 34 ***************
... ..( 98 skipped). .. ***************
136 2024-10-10 10:33 34 ***************
137 2024-10-10 10:34 30 ***********
... ..( 3 skipped). .. ***********
141 2024-10-10 10:38 30 ***********
142 2024-10-10 10:39 31 ************
... ..( 4 skipped). .. ************
147 2024-10-10 10:44 31 ************
148 2024-10-10 10:45 32 *************
... ..( 7 skipped). .. *************
156 2024-10-10 10:53 32 *************
157 2024-10-10 10:54 33 **************
... ..( 30 skipped). .. **************
188 2024-10-10 11:25 33 **************
189 2024-10-10 11:26 34 ***************
... ..(324 skipped). .. ***************
36 2024-10-10 16:51 34 ***************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 3) ==
0x01 0x008 4 1 --- Lifetime Power-On Resets
0x01 0x010 4 3165 --- Power-on Hours
0x01 0x018 6 6949254854 --- Logical Sectors Written
0x01 0x020 6 87412998 --- Number of Write Commands
0x01 0x028 6 71904826733 --- Logical Sectors Read
0x01 0x030 6 42791946 --- Number of Read Commands
0x01 0x038 6 2804065408 --- Date and Time TimeStamp
0x02 ===== = = === == Free-Fall Statistics (rev 1) ==
0x02 0x010 4 0 --- Overlimit Shock Events
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 3120 --- Spindle Motor Power-on Hours
0x03 0x010 4 3119 --- Head Flying Hours
0x03 0x018 4 2 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 0 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 34 --- Current Temperature
0x05 0x010 1 33 --- Average Short Term Temperature
0x05 0x018 1 33 --- Average Long Term Temperature
0x05 0x020 1 40 --- Highest Temperature
0x05 0x028 1 27 --- Lowest Temperature
0x05 0x030 1 38 --- Highest Average Short Term Temperature
0x05 0x038 1 30 --- Lowest Average Short Term Temperature
0x05 0x040 1 35 --- Highest Average Long Term Temperature
0x05 0x048 1 33 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 65 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 28 --- Number of Hardware Resets
0x06 0x010 4 18 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
0xff ===== = = === == Vendor Specific Statistics (rev 1) ==
0xff 0x008 7 0 --- Vendor Specific
0xff 0x010 7 0 --- Vendor Specific
0xff 0x018 7 0 --- Vendor Specific
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 27 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 28 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 11394806 Vendor specific
root@freenas[~]#
Any hints about what I am dealing with?
