here’s the glabel status:
root@truenas[/tmp]# glabel status
Name Status Components
gptid/2acc72a5-5875-11ee-8691-3cecef0ff484 N/A ada0p1
gptid/2ad1ae0d-5875-11ee-8691-3cecef0ff484 N/A ada1p1
gptid/e8b76b2a-5877-11ee-b974-3cecef0ff484 N/A da0p1
gptid/e8bc28f8-5877-11ee-b974-3cecef0ff484 N/A da1p1
gptid/ea093413-5877-11ee-b974-3cecef0ff484 N/A da2p2
gptid/e9f532b1-5877-11ee-b974-3cecef0ff484 N/A da3p2
gptid/ea5c7d87-5877-11ee-b974-3cecef0ff484 N/A da4p2
gptid/ea1ac84a-5877-11ee-b974-3cecef0ff484 N/A da5p2
gptid/ea132c35-5877-11ee-b974-3cecef0ff484 N/A da6p2
gptid/ea54d164-5877-11ee-b974-3cecef0ff484 N/A da7p2
gptid/2ad34b86-5875-11ee-8691-3cecef0ff484 N/A ada1p3
gptid/2ace12d3-5875-11ee-8691-3cecef0ff484 N/A ada0p3
here the zpool status output:
root@truenas[/tmp]# zpool status
pool: ZFSPool
state: ONLINE
scan: scrub repaired 0B in 09:15:12 with 0 errors on Sun May 26 09:15:12 2024
NAME STATE READ WRITE CKS UM
ZFSPool ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/ea093413-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
gptid/e9f532b1-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
gptid/ea5c7d87-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
gptid/ea1ac84a-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
gptid/ea132c35-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
gptid/ea54d164-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
cache
gptid/e8b76b2a-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
gptid/e8bc28f8-5877-11ee-b974-3cecef0ff484 ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:06 with 0 errors on Wed Jun 26 03:45:06 2024
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
pool: ZFSPool
state: ONLINE
cache
pool: boot-pool
state: ONLINE
ada0p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
and also:
root@truenas[/tmp]# dmesg | grep mpr
mpr0: <Avago Technologies (LSI) SAS3008> port 0xd000-0xd0ff mem 0xe6640000-0xe664ffff,0xe6600000-0xe663ffff irq 18 at device 0.0 numa-domain 0 on pci9
mpr0: Firmware: 16.00.10.00, Driver: 23.00.00.00-fbsd
mpr0: IOCCapabilities: 7a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc,FastPath,RDPQArray>
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x0009> enclosureHandle<0x0001> slot 0
mpr0: At enclosure level 0 and connector name ( )
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x000a> enclosureHandle<0x0001> slot 1
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x000b> enclosureHandle<0x0001> slot 2
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x000c> enclosureHandle<0x0001> slot 3
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x000d> enclosureHandle<0x0001> slot 4
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x000e> enclosureHandle<0x0001> slot 5
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x000f> enclosureHandle<0x0001> slot 6
mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x0010> enclosureHandle<0x0001> slot 7
da0 at mpr0 bus 0 scbus12 target 0 lun 0
da1 at mpr0 bus 0 scbus12 target 1 lun 0
da3 at mpr0 bus 0 scbus12 target 3 lun 0
da4 at mpr0 bus 0 scbus12 target 4 lun 0
da2 at mpr0 bus 0 scbus12 target 2 lun 0
da5 at mpr0 bus 0 scbus12 target 5 lun 0
da6 at mpr0 bus 0 scbus12 target 6 lun 0
da7 at mpr0 bus 0 scbus12 target 7 lun 0
mpr0: mpr_user_pass_thru: user reply buffer (64) smaller than returned buffer (68)
mpr0: Reinitializing controller
mpr0: Firmware: 16.00.12.00, Driver: 23.00.00.00-fbsd
mpr0: Unfreezing SIM queue
mpr0: Firmware: 16.00.14.00, Driver: 23.00.00.00-fbsd
